Help needed to remove error
I'm building a pulse oximeter, and the code is giving this error, exit status 1
Error compiling for board Arduino Nano. Please help me resolve this issue. It's urgent.
I've copy-pasted the error message below.
Arduino: 1.8.19 (Windows 10), Board: "Arduino Nano, ATmega328P"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Shanzay\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Shanzay\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Shanzay\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\Shanzay\AppData\Local\Temp\arduino_build_667775 -warnings=all -build-cache C:\Users\Shanzay\AppData\Local\Temp\arduino_cache_85163 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Shanzay\Desktop\Pulse_oximeter\Pulse_oximeter.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Shanzay\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Shanzay\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Shanzay\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\Shanzay\AppData\Local\Temp\arduino_build_667775 -warnings=all -build-cache C:\Users\Shanzay\AppData\Local\Temp\arduino_cache_85163 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose C:\Users\Shanzay\Desktop\Pulse_oximeter\Pulse_oximeter.ino
Using board 'nano' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Users\\Shanzay\\AppData\\Local\\Temp\\arduino_build_667775\\sketch\\Pulse_oximeter.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0 Wire-master@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0 Wire-master@1.0]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\Shanzay\\AppData\\Local\\Temp\\arduino_build_667775\\sketch\\Pulse_oximeter.ino.cpp" -o nul
Alternatives for MAX30100_PulseOximeter.h: [Arduino-MAX30100-master@1.2.1]
ResolveLibrary(MAX30100_PulseOximeter.h)
  -> candidates: [Arduino-MAX30100-master@1.2.1]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Arduino-MAX30100-master\\src" "C:\\Users\\Shanzay\\AppData\\Local\\Temp\\arduino_build_667775\\sketch\\Pulse_oximeter.ino.cpp" -o nul
Alternatives for Adafruit_GFX.h: [Adafruit-GFX-Library-master@1.11.3]
ResolveLibrary(Adafruit_GFX.h)
  -> candidates: [Adafruit-GFX-Library-master@1.11.3]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Arduino-MAX30100-master\\src" "-IC:\\Program Files (x86)\\Arduino\\libraries\\Adafruit-GFX-Library-master" "C:\\Users\\Shanzay\\AppData\\Local\\Temp\\arduino_build_667775\\sketch\\Pulse_oximeter.ino.cpp" -o nul
Alternatives for Adafruit_I2CDevice.h: []
ResolveLibrary(Adafruit_I2CDevice.h)
  -> candidates: []
Multiple libraries were found for "Wire.h"
 Used: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
In file included from C:\Users\Shanzay\Desktop\Pulse_oximeter\Pulse_oximeter.ino:4:0:
 Not used: C:\Program Files (x86)\Arduino\libraries\Wire-master
C:\Program Files (x86)\Arduino\libraries\Adafruit-GFX-Library-master/Adafruit_GFX.h:12:10: fatal error: Adafruit_I2CDevice.h: No such file or directory
 #include <Adafruit_I2CDevice.h>
compilation terminated.
Using library Wire at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\Wire
Using library Arduino-MAX30100-master at version 1.2.1 in folder: C:\Program Files (x86)\Arduino\libraries\Arduino-MAX30100-master
Using library Adafruit-GFX-Library-master at version 1.11.3 in folder: C:\Program Files (x86)\Arduino\libraries\Adafruit-GFX-Library-master
exit status 1
Did you install that library?
Only for you.
Did you check, didn´t you?
I've installed all the 4 libraries that are in my code.
#include <Wire.h>
#include "MAX30100_PulseOximeter.h"
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define ENABLE_MAX30100 1
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 //64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
// The pins for I2C are defined by the Wire-library.
// On an arduino UNO:       A4(SDA), A5(SCL)
// On an arduino MEGA 2560: 20(SDA), 21(SCL)
// On an arduino LEONARDO:   2(SDA),  3(SCL), ...
#define OLED_RESET     -1 // 4 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3c ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#if ENABLE_MAX30100
#define REPORTING_PERIOD_MS     5000
// PulseOximeter is the higher level interface to the sensor
// it offers:
//  * beat detection reporting
//  * heart rate calculation
//  * SpO2 (oxidation level) calculation
PulseOximeter pox;
#endif
uint32_t tsLastReport = 0;
int xPos = 0;
// Callback (registered below) fired when a pulse is detected
void onBeatDetected()
  Serial.println("Beat!");
  heart_beat(&xPos);
  Serial.println("SSD1306 128x64 OLED TEST");
  // SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
  if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
    Serial.println(F("SSD1306 allocation failed"));
    for (;;); // Don't proceed, loop forever
  // Show initial display buffer contents on the screen --
  // the library initializes this with an Adafruit splash screen.
  //display.display();
  display.clearDisplay();
  display.setTextSize(1);
  display.setTextColor(WHITE);
  display.setCursor(20, 18);
  // Display static text
  display.print("Pulse OxiMeter");
  int temp1 = 0;
  int temp2 = 40;
  int temp3 = 80;
  heart_beat(&temp1);
  heart_beat(&temp2);
  heart_beat(&temp3);
  xPos = 0;
  display.display();
  delay(2000); // Pause for 2 seconds
  display.cp437(true);
  Serial.print("Initializing pulse oximeter..");
#if ENABLE_MAX30100
  // Initialize the PulseOximeter instance
  // Failures are generally due to an improper I2C wiring, missing power supply
  // or wrong target chip
  if (!pox.begin()) {
    Serial.println("FAILED");
    for (;;);
    Serial.println("SUCCESS");
  // The default current for the IR LED is 50mA and it could be changed
  //   by uncommenting the following line. Check MAX30100_Registers.h for all the
  //   available options.
  pox.setIRLedCurrent(MAX30100_LED_CURR_7_6MA);
  // Register a callback for the beat detection
  pox.setOnBeatDetectedCallback(onBeatDetected);
  display_data(0, 0);
#endif
#if ENABLE_MAX30100
  // Make sure to call update as fast as possible
  pox.update();
  int bpm = 0;
  int spo2 = 0;
  // Asynchronously dump heart rate and oxidation levels to the serial
  // For both, a value of 0 means "invalid"
  if (millis() - tsLastReport > REPORTING_PERIOD_MS) {
    //Serial.print("Heart rate:");
    bpm = pox.getHeartRate();
    spo2 = pox.getSpO2();
    Serial.println(bpm);
    //Serial.print("bpm / SpO2:");
    Serial.println(spo2);
    //Serial.println("%");
    tsLastReport = millis();
    display_data(bpm, spo2);
#endif
  drawLine(&xPos);
void display_data(int bpm, int spo2) {
  display.fillRect(0, 18, 127, 15, SSD1306_BLACK);
  display.setCursor(0, 18);
  display.print("BPM ");
  display.print(bpm);
  display.display();
  display.setCursor(64, 18);
  display.print("Spo2% ");
  display.println(spo2);
  display.display();
void drawLine(int *x_pos) {
  // Draw a single pixel in white
  display.drawPixel(*x_pos, 8, SSD1306_WHITE);
  display.drawPixel((*x_pos)++, 8, SSD1306_WHITE);
  display.drawPixel((*x_pos), 8, BLACK);  // -----
  //Serial.println(*x_pos);
  display.fillRect(*x_pos, 0, 31, 16, SSD1306_BLACK);
  display.display();
  delay(1);
  if (*x_pos >= SCREEN_WIDTH) {
    *x_pos = 0;
void heart_beat(int *x_pos) {
  //display.clearDisplay();
  display.fillRect(*x_pos, 0, 30, 15, SSD1306_BLACK);
  display.drawPixel(*x_pos + 0, 8, SSD1306_WHITE);
  display.drawPixel(*x_pos + 1, 8, SSD1306_WHITE);
  display.drawPixel(*x_pos + 2, 8, SSD1306_WHITE);
  display.drawPixel(*x_pos + 3, 8, SSD1306_WHITE);
  display.drawPixel(*x_pos + 4, 8, BLACK); // -----
  //delay(1);
  display.drawPixel(*x_pos + 5, 7, SSD1306_WHITE);
  display.drawPixel(*x_pos + 6, 6, SSD1306_WHITE);
  display.drawPixel(*x_pos + 7, 7, SSD1306_WHITE); // .~.
  //delay(1);
  display.drawPixel(*x_pos + 8, 8, SSD1306_WHITE);
  display.drawPixel(*x_pos + 9, 8, SSD1306_WHITE); // --
  //delay(1);
  display.drawPixel(*x_pos + 10, 8, SSD1306_WHITE);
  display.drawPixel(*x_pos + 10, 9, SSD1306_WHITE);
  display.drawPixel(*x_pos + 11, 10, SSD1306_WHITE);
  display.drawPixel(*x_pos + 11, 11, SSD1306_WHITE);
  //delay(1);
  display.drawPixel(*x_pos + 12, 10, SSD1306_WHITE);
  display.drawPixel(*x_pos + 12, 9, SSD1306_WHITE);
  display.drawPixel(*x_pos + 12, 8, SSD1306_WHITE);
  display.drawPixel(*x_pos + 12, 7, SSD1306_WHITE);
  //delay(1);
  display.drawPixel(*x_pos + 13, 6, SSD1306_WHITE);
  display.drawPixel(*x_pos + 13, 5, SSD1306_WHITE);
  display.drawPixel(*x_pos + 13, 4, SSD1306_WHITE);
  display.drawPixel(*x_pos + 13, 3, SSD1306_WHITE);
  //delay(1);
  display.drawPixel(*x_pos + 14, 2, SSD1306_WHITE);
  display.drawPixel(*x_pos + 14, 1, SSD1306_WHITE);
  display.drawPixel(*x_pos + 14, 0, SSD1306_WHITE);
  //delay(1);
  display.drawPixel(*x_pos + 15, 0, SSD1306_WHITE);
  display.drawPixel(*x_pos + 15, 1, SSD1306_WHITE);
  display.drawPixel(*x_pos + 15, 2, SSD1306_WHITE);
  display.drawPixel(*x_pos + 15, 3, SSD1306_WHITE);
  //delay(1);
  display.drawPixel(*x_pos + 15, 4, SSD1306_WHITE);
  display.drawPixel(*x_pos + 15, 5, SSD1306_WHITE);
  display.drawPixel(*x_pos + 16, 6, SSD1306_WHITE);
  display.drawPixel(*x_pos + 16, 7, SSD1306_WHITE);
  //delay(1);
  display.drawPixel(*x_pos + 16, 8, SSD1306_WHITE);
  display.drawPixel(*x_pos + 16, 9, SSD1306_WHITE);
  display.drawPixel(*x_pos + 16, 10, SSD1306_WHITE);
  display.drawPixel(*x_pos + 16, 11, SSD1306_WHITE);
  //delay(1);
  display.drawPixel(*x_pos + 17, 12, SSD1306_WHITE);
  display.drawPixel(*x_pos + 17, 13, SSD1306_WHITE);
  display.drawPixel(*x_pos + 17, 14, SSD1306_WHITE);
  display.drawPixel(*x_pos + 17, 15, SSD1306_WHITE);
  //delay(1);
  display.drawPixel(*x_pos + 18, 15, SSD1306_WHITE);
  display.drawPixel(*x_pos + 18, 14, SSD1306_WHITE);
  display.drawPixel(*x_pos + 18, 13, SSD1306_WHITE);
  display.drawPixel(*x_pos + 18, 12, SSD1306_WHITE);
  //delay(1);
  display.drawPixel(*x_pos + 19, 11, SSD1306_WHITE);
  display.drawPixel(*x_pos + 19, 10, SSD1306_WHITE);
  display.drawPixel(*x_pos + 19, 9, SSD1306_WHITE);
  display.drawPixel(*x_pos + 19, 8, SSD1306_WHITE);
  //delay(1);
  display.drawPixel(*x_pos + 20, 8, SSD1306_WHITE);
  display.drawPixel(*x_pos + 21, 8, SSD1306_WHITE);
  //delay(1);
  display.drawPixel(*x_pos + 22, 7, SSD1306_WHITE);
  display.drawPixel(*x_pos + 23, 6, SSD1306_WHITE);
  display.drawPixel(*x_pos + 24, 6, SSD1306_WHITE);
  display.drawPixel(*x_pos + 25, 7, SSD1306_WHITE);
  //delay(1);
  display.drawPixel(*x_pos + 26, 8, SSD1306_WHITE);
  display.drawPixel(*x_pos + 27, 8, SSD1306_WHITE);
  display.drawPixel(*x_pos + 28, 8, SSD1306_WHITE);
  display.drawPixel(*x_pos + 29, 8, SSD1306_WHITE);
  display.drawPixel(*x_pos + 30, 8, SSD1306_WHITE); // -----
  *x_pos = *x_pos + 30;
  display.display();
  delay(1);
My limited experience of the Adafruit library installation is that they're quite good at prompting you to install any dependencies.
I've almost no knowledge of Arduino and it's Libraries. I have to make a project and the focus is the circuit not the code, bit in order to run the device I need code.
I haven't even written it myself. I took it from the Internet. Can you please help me (considering the fact I know no technical terms and haven't used Arduino before)
I'll really appreciate it.
Thanks.
Help us to help you
There is no way around that you adjust the arduino IDE like shown in this tutorial to
make the IDE say in more detail what the error is
How did you install them? What method did you use?
There were links in the video that I'm using as a reference. I downloaded them from there. They're were GitHub links.
Did you install them using the Arduino-IDE-internal install ZIP-library function?
Anyway if you would adjust the Arduino-IDE to
  • extended output while compiling
  • extended output while uploading
  • and adjust to compiler-warnings to all
and then do the compiling and as the compiler aborts with an error message
click the "copy Error-messages button and would paste this compiler-log
into a code-section here in the forum
The experienced user could say what is wrong.
Without this extended compiler-log all is guessing in the fog!
Thank you for adding the complete error message to your original posting.
I think this is part part of Adafruit_BusIO library.
Install the Adafruit_BusIO library using the Library Manager.
Just tried your code. It compiled without error using Arduino 1.8.19
Libraries:
#include <Wire.h>                     // no need to install, already available
#include "MAX30100_PulseOximeter.h"   // download zip
#include <Adafruit_GFX.h>             // installed from library manager
#include <Adafruit_SSD1306.h>         // installed from library manager
The zipped library was added using:
Sketch > Include Library > Add .ZIP Library... > Arduino-MAX30100-master.zip
I think your installation of a Wire library wasn't needed and it's causing the Arduino version to be ignored, as noted in your error verbose here ...
This should be used ...
  • Try uninstalling whatever wire library you've added
I was constantly searching for adafruit_I2C and was unable to find it.
Thank you so much for giving actionable advice. The issue is resolved. Once again, thank you for your time and guidance. Really appreciate it.
Yes, I had another wire library, and I installed it, it worked.
