Hi
I want to use a silicon photodiode in a research project. Actually i need a photodiode "hydrogenated amorphous silicon (a-Si:H) p-doped/intrinsic/n-doped photodiode" but it's hard to find, so i search for an alternative. The alternative must or should:
1-commercial and cheap
2- Very small surface area (less than 1 mm2)
3-landa max (absorption wave length) near to 470 nm
4- Module is better than phtodiode
5- Senestive
6- with routine voltages (adaptable to UNO)
What are UR suggestions?
From the abstract of the article Its not clear to me whether they have used a customized Diode (the chip itself) or not. Some Integration stuff, ok, but probably an of-the-shelf diode (keep in mind that if not semiconductor specialists or even not engineering they have to use this "hydrogenated amorphous silicon (a-Si:H) p-doped/intrinsic/n-doped photodiode"-wording to appear being cool)...
Anyway: ask the authors what they have used. If a commercial one, you are done.
I think, @jremington provided all required Information to make the next step in your research(!) project on your own.
Btw: there is a counter on the provided link. It just says "one", and that was me. So it appears to me that you have not even taken his reply sufficiantly into account
