Help please! Door Lock button not working
Hello. Im new to Arduino and Im currently working on my first projekt (in Tinkercad) which is a door lock system. Programing was going smoothly so far but now im stuck on a problem. As my last part of the projekt I added a button which was meant to be on the other side of of the door and when pressed it was suppose to open the door just as it would with the correct password from the other side. Im not sure whether its the code or the conections that is the problem. Im able to run the code but when I press the button nothing changes.
#include <Keypad.h>
#include <LiquidCrystal.h>
#include <Servo.h>
#define Password_Length 5
Servo servo1;
LiquidCrystal lcd(A0, A1, A2, A3, A4, A5);
int buzzerPin = 12;
const int buttonPin = 8;
int buttonState = 0;
char Data[Password_Length];
char Pass[Password_Length] = "1111";
byte data_count = 0;
char customKey;
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
byte rowPins[ROWS] = {0, 1, 2, 3};
byte colPins[COLS] = {4, 5, 6, 7};
Keypad customKeypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
  servo1.attach(9);
  servo1.write(0);
  lcd.begin(16, 2);
  lcd.print("door locked");
  lcd.clear();
  pinMode(10, OUTPUT);
  pinMode(11,OUTPUT);
  pinMode(buzzerPin, OUTPUT);
  pinMode(buttonPin, INPUT);
  Open();
  if (buttonState == HIGH){
    void Button();
void Button(){
  servo1.write(90);
    lcd.print("door open");
    digitalWrite(10, HIGH);
    digitalWrite(11, LOW);
    delay(5000);
    lcd.clear();
    noTone(buzzerPin);
    servo1.write(0);
void clearData() {
  while (data_count != 0) {
    Data[data_count--] = 0;
void deleteChar() {
  if (data_count > 0) {
    data_count--;
    Data[data_count] = 0;
    lcd.setCursor(data_count, 1);
    lcd.print(' ');
void Open() {
  lcd.setCursor(0, 0);
  lcd.print("enter password");
  digitalWrite(10, LOW);
  noTone(buzzerPin);
  customKey = customKeypad.getKey();
  if (customKey) {
    if (customKey == '#') {
      deleteChar();
      Data[data_count] = customKey;
      lcd.print(Data[data_count]);
      data_count++;
      tone(buzzerPin, 440);
  if (data_count == Password_Length - 1) {
    if (!strcmp(Data, Pass)) {
      lcd.clear();
      servo1.write(90);
      delay(5000);
      lcd.clear();
      noTone(buzzerPin);
      servo1.write(0);
    else {
      lcd.clear();
      lcd.print("incorrect password");
      digitalWrite(11, HIGH);
      noTone(buzzerPin);
      delay(2000);
    lcd.clear();
    clearData();
Welcome to the forum
Where in the code do you read the state of the button ?
Oh, I see, thats a line I forgot. So do I just add this into void loop ?
  buttonState = digitalRead(buttonPin);
  Open();
    void Button();
Beacause this dosent seem to work
Check the wiring of the button very carefully. Note that the button is not square and if inserted 90 degrees out of place it may not be doing what you think it is
Is the button pin held LOW when the button is not pressed ?
Does the button pin go HIGH when the button is pressed ?
Print the value of buttonState every time you read the button pin
Ok so I added this along with Serial.begin(9600); in the setup
  Open();
    Serial.println ("Yes");
    delay (1000);
    void Button();
And it dosent work. I mean nothing is beeing writen in the serial monitor
My conclusion would be that buttonState is never HIGH
Check those button connections again
Better still :
  • Use INPUT_PULLUP in pinMode() for buttonPin to enable the built in pullup resistor to keep the pin HIGH until it is pressed.
  • Change the wiring to take the pin LOW when the button is pressed (use diagonally opposite pins on the button).
  • Remove the external resistor
  • Change the program logic to test for LOW to detect a button press
Hello I looked into it againg after some time and realised how dumb I am :smile:. When I called the function in Loop I accidently wrote void Button(); instead of Button();. Thank you for your help.
