Thank you very much for this sir.
We actually wanted to comeup with this kind of project.
But our main problem is we are trying to incorporate it with an alarm clock, giving us a lot of limitaions when it comes to programming.
We want to use this program with 6 kinds of different medicines, setting two to three alarms at a time.
my question is how are we going to set two or more alarms at different times at the same time?
Look at the Time library and the code samples that come with it.
If you understand the examples then look at the keypad library and it's examples. http://playground.arduino.cc/Code/Keypad#.UxFuCn-9KSM
In C++ you can compare the current time with time entered in on the key pad and if they are equal you send an output to a pin connected to a piezo speaker.
Of course you need a LCD display to display messages
This will definitely help us alot sir.
We will try to study more and understand this codes
Thank you very much for this..
Any more suggestions and links and tutorials are very much welcome.
I have a question sir
How am i gonna set 2 didderent alarms?
Becuse we need this for our project, example is as follows:
Medicine 1:
00:00 //set the time this medicine is to be taken
Then we have to set 1 more alarm for Medicine 2?:
Medicine 2:
Then to medicine 6
Medicine 6:
we need something like this but we cant figure out how are we going to do this....
thank you guys
You can use a 9 volt battery however, if you don't use power managment it will not last very long, stick with plug in power using a wall wart.
This project is quite complex to start with.
Make sure you master each section and peripheral, otherwise you will end up with a big mess.
Force yourselves to oranize your code into different sections.
Debug and get each section to work perfectly before you proceed to the next bit of code.
For the six or more alarm times use an array(s) that is large enough to hold the maximum number you expect, i.e. If you know you will have no more than 10 alarms make the array size equal to ten.
I would consider using a format such as unix/epoch time to store each alarm but you can use hh: mm:ss
If we are going to usse a wall wart, the projects concept of being a Portable device would be lessen...
But we will surely consider your ideas Sir..
So you are actually telling me that we can set 6 alarms simultaneously???
Yeah its quite a complicated project to start with considering Arduino was just introduced to us last month
We are trying our best to study and practice the said compiler. And we are asking for your guidance in doing so
Sir can you give us a bit of codes on how to set more than 1 alarm???
If you mean can you set more than one alarm from the keypad then YES you can.
I haven't written this code you are looking for and just have access to an iPad for the next week.
It should be very straight forward.
You would enter an alarm time on the keypad and let's say when you press the * key, the alarm is to be processed.
If you want another alarm, you repeat the above.
You could enter 5#142345* which would set alarm 5 to 14:23:45
You could use an array to hold the alarm times let's call it alarmTime[0], alarmTime[1], alarmTime[2] etc.
If you want to clear an alarm you could enter 5## which would delete alarm 5
So its more of like using arrays in Visual Basic?
We will try to study this arrays maybe this week Sir..
Thank you very much for your answers, we really do appreciate them
Hope we can reach to you again anytime
THANKS A LOT Sir!
