I am currently developing an application using uno with the following features to which I am facing difficulty updating the counter values;
GSM sheid is attached to uno.
Photoresistor is attached to digital PIN 7.
Whenever the photoresistor is avoided of light a counter should begin counting infintely and store the value during power cycle.
after every 2 hour the sms should be generated with the finite count of the trigger.
Now the problem is that we are not getting the proper serial output and the sms is generated only for the single trigger per 2 hour.
Please help for the bug in the code.
Also attached below is the sketch;
#include<SoftwareSerial.h>
SoftwareSerial cell(2,3); //Object for GSM soft comm
char data =0; //Char var. for dumping serial stuff
int ledPin = 13; //LED feedback
int switchPin =7; //photodiode input
int val = 0; //var. for pin status
int counter = 0, currentState = 0,previousState = 0; //misc vars.
pinMode(ledPin, OUTPUT); //LED as output
pinMode(switchPin, INPUT); //photodiode as input
Serial.begin(9600); //serial comm init.
cell.begin(9600); //ditto
if(cell.available() > 0)
Serial.write(cell.read()); //verbose for serial
count(); //storing, debouncing and incrementing the photodiode trigger
delay(2 * 60 * 1000); //2 hr delay
gsmsms(); //message seqence
//Blink without Delay skeleton
//4 examples demonstrated
//LED wiring options
//Depending which way your LEDs are wired, uncomment the next line.
//#define PlusEqualsON
#ifdef PlusEqualsON
//wired so +5V turns LED ON
#define ledON HIGH
#define ledOFF LOW
#else
//wired so +5V turns LED OFF
#define ledON LOW
#define ledOFF HIGH
#endif
//switch wiring options
//Depending which way your switches are wired, uncomment the next line.
#define PushEqualsLOW
#ifdef PushEqualsLOW
//pushing the switch makes pin LOW
#define Pushed LOW
#define Released HIGH
#else
//pushing the switch makes pin HIGH
#define Pushed HIGH
#define Released LOW
#endif
unsigned long currentMillis;
unsigned long pin13Millis;
unsigned long pin12Millis;
unsigned long pin11Millis;
unsigned long SwitchMillis;
//if these are not changed in the sketch, they can be const
unsigned long debounceMillis = 100UL; //100ms
unsigned long ledOnTime = 5*1000UL; //5 seconds
byte laststartSwitchState = HIGH;
byte buttonState = HIGH;
byte counter = 0;
//the following are enable/disable flags
//some of these might not be used in this sketch
boolean flag13 = true;
boolean flag12 = true;
boolean flag11 = true;
boolean flag10 = true;
const byte startSwitch = 2; //pushed = LOW
const byte testSwitch = 3; //pushed = LOW
digitalWrite(13,ledOFF);
pinMode(13, OUTPUT);
digitalWrite(12,ledOFF);
pinMode(12, OUTPUT);
digitalWrite(11,ledOFF);
pinMode(11, OUTPUT);
digitalWrite(10,ledOFF);
pinMode(10, OUTPUT);
pinMode(startSwitch, INPUT_PULLUP); //pushed = LOW
pinMode(testSwitch, INPUT_PULLUP); //pushed = LOW
} // >>>>>>>>>>>>>> E N D O F s e t u p ( ) <<<<<<<<<<<<<<<<<
//save the current time
currentMillis = millis();
//************************************* E x a m p l e 1
//toggle pin 13 every 200mS
//has 200ms or more gone by?
if (currentMillis - pin13Millis >= 200UL)
//code here runs every 200ms
//get ready for next iteration
pin13Millis = pin13Millis + 200UL;
//toggle pin 13
digitalWrite(13,!digitalRead(13));
//************************************* E x a m p l e 2
//at power up, pin 12 LED goes ON, after 3 seconds goes OFF and stays OFF
//could be used as a powerup reset signal
if (flag12 == true && currentMillis - pin12Millis <= 3000UL)
//code here runs for 3 seconds after power up, then stops
digitalWrite(12,ledON);
//disable further pin 12 control
flag12 = false;
//************************************* E x a m p l e 3
//if testSwitch is pushed and released
//pin 11 LED goes ON for 5 seconds, then goes OFF
buttonState = digitalRead(testSwitch);
//are we are allowed to check the switch and is it pressed?
if(flag11 == true && buttonState == Pushed)
//enable timing of LED on pin 11
flag11 = false; //false --> timing is enabled
//turn LED ON
digitalWrite(11,ledON);
//record the time LED turned ON
pin11Millis = currentMillis;
//are we allowed and is it time to control pin 11
if (flag11 == false && currentMillis - pin11Millis >= ledOnTime)
//if enabled, code here runs after ledOnTime ms goes by
//allow switch press detection again
flag11 = true; //true --> switch monitoring is enabled
//************************************* E x a m p l e 4
//is it time to check the switches?
//in particular, pushing startSwitch will turn ON/OFF (toggle) an output pin 10
if (currentMillis - SwitchMillis >= debounceMillis)
//code here runs every debounceMillis ms
//get ready for the next iteration
SwitchMillis += debounceMillis;
//go and check the switches
checkSwitches();
//put other non-blocking stuff here
} // >>>>>>>>>>>>>> E N D O F l o o p ( ) <<<<<<<<<<<<<<<<<
// F U N C T I O N S
//****************** c h e c k S w i t c h e s ( ) *********************
//switches are checked every debounceValue milli seconds
//no minimum switch press time is validated with this code (i.e. No glitch filter)
void checkSwitches()
//re-usable for all the switches
boolean thisState;
//************************************* E x a m p l e Push ON push OFF (toggle)
//check if this switch has changed state
thisState = digitalRead(startSwitch);
if (thisState != laststartSwitchState)
//update the switch state
laststartSwitchState = thisState;
//this switch position has changed so do some stuff
//"HIGH condition code"
//switch went from LOW to HIGH
if(thisState == HIGH)
//Do some HIGH switch stuff here
//"LOW condition code"
//switch went from HIGH to LOW
//Do some LOW switch stuff here
digitalWrite(10, !digitalRead(10));
//print number of pushes
counter++;
Serial.println(counter);
} //END of startSwitch code
//similar code for other switches goes here
} //END of checkSwitches()
// E N D O F C O D E
Dear all,
Please find below code for the revised program, but still the output tend to be "Number of Trigger 1".
#include<SoftwareSerial.h> #include <MsTimer2.h>
count();
MsTimer2::set(15000, gsmsms); //New timer liabrary
MsTimer2::start();
Actually, that doesn't add up to two hours. Since the math is done with 16bit ints it rolls over and this ends up equaling something much less than 2 hours if not a negative number.
You don't need a fancy timer that only adds another layer of ccmplexity. First rule of computing: keep it simple. Try something like this (both old_time and new_time are global here):
#define TIME_TO_WAIT (2L * 60L * 1000L )
unsigned long new_time = 0L;
unsigned long old_time = 0L;
(in setup)
new_time = millis(); // number of milliseconds since reboot
old_time = new_time;
(in loop)
if( condition == TRUE )
if( new_time - old_time > TIME_TO_WAIT ) // has enough time passed?
do_stuff();
old_time = new_time; // reset the waiting period
