Hello, I want my string to be printed to my LCD.
In my codes below, (in hyperterminal) whenever I type a character, it will be directly sent to LCD.
For instance, I pressed 'A', the LCD will print 'A'.
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// Buffer to store incoming commands from serial port
String inData;
Serial.println("Serial conection started, waiting for instructions...\n\n");
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("hello, world!");//initial dispaly
while (Serial.available() > 0)
char recieved = Serial.read();
inData += recieved;
// Process message when new line character is recieved
if (recieved == '\n')
Serial.print("\nArduino Received: \n");
Serial.print(inData);
inData = ""; // Clear recieved buffer
myPrint();
void myPrint(){
lcd.begin(16, 2);
// print the number of seconds since reset:
lcd.print(inData);
What I want is this:
Hyperterminal will have to finish me first typing my string (therefore waiting for me til I press return) before
arduino will print the string into my LCD.
I can see that my LCD is blinking so fast, and so I can tell that it refreshes all the time because of the loop function. Please Help.
glenn
I mean, the string(characters) that I have inputted in SerialMonitor/Hyperterminal will be printed to the LCD after I press a return key.
// when characters arrive over the serial port...
if (Serial.available()) {
// wait a bit for the entire message to arrive
delay(100);
// clear the screen
lcd.clear();
// read all the available characters
while (Serial.available() > 0) {
// display each character to the LCD
lcd.write(Serial.read());
This code is from the SERIAL-LCD example from the arduino IDE. It works just the way I wanted (waiting for me to press an enter then print the string to LCD).
But I want the string also to be printed in hyperterminal/serial monitor.
and how can I avoid printing a "special character" at the end of the LCD display? I know this character is caused by an enter key.
ok I got it. sorry for not reviewing my codes before posting:
delay(100);
// clear the screen
lcd.clear();
char rec = Serial.read();
lcd.write(rec);
inData = inData + rec;
But my last question remains. How am I suppose to remove or avoid the special characters in LCD caused by an enter?
Well, it'll either have the value 0x0a, or the value 0x0d, so avoiding printing either of those (or not putting them in your String in the first place) would seem to me to be a good start.
