Hay
I'm also working on a similar project, a bit different. i used 7 LEDs to light up according to the magnetic field strength. but my code seems not working. actually the code itself is something i came up with going through so many examples online. but, still couldn't get it right and struggling so hard. help me.
here's my code
const int numReadings = 40;
int readings[numReadings]; // the readings from the analog input
int readIndex = 0; // the index of the current reading
int total = 0; // the running total
int average = 0; // the average
int hallinputPin = A0;
int LED1 = 2;
int LED2 = 3;
int LED3 = 4;
int LED4 = 5;
int LED5 = 6;
int LED6 = 7;
int LED7 = 8;
// initialize serial communication with computer:
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(A0, INPUT);
// initialize all the readings to 0:
for (int thisReading = 0; thisReading < numReadings; thisReading++) {
readings[thisReading] = 0;
void loop(){
// subtract the last reading:
total = total - readings[readIndex];
// read from the sensor:
readings[readIndex] = analogRead(hallinputPin);
// add the reading to the total:
total = total + readings[readIndex];
// advance to the next position in the array:
readIndex = readIndex + 1;
// if we're at the end of the array...
if (readIndex >= numReadings){
// ...wrap around to the beginning:
readIndex = 0;
// calculate the average:
average = total / numReadings;
if (average >= 4){
average = 5; // max LEDs 7.
if (average <= 1){
average = 1; // 1 the min.
if (average <= 1) {
digitalWrite(LED1, LOW);
digitalWrite(LED2, LOW);
digitalWrite(LED3, LOW);
digitalWrite(LED4, LOW);
digitalWrite(LED5, LOW);
digitalWrite(LED6, LOW);
digitalWrite(LED7, LOW);
delay(500); // half a second for stability
if (average >= 1.01 && average <= 1.50) {
digitalWrite(LED1, HIGH);
if (average >= 1.51 && average <= 2) {
digitalWrite(LED2, HIGH);
if (average >= 2.01 && average <= 2.50) {
digitalWrite(LED3, HIGH);
if (average >= 2.51 && average <= 3) {
digitalWrite(LED4, HIGH);
if (average >= 3.1 && average <= 3.50) {
digitalWrite(LED5, HIGH);
if (average >= 3.51 && average <= 3.999) {
digitalWrite(LED6, HIGH);
if (average >= 4 ) {
digitalWrite(LED7, HIGH);
And also i came up with another code just in case. I acually dont know what instructions to give. this is my first project and i'm stuck with this for weeks.
int hallPin =A0;
int LED1 = 2;
int LED2 = 3;
int LED3 = 4;
int LED4 = 5;
int LED5 = 6;
int LED6 = 7;
int LED7 = 8;
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(A0, INPUT);
int val =analogRead(hallPin);
if (val <= 8) {
if (val >= 9 && val <= 16) {
if (val >= 17 && val <= 32) {
if (val >= 33 && val <= 64) {
if (val >= 65 && val <= 128) {
if (val >= 129 && val <= 256) {
if (val >= 257 && val <= 512) {
if (val >= 513 ) {
