Hi all,
I've been coding arduino for about a year. It is not for work, just a passion. Today I've decided that it was time to start using EEPROM memory. So I wrote this simple code. Basically you can input a command via serial, arduino process it. Commands are write, read, erase, read_all, erase_all. I'm posting it here because I got an unexpected behaviour: when I type WRITE then IP (write for 15 chars starting from 0) it writes also the 1024 EEPROM slot.
I'd like also to receive advices to improve it.
Thank you.
PS: I tried to comment it so you can understand it better.
#include <EEPROM.h>
#define ALLOCATED_BUFFER 20
void serial_read() {
if (Serial.available()) {
static int length = 0;
static char buffer[ALLOCATED_BUFFER];
static int type = 0;
static int info = 0;
char r = Serial.read();
if (r == '\r' ) { //only cares bout \r end of line, handle!
if (type == 0) {
Serial.print(F("Command: "));
Serial.println(buffer);
} else if (info == 0) {
Serial.print(F("Data: "));
if (strstr(buffer,"DATES")) { //List
Serial.println(F("************************************\n"));
Serial.println(F("IP <===> max 15 char"));
Serial.println(F("NAME <===> max 15 char"));
Serial.println(F("\n***************END**************************"));
}else if (strstr(buffer, "HELP")) { // List commands
Serial.println(F("********************************************\n"));
Serial.println(F("DATES <===> List available dates"));
Serial.println(F("ERASE <===> Delete that date"));
Serial.println(F("ERASE_ALL <===> Delete all memory"));
Serial.println(F("READ <===> Read that date"));
Serial.println(F("READ_ALL <===> Read all memory"));
Serial.println(F("WRITE <===> Write that date"));
} else if (strstr(buffer, "ERASE_ALL")) { // Erase all memory
eeprom_erase_all();
} else if (strstr(buffer, "READ_ALL")) { // Read all
eeprom_read_all();
} else if(strstr(buffer, "WRITE")) { // Write info
type = 1;
Serial.println(F("What do you want to write?"));
} else if (strstr(buffer, "READ")) { // Read info
type = 2;
Serial.println(F("What do you want to read?"));
} else if (strstr(buffer, "ERASE")) { // Erase info
type = 3;
Serial.println(F("What do you want to erase?"));
} else if (type != 0) { // get info
if (info == 0) {
if (strstr(buffer, "IP")) { // 1 = IP
switch (type) {
case 1:
Serial.println(F("Type data"));
info = 1;
case 2:
Serial.println(eeprom_reader(1));
type = 0;
info = 0;
case 3:
eeprom_erase(1);
Serial.println(F("Erased successfully"));
type = 0;
info = 0;
default:
} else if (strstr(buffer, "NAME")) { // 2 = NAME
switch (type) {
case 1:
info = 2;
case 2:
Serial.println(eeprom_reader(2));
type = 0;
info = 0;
case 3:
eeprom_erase(2);
type = 0;
info = 0;
default:
}else {
Serial.println(F("Not valid data, abort"));
type = 0;
info = 0;
eeprom_writer(info, buffer);
Serial.println(F("Written successfully"));
type = 0;
info = 0;
Serial.println(F("Not a valid command"));
type = 0;
info = 0;
length = 0;
} else if (r == '\n') { //don't care about \n
return;
} else if (length < ALLOCATED_BUFFER) {
buffer[length] = r;
length++;
buffer[length] = 0;
int data_length_ (int info) {
switch (info) {
case 1: //IP
return 15;
case 2:
return 15; // NAME
default:
return 0;
int data_init_ (int info) {
switch (info) {
case 1: //IP
return 0;
case 2: //NAME
return 15;
default:
return 0;
char* eeprom_reader(int info) {
int data_init = data_init_(info);
int data_length = data_length_(info);
char* buf = (char *) malloc (ALLOCATED_BUFFER);
buffer[0] = '\0';
if (data_length != 0) {
// time to read
for (int x = 0; x < data_length; x++) {
//read each character and add to buffer
char ch = EEPROM.read(x + data_init);
buffer[x] = ch;
buffer[x + 1] = '\0';
//read complete :)
strcpy (buf, buffer);
return buf;
void eeprom_writer(int info, char text[ALLOCATED_BUFFER]) {
//write each character
EEPROM.update((x + data_init), text[x]);
void eeprom_erase(int info) {
//write each null
EEPROM.update((x + data_init), '\0');
void eeprom_erase_all() {
for (int x = 0; x < 1025; x++) {
//write each null
EEPROM.update((x), '\0');
Serial.println("Deleted all memory");
void eeprom_read_all () {
//read each
Serial.print(F("#"));
Serial.print(x);
Serial.print(F("="));
Serial.println((char)EEPROM.read(x));
Serial.println(F("Ready! :)"));
Serial.println(F("Type HELP for help"));
serial_read();
