Help understanding this code for. checking buttons
From this post
I saw this little snippet
byte button[] = {30, 26, 28, 32};
byte numberOfButtons = 4;
byte buttonState[numberOfButtons];
byte activeButton[numberOfButtons];
boolean hit;
  for (byte i = 0; i < numberOfButtons; i++)
    pinMode(button[i], INPUT_PULLUP);  //Check for LOW for a button press
  for (byte i = 0; i < numberOfButtons; i++) //read all buttons at beginning of loop()
    buttonState[i] = !digitalRead(button[i]);
    if (buttonState[i] && (!otherButtonPressed(i) || activeButton[i]))  //if no other buttons are active or this one is already active
      activeButton[i] = true;
      Serial.print(i+1);
      activeButton[i] = false;
boolean otherButtonPressed(byte currentButton)
  hit = 0;
    if (i == currentButton)
      continue; // skip test for button passed to function
    if (activeButton[i] == HIGH)  // if any other button is currently the active one
      hit = true;
  return hit;  //Were any other buttons already pressed?
Why does he use byte arrays? The first array ,button[] , is a set of integers so shoudnt it be an int array?
The he declares the number of buttons as a byte. Shouldnt it be an integer?
Then buttonState is a byte array but he sets button state to the output of digitalRead. I thought digitalRead returns high or low. Is that a boolean value?
Then the activeButton array is also declared as a byte array . But later in the code he sets it to true or false. Isnt that a boolean?
I am quite confused by the use of byte in the declaration of variables.
And in his main loop he has this statement:
How can he use the value of activeButton[i] before it is ever initialized or set?
Finally, dont I have to worry about 'debouncing' and add delays?
As you might imagine, I am trying to write code to efficiently monitor momentary button presses and happened across this code in my research.
byte is an 8 bit integer
int is a 16 bit integer with sign
uses hardcoded numbers that fit into an 8-bit variable. 8 bit = values between 0 and 255 (2^8 - 1)
digitalread results the number 0 or the number 1
code a
serial.println(digitalRead(2) );
"LOW" and "HIGH" are constants representing 0 and 1
"LOW" and "HIGH" are not an extra data-type
any expression inside an if-condition that results in a nonzero-value are seen as "true"
if(2) is the same as if(true)
if(100) is the same as if(true)
if(0) is the same as if(false)
unsigned long a = 11;
byte b = 10;
if( a - b)     // results in true  because the mathematical result is 1
global variables are initialised to zero automatically
best regards Stefan
Hello skypickle
Generaly spoken:
Sometimes it is helpful and useful to read, study and understand the Arduino instruction set. Aspecially to have a view to return values given.
eg
A digitalRead() returns an either a HIGH or LOW using the datatype INT.
In this way you can check the complete sketch by yourself.
Дайте миру шанс!
p.s.
None published sketch is errorless.
please tell me what is the error inside this sketch ?
Stefan, thank you. Clearly you see I am a beginner and I appreciate the time you took to help. Reminds me of an earlier internet when people were kind
certainly a confusing piece of code. could be clearer if avoiding multiple button presses
consider
// check multiple buttons and toggle LEDs
enum { Off = HIGH, On = LOW };
byte pinsLed [] = { 10, 11, 12 };
byte pinsBut [] = { A1, A2, A3 };
#define N_BUT   sizeof(pinsBut)
byte butState [N_BUT];
int
chkButtons ()
    for (unsigned n = 0; n < sizeof(pinsBut); n++)  {
        byte but = digitalRead (pinsBut [n]);
        if (butState [n] != but)  {
            butState [n] = but;
            delay (10);     // debounce
            if (On == but)
                return n;
    return -1;
void
loop ()
    switch (chkButtons ())  {
    case 2:
        digitalWrite (pinsLed [2], ! digitalRead (pinsLed [2]));
    case 1:
        digitalWrite (pinsLed [1], ! digitalRead (pinsLed [1]));
    case 0:
        digitalWrite (pinsLed [0], ! digitalRead (pinsLed [0]));
void
setup ()
    Serial.begin (9600);
        pinMode (pinsBut [n], INPUT_PULLUP);
        butState [n] = digitalRead (pinsBut [n]);
    for (unsigned n = 0; n < sizeof(pinsLed); n++)  {
        digitalWrite (pinsLed [n], Off);
        pinMode      (pinsLed [n], OUTPUT);
