hello, i want to use the deumilanove to program the IC atmega328 but then i want only to use the IC without the board. Here is an exemple, imagine you want to blink a led, you program the IC with the board and then you take just the IC and built a circuit with the led and the IC, is this possible? And what about the 16Mhz crystal? Do i need it? How do i do this?
Yes, that is a very common thing to do. There is a lot of information avalible if you search the forum for 'standalone'. Here is an artical on how to set up a standalone on a solderless breadboard:
you will see there are two versions, one using an arduino board and the other being stand alone. You can see what you need to add over and above the board from this.
