Help with -80 Freezer Monitor Project
Hi I am a researcher at The University of Washington,
Was wondering if anybody would know how to code an arduino to read the input of an lcd screen line? Our labs have all these -80 freezers with important samples in them but we do not have enough staff resources to keep track of all of them with everybody at home. I thought a decent approach would be to put uno wifi inbetween the fridges output to the LCD screen showing the temp so that the uno could get temp information and post it to a website that we can monitor remotely.
*edit
To clarify the freezers have temp sensors. They post readings to an LCD screen. Easiest way to highjack reading would be to read freezer output to its LCD screen showing temp. Then post that reading via wifi to a UI for people to check on from time to time.
This shouldn't be complicated project in principle. There are plenty similar projects presented on the web.
However, I see the temperature sensor as challenge. I'm supposing -80 in Fahrenheit. It is about -62 deg in Celsius. Still, I do not know about sensor be able to measure it reliably.
If they're commercial devices, it is unlikely that the protocol for the display is easily hackable,
Antes de hacer nada con Arduino, asegúrese de que se puede homologar en su país, en España, ya ha habido varias iniciativas que no se han podido llevar a cabo por los problemas de homologación, se han hecho respiradores, pantallas de protección, y un sinfín de productos que en un principio se pueden utilizar para ayudar en esta emergencia, pero sin embargo cuando se ha intentado entregar, lo primero que se ha pedido es el certificado de homologación, y el certificado de poder utilizarse en la Unión Europea, sin estos documentos, todo el esfuerzo en hacer el proyecto, ha ido directamente a la basura, ( o por lo menos eso han dicho), porque se quedan con el material, requisado, para que no se pueda vender.
Por ejemplo, en España, ha habido un grupo de personas que tenían impresoras 3D, y se han puesto a imprimir pantallas de protección, han conseguido 5.000 unidades en una semana, las han levado a un Hospital de Madrid, y las han rechazado, por no estar homologadas.
En este momento, solo las empresas autorizadas por los distintos gobiernos, son las que únicamente pueden hacer este tipo de productos, por ejemplo General Motors, en Estados Unidos, SEAT, en España, y siempre después de pasar los controles de homologación.
La intención es buena, pero en la mayoría de los casos, está condenada al fracaso por la burocracia de los distintos países, y los distintos intereses económicos alrededor de ese producto.
Tenga en cuenta que cada respirador que se utiliza en una Unidad de Cuidados Intensivos UCI, vale en el mercado entre 25.000 y 30.000 Euros, al cambio entre más o menos 24.000 y 29.000 Dólares USA, cuando el coste real con motores reutilizados y Arduino, no llega a los 200 € ninguno de los proyectos que se han construido en casa, con toda la buena intención, los dejan utilizar en los hospitales, por lo menos en Europa
Before doing anything with Arduino, make sure that it can be approved in your country, in Spain, there have already been several initiatives that have not been carried out by the problems of type-approval, have become respirators, screens of protection, and a host of products that in a principle can be used to assist in this emergency, but however when attempted to deliver, the first thing that has been requested is the approval certificate, and the certificate of being able to be used in the European Union, without these documents, all the effort in doing the project, it has gone straight to the trash, (or at least that's what they've said), because they keep the material, requisitioned, so that it can't be sold.
For example, in Spain, there has been a group of people who had 3D printers, and they have started printing screens of protection, they have obtained 5,000 units in a week, taken them to a Hospital in Madrid, and rejected them, because they were not approved.
At this time, only companies authorized by the different governments, are those that can only make this type of products, for example General Motors, in the United States, SEAT, in Spain, and always after passing the approval checks.
The intention is good, but in most cases, it is doomed to failure by the bureaucracy of the different countries, and the different economic interests around that product.
Please note that each respirator that is used in an ICU Intensive Care Unit, is valid on the market between 25,000 and 30,000 Euros, when the change between about 24,000 and 29,000 US Dollars, when the actual cost with repurposed engines and Arduino, does not reach 200 none of the projects that have been built at home, with all the good intentions, let them use them in hospitals, at least in Europe
That is a self issued certificate by the manufacturer, that is you. Basically it is a declaration of CE conformity. There is no need to get anything tested by an external body. You only commit an offence if it is tested by an external test house and found not to comply. Someone has to pay for that which is not you.
So print out your own CE conformance certificates and show them that.
maybe this links will help related the following quotes :
Cheers,
niel
Good morning.
I'm not going to get into legal discussions, since each country applies the rules in one way, and in the USA, it's every state that has the skills for that, all I intend to do is help you not waste time and work, developing a project , so that, because of legal problems, they do not allow you to use it.
A greeting
You started it.
The EU has the same approval rules for all. They are stupid and is one of the reasons the UK is leaving it.
No the USA has one unified federal system.
Oh dear god! Another one who knows it better. Have you read this statement after yourself?
I am sorry it is out of topic context but anyway...
Not all EU rules are stupid, just some of them. Those not based on scientific evidence are stupid and are at the behest of large industry lobbying.
