Help with a hall sensor
Hi
I need a hall sensor that works on 3.3v.
My default A3144 is a 5v device and I don't have 5v on the PCB.
So, I found these TLE4906LHALA1 hall sensors and grabbed a couple for testing.
Nope...
I thought they would output OV when the magnetic field was present, but the output pin sits at about 2.6v and drops about 0.6v when a field is moved near it - not enough for an Arduino to detect.
A pullup makes no difference. 10K on the output to 3.3v does not pull the output up (or change upon a magnetic field).
Any ideas?
Either what I am doing wrong, or more likely that they are not suitable.
But I have not yet found another 3.3v option (just need a sensor in 3 lead style - not a whole breakout PCB).
Device pretty simple, under no circumstances should you see what you're seeing. My bet is, incorrect measurement technique or incorrect wiring. Suggest you try again.
Sensor package type: PG-SSO-3-2.
If you are using an Arduino UNO, then connect 5V-point of UNO with Vs-pin (Pin-1) of the sensor. Connect a 5k pullup resistor with Q-pin (Pin-2). Now, operate the sensor and see the voltage swing at the output of the sensor. Report the result.
Arduino UNO will detect as low as 3.0V as logic HIGH (VIH, Fig-1) and will detect as high as 1.0V as logic LOW (VIL, Fig-1). Values beyond these two boundaries fall in the forbidden zone.
NOPE.....
The datasheet is wrong
VCC | GND | OUT
After 10 minutes faffing around, I took a stab at the datasheet being wrong and indeed it works fine when Pin 1 = 3.3v, Pin 2 = GND and pin 3 = Out.
What uses is a datasheet if it's incorrect
So basically the same as a 5v A3144. Lucky I didn't design a PCB for this
Post the picture of the sensor you are using so that we can see the package type.
Apparently INFINEON are shockers for changing their pinouts and not updating the sheets
But that is exactly what the datasheet says!
Yep - I just looked and the datasheet I download from a different supplier is a much older version. That has the pinout as I stated at the start.
That Digikey datasheet is newer and correct.
Note to self. Always check the datasheet version
It's the one you gave in post #1
maybe... : )
