Help with a selfmade keyboard
Hallo together,
I built a keyboard myself. I got the code from the Internet and reworked it a bit because I still connected a display and LEDs. The keyboard works well when typing. But not with video games if you want to run with it (WASD). Is it up to the library, the command Keyboard.press (); or only the game?
(I know the code is a bit cumbersome)
Any support would be great. Many Thanks
(I deleted the code for the leds and the display because it would then be confusing)
#include <Keyboard.h>
int wort;
int esc = 0;
int zuruck = 0;
int tab = 0;
int capslock = 0;
int enter = 0;
int shiftlinks = 0;
int shiftrechts = 0;
int ctrllinks = 0;
int windowslinks = 0;
int altlinks = 0;
int leerzeichen = 0;
int altrechts = 0;
int windowsrechts = 0;
int ctrlrechts = 0;
int longPressDelay = 350;
int spamSpeed = 15;
byte inputs[] = {22, 21, 20, 19, 18, 17, 16, 15, 14, 13, 12, 11, 10, 9, 8, 7};
#define inCount sizeof(inputs)/sizeof(inputs[0])
byte outputs[] = {6, 5, 4, 38, 39};
#define outCount sizeof(outputs)/sizeof(outputs[0])
char layout[5][15] = {
  {1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15},
  {16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30},
  {31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45},
  {46, 47, 48, 49, 50, 51, 52, 53, 54, 55, 56, 57, 58, 59, 60},
  {61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75},
int keyDown[outCount][inCount];
bool keyLong[outCount][inCount];
  for (int i = 0; i < outCount; i++) {
    pinMode(outputs[i], OUTPUT);
    digitalWrite(outputs[i], HIGH);
  for (int i = 0; i < inCount; i++) {
    pinMode(inputs[i], INPUT_PULLUP);
  Serial.println("verbunden");
  Keyboard.begin();
    digitalWrite(outputs[i], LOW);
    delayMicroseconds(5);
    for (int j = 0; j < inCount; j++)
      if (digitalRead(inputs[j]) == LOW)
        keyPressed(i, j);
      else if (keyDown[i][j] != 0)
        resetKey(i, j);
    delayMicroseconds(500);
void keyPressed(int row, int col) {
  Serial.print("Output: ");
  Serial.print(row);
  Serial.print(" Input: ");
  Serial.print(col);
  Serial.print(" ");
  Serial.println(layout[row][col]);
  if (layout[row][col] == 2) {   //1
    Serial.println("1");
    wort = 49;
  if (layout[row][col] == 3) {   //2
    Serial.println("2");
    wort = 50;
  if (layout[row][col] == 4) {   //3
    Serial.println("3");
    wort = 51;
  if (layout[row][col] ==  5) {   //4
    Serial.println("4");
    wort = 52;
  if (layout[row][col] == 6) {  //5
    Serial.println("5");
    wort = 53;
  if (layout[row][col] == 7) { //6
    Serial.println("6");
    wort = 54;
  if (layout[row][col] == 8) { //7
    Serial.println("7");
    wort = 55;
  if (layout[row][col] == 9) {  //8
    Serial.println("8");
    wort = 56;
  if (layout[row][col] == 10) {  //9
    Serial.println("9");
    wort = 57;
  if (layout[row][col] == 11) {  //0
    Serial.println("0");
    wort = 48;
  if (layout[row][col] ==  12) {  //ß
    Serial.println("ß");
  if (layout[row][col] ==  13) {  //^
    Serial.println("^");
    wort = 94;
  if (layout[row][col] == 18) {  //q
    Serial.println("q");
    wort = 113;
  if (layout[row][col] == 19) {  //w
    Serial.println("w");
    wort = 119;
  if (layout[row][col] == 20) {  //e
    Serial.println("e");
    wort = 101;
  if (layout[row][col] ==  21) {  //r
    Serial.println("r");
    wort = 114;
  if (layout[row][col] == 22) {
    Serial.println("t");    //t
    wort = 116;
  if (layout[row][col] ==  23) {  //z
    Serial.println("z");
    wort = 122;
  if (layout[row][col] == 24) {  //u
    Serial.println("u");
    wort = 117;
  if (layout[row][col] == 25) {  //i
    Serial.println("i");
    wort = 105;
  if (layout[row][col] == 26) {  //o
    Serial.println("o");
    wort = 111;
  if (layout[row][col] == 27) {  //p
    Serial.println("p");
    wort = 112;
  if (layout[row][col] == 28) {  //ü
    Serial.println("ü");
    wort = 129;
    altlinks = 10;
  if (layout[row][col] ==  29) {  //+
    Serial.println("+");
    wort = 43;
  if (layout[row][col] ==  30) {  //-
    Serial.println("-");
    wort = 45;
  if (layout[row][col] == 33) {  //a
    Serial.println("a");
    wort = 97;
  if (layout[row][col] == 34) {  //s
    Serial.println("s");
    wort = 115;
  if (layout[row][col] == 35) {  //d
    Serial.println("d");
    wort = 100;
  if (layout[row][col] == 36) {  //f
    Serial.println("f");
    wort = 102;
  if (layout[row][col] ==  37) {  //g
    Serial.println("g");
    wort = 103;
  if (layout[row][col] == 38) {  //h
    Serial.println("h");
    wort = 104;
  if (layout[row][col] == 39) {  //j
    Serial.println("j");
    wort = 106;
  if (layout[row][col] == 40) {  //k
    Serial.println("k");
    wort = 107;
  if (layout[row][col] == 41) {  //l
    Serial.println("l");
    wort = 108;
  if (layout[row][col] ==  42) {  //ö
    Serial.println("ö");
    wort = 148;
    altlinks = 10;
  if (layout[row][col] == 43) {  //ä
    Serial.println("ä");
    wort = 132;
    altlinks = 10;
  if (layout[row][col] == 49) {  //<
    Serial.println("y");
    wort = 121;
  if (layout[row][col] == 48) {  //<
    Serial.println("<");
    wort = 60;
  if (layout[row][col] == 50) {    //x
    Serial.println("x");
    wort = 120;
  if (layout[row][col] == 51) {  //c
    Serial.println("c");
    wort = 99;
  if (layout[row][col] == 52) {  //v
    Serial.println("v");
    wort = 118;
  if (layout[row][col] ==  53) {  //b
    Serial.println("b");
    wort = 98;
  if (layout[row][col] ==  54) {  //n
    Serial.println("n");
    wort = 110;
  if (layout[row][col] ==  55) {  //m
    Serial.println("m");
    wort = 109;
  if (layout[row][col] == 56) {  //,
    Serial.println(",");
    wort = 44;
  if (layout[row][col] == 57) {  //.
    Serial.println(".");
    wort = 46;
  //macros
  if (row == 2 && col == 15) {  //makro1: Ctrl+v
    Serial.println("marko1");
    Keyboard.press(KEY_LEFT_CTRL);
    Keyboard.press('v');
    Keyboard.releaseAll();
    delay(350);
  if (row == 1 && col == 15) {  //makro2: Ctrl+c
    Serial.println("marko2");
    Keyboard.press('c');
    delay(350);
  if (row == 3 && col == 15) {  //makro4:  Windows+G (Xbox app)
    Serial.println("makro4");
    Keyboard.press(KEY_LEFT_GUI);
    Keyboard.press('g');
  if (row == 4 && col == 15) {  //makro3: Alt+y  (Disord mute)
    Serial.println("makro3");
    Keyboard.press(KEY_LEFT_ALT);
    Keyboard.press('Y');
  //funktionen
  if (row == 0 && col == 0) {   //ESC
    Serial.println("ESC");
    esc = 10;
  if (row == 0 && col == 14) {  //zurück
    Serial.println("zurück");
    zuruck = 10;
  if (row == 1 && col == 0) {  //Tab
    Serial.println("tab");
    tab = 10;
  if (row == 2 && col == 0) {  //caps lock
    Serial.println("caps lock");
    capslock = 10;
  if (row == 2 && col == 13) {  //enter
    Serial.println("Enter");
    enter = 10;
  if (row == 3 && col == 1) {  //Shift links
    shiftlinks = 10;
  if (row == 3 && col == 13) {  //Shift rechts
    Serial.println("rechts shift");
    shiftrechts = 10;
  if (row == 4 && col == 0) {  //CTRL links
    Serial.println("ctrl links");
    ctrllinks = 10;
  if (row == 4 && col == 1) {  //windows taste links
    Serial.println("windows taste");
    windowslinks = 10;
  if (row == 4 && col == 3) {  //alt links
    Serial.println("alt links");
    altlinks = 10;
  if (row == 4 && col == 6) {  //space
    Serial.println("leerzeichen");
    leerzeichen = 10;
  if (row == 4 && col == 10) {  //alt rechts
    Serial.println("rechts alt");
    altrechts = 10;
  if (row == 4 && col == 11) {  //windows taste rechts
    windowsrechts = 10;
  if (row == 4 && col == 14) {  //ctrl rechts
    ctrlrechts = 10;
  if (keyDown[row][col] == 0) {
    if (esc == 10) {
      Keyboard.press(KEY_ESC);
      esc = 0;
      delay(50);
    if (zuruck == 10) {
      Keyboard.press(KEY_BACKSPACE);
      zuruck = 0;
      delay(50);
    if (tab == 10) {
      Keyboard.press(KEY_TAB);
      tab = 0;
      delay(50);
    if (capslock == 10) {
      Keyboard.press(KEY_CAPS_LOCK);
      capslock = 0;
      delay(50);
    if (enter == 10) {
      Keyboard.press(KEY_ENTER);
      enter = 0;
      delay(50);
    if (shiftlinks == 10) {
      Keyboard.press(KEY_LEFT_SHIFT);
      shiftlinks = 0;
      delay(50);
    if (shiftrechts == 10) {
      Keyboard.press(KEY_RIGHT_SHIFT);
      shiftrechts = 0;
      delay(50);
    if (ctrllinks == 10) {
      ctrllinks = 0;
      delay(50);
    if (windowslinks == 10) {
      windowslinks = 0;
      delay(50);
    if (altlinks == 10) {
      altlinks = 0;
      delay(50);
    if (leerzeichen == 10) {
      Keyboard.press(32);
      leerzeichen = 0;
      delay(50);
    if (altrechts == 10) {
      Keyboard.press(KEY_RIGHT_ALT);
      altrechts = 0;
      delay(50);
    if (windowsrechts == 10) {
      Keyboard.press(KEY_RIGHT_GUI);
      windowsrechts = 0;
      delay(50);
    if (ctrlrechts == 10) {
      ctrlrechts = 0;
      delay(50);
    Keyboard.press(wort);
    Serial.println(wort);
  else if (keyLong[row][col] && keyDown[row][col] > spamSpeed) {
    if (esc == 10) {
      esc = 0;
    if (zuruck == 10) {
      zuruck = 0;
    if (tab == 10) {
      tab = 0;
      capslock = 0;
    if (enter == 10) {
      enter = 0;
      shiftlinks = 0;
      shiftrechts = 0;
      ctrllinks = 0;
      windowslinks = 0;
      altlinks = 0;
      Keyboard.press(32);
      leerzeichen = 0;
      altrechts = 0;
      windowsrechts = 0;
      ctrlrechts = 0;
    keyDown[row][col] = 1;
  else if (keyDown[row][col] > longPressDelay) {
    keyLong[row][col] = true;
  keyDown[row][col]++;
void resetKey(int row, int col) {
  keyDown[row][col] = 0;
  keyLong[row][col] = false;
  wort = 0;
  esc = 0;
  zuruck = 0;
  tab = 0;
  capslock = 0;
  enter = 0;
  shiftlinks = 0;
  shiftrechts = 0;
  ctrllinks = 0;
  windowslinks = 0;
  altlinks = 0;
  leerzeichen = 0;
  altrechts = 0;
  windowsrechts = 0;
  ctrllinks = 0;
What do you mean "run with it"? I guess running with a keyboard is less dangerous than running with scissors, but I still would not recommend it! What do you mean by WASD? It seems to be the name of a manufacturer of some quite expensive keyboards.
Is what up to the library? This running idea? I think that is up to your legs!
More than a bit! Would you like some suggestions?
I will try to guess what your problem is. You want the PC to receive key release events? You should use Keyboard.release() for each key, not Keyboard.releaseAll() when any key is released.
"run with it" means "run it with". Please try to accommodate people whose first language is not English.
WASD refers to 4 keys that are often used on a standard keyboard as inputs for up, left, down and right
Rather than 57 of these:
You could use two arrays for the names and the values for each key.
You don't really need the array for "layout[row][col]" because the answer is just "(row*15+col+1)".
Electrons respond in nanoseconds so you don't need the 'delayMicroseconds()' calls in your keyboard scanning.
Sorry for the misunderstanding. My problem is that for example when I want to move in minecraft (video game) the game doesnt react to the key when I press the letter keys to move (with the letters W A S D you move in the most video games: W forward, A left, S backwards, D right). But when I'm typing in the browser every key is working.
Sometimes Keyboard.write() causes problems because it does Keyboard.press() immediately followed by Keyboard.release(). It might help your game to use .press() and .release() with a very short delay between (like a few milliseconds).
thank you, your suggestion has been right!
Now it works :grinning:
