Essentially I have a simple web server based on getting input by appending to the URL.
Depending on the input a different lighting function will happen.
I found however, if I ran an 'If' the lighting function would happen once, in this case the rainbow cycle cycles through the colour wheel 5 times, due to the line 256*5, then stops.
Therefore I ran a while however in this the lights continually stay on and input from the web server are neglected. I don't understand why the while is reacting like this as it is
while (currentLine.endsWith("GET /RC")) {
rainbowCycle(5);
so it should stop once the input changes, also this is within another loop that happens while the client is connected.
If you can think of a solution it'd be much appreciated as I believe it is a simple fix, I just don't know in which way to do so.
Here's the whole code:
#include <WiFi.h>
#ifdef __AVR__
#include <avr/power.h>
#endif
#define PIN 13
#define NUM_LEDS 300
Adafruit_NeoPixel strip(NUM_LEDS, PIN, NEO_GRB + NEO_KHZ800);
#define DELAYVAL 500
void showStrip() {
#ifdef ADAFRUIT_NEOPIXEL_H
// neopixel
strip.show();
#endif
#ifndef ADAFRUIT_NEOPIXEL_H
// fastlED
FastLED.show();
#endif
void setPixel(int Pixel, byte red, byte green, byte blue) {
// NeoPixel
strip.setPixelColor(Pixel, strip.Color(red, green, blue));
#endif
// FastLED
leds[Pixel].r = red;
leds[Pixel].g = green;
leds[Pixel].b = blue;
#endif
void setAll(byte red, byte green, byte blue) {
for(int i = 0; i < NUM_LEDS; i++ ) {
setPixel(i, red, green, blue);
showStrip();
void rainbowCycle(int SpeedDelay) {
byte *c;
uint16_t i, j;
for(j=0; j<256*5; j++) {
for(i=0; i< NUM_LEDS; i++) {
c=Wheel(((i * 256 / NUM_LEDS) + j) & 255);
setPixel(i, *c, *(c+1), *(c+2));
strip.setBrightness(255);
showStrip();
delay(SpeedDelay);
byte * Wheel(byte WheelPos) {
static byte c[3];
if(WheelPos < 85) {
c[0]=WheelPos * 3;
c[1]=255 - WheelPos * 3;
c[2]=0;
} else if(WheelPos < 170) {
WheelPos -= 85;
c[0]=255 - WheelPos * 3;
c[1]=0;
c[2]=WheelPos * 3;
WheelPos -= 170;
c[0]=0;
c[1]=WheelPos * 3;
c[2]=255 - WheelPos * 3;
return c;
const char* ssid = "BT-TGAHZR";
const char* password = "beqxyVRt6cGng7";
WiFiServer server(80);
pinMode(5, OUTPUT);
delay(10);
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected.");
Serial.println("IP address: ");
server.begin();
strip.begin();
int value = 0;
void loop(){
WiFiClient client = server.available();
if (client) {
Serial.println("New Client.");
String currentLine = "";
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
if (c == '\n') {
if (currentLine.length() == 0) {
client.println("Content-type:text/html");
client.println();
client.print("Click <a href=\"/N\">here</a> to Neophase.<br>");
client.print("Click <a href=\"/R\">here</a> to Running Lights.<br>");
client.print("Click <a href=\"/RC\">here</a> to Rainbow Cycle.<br>");
client.print("Click <a href=\"/L\">here</a> to turn off.<br>");
client.println();
currentLine = "";
} else if (c != '\r') {
currentLine += c;
rainbowCycle(5);
if (currentLine.endsWith("GET /L")) {
setAll(0,0,0);
client.stop();
Serial.println("Client Disconnected.");
