Help with air ride code....
Fair warning this is my first code that i have written. When i load this code on the Arduino and have it running through my LCD it runs fine for a little bit, then all of a sudden it seems like it jumps out of the loop and then starts doing whatever it wants. Did i miss something in my code. Any help/input would be great. Thank you in advance. I haven't hooked all the wires to the arduino yet, just the LCD serial wires.
//Read air pressure in air bags, 4 air pressure sensors on analog pins 0-3
//2 tank sensors connected to analog pins 4,5
//Air ride control unit attached to digital pin 13-6
//2 Push buttons connected digital Pins 2,3 to interrupt and clear display for upper and lower tank
//2 Push buttons connected digital Pins 5,4 to set ride heights
//Uses moderndevice 20x4 LCD screen
const int psisensor1 = 0;    //Set LF Bag sensor input on Analog port 0
const int psisensor2 = 1;    //Set RF Bag Sensor input on Analog port 1
const int psisensor3 = 2;    //Set LR Bag Sensor input on Analog port 2
const int psisensor4 = 3;    //Set RR Bag Sensor input on Analog port 3
const int tank1sensor = 4;   //Set Upper Tank Sensor input on Analog port 4
const int tank2sensor = 5;   //Set Lower Tank Sensor input on Analog Port 5
int sensor1val = 0;          //Set LF Bag sensor to 0 value
int sensor2val = 0;          //Set RF Bag sensor to 0 value
int sensor3val = 0;          //Set LR Bag Sensor to 0 value
int sensor4val = 0;          //Set RR Bag Sensor to 0 value
int tank1val = 0;            //Set Upper Tank sensor to value 0
int tank2val = 0;            //Set Lower Tank sensor to value 0
int press1 = 0;
int press2 = 0;
int press3 = 0;
int press4 = 0;
volatile int tank1pres = 0;    //Set tank 1 pressure to 0
volatile int tank2pres = 0;    //Set tank 2 pressure to 0
const int lfupPin = 13;        //LF Bag fill solenoid to Digital Pin 13
const int lfdownPin = 12;      //LF Bag release solenoid to Digital Pin 12
const int rfupPin = 11;        //RF Bag fill solenoid to Digial Pin 11
const int rfdownPin = 10;      //RF Bag release solenoid to Digital Pin 10
const int lrupPin = 9;         //LR Bag fill solenoid to Digital Pin 9
const int lrdownPin = 8;       //LR Bag release solenoid to Digital Pin 8
const int rrupPin = 7;         //RR Bag fill solenoid to Digital Pin 7
const int rrdownPin = 6;       //RR Bag release solenoid to Digital Pin 4
const int upbuttonPin = 5;     //Push button to put car at highes level on Digital Pin 5
const int ridebuttonPin = 4;   //Push button to put car at ride height on Digital Pin 4
int upbuttonState = LOW;         // the current state of the output pin
int button1State;             // the current reading from the input pin
int lastButton1State = HIGH;   // the previous reading from the input pin
int ridebuttonState = LOW;
int button2State;
int lastbutton2State = HIGH;
long lastDebounceTime = 0;
long debounceDelay = 50;
  attachInterrupt(0, tank1, CHANGE);
  attachInterrupt(1, tank2, CHANGE);
  pinMode (lfupPin, OUTPUT);
  pinMode (lfdownPin, OUTPUT);
  pinMode (rfupPin, OUTPUT);
  pinMode (rfdownPin, OUTPUT);
  pinMode (lrupPin, OUTPUT);
  pinMode (lrdownPin, OUTPUT);
  pinMode (rrupPin, OUTPUT);
  pinMode (rrdownPin, OUTPUT);
  pinMode (upbuttonPin, INPUT);
  pinMode (ridebuttonPin, INPUT);
  Serial.print("?f");                //clear LCD per LCD117 command
  Serial.print("?x05?y1Rhodes Caddy");     //print at column 6, row 2
  Serial.print("?x06?y31950 Cadillac");     //print at column 7, row 4
  delay (2000);
  Serial.print("?x02?y0LF PSI:");     // print at column 4, row 1
  Serial.print("?x12?y0RF PSI:");     //print at column 13, row 1
  Serial.print("?x02?y2LR PSI:");     //print at column 4, row 3
  Serial.print("?x12?y2RR PSI:");     //print at column 13, row 3
    sensor1val = analogRead(psisensor1);  //reads all pressures in 4 bags
    sensor2val = analogRead(psisensor2);
    sensor3val = analogRead(psisensor3);
    sensor4val = analogRead(psisensor4);
    press1 = ((sensor1val)*35.0877-9.4737);           //calculates pressure in bags from voltage
    press2 = ((sensor2val)*35.0877-9.4737);
    press3 = ((sensor3val)*35.0877-9.4737);
    press4 = ((sensor4val)*35.0877-9.4737);
    Serial.write(press1);
    Serial.print("?x03?y1");
    Serial.print(press1);
    Serial.write(press2);
    Serial.print("?x13?y1");
    Serial.print(press2);
    Serial.write(press3);
    Serial.print("?x03?y3");
    Serial.print(press3);
    Serial.write(press4);
    Serial.print("?x13?y3");
    Serial.print(press4);
    delay(200);
    if (digitalRead(upbuttonPin)== HIGH)
      if (press1 < 116);
        delay(50);
        digitalWrite(lfupPin, HIGH);
        if (press1 >115);
          delay(50);
          digitalWrite(lfdownPin, HIGH);
      if (press2 < 116);
        delay(50);
        digitalWrite(rfupPin, HIGH);
        if (press2 > 115);
          delay(50);
          digitalWrite(rfdownPin, HIGH);
      if (press3 < 116);
        delay(50);
        digitalWrite (lrupPin, HIGH);
        if (press3 > 115);
          delay(50);
          digitalWrite (lrdownPin, HIGH);
      if (press4 < 116);
        delay(50);
        digitalWrite(rrupPin, HIGH);
        if (press4 > 115);
          delay(50);
          digitalWrite(rrdownPin, HIGH);
      return;
     if (digitalRead(ridebuttonPin) == HIGH)
       if (press1 < 80);
         delay(50);
         digitalWrite (lfupPin, HIGH);
         if (press1 > 80);
           delay(50);
           digitalWrite (lfdownPin, HIGH);
       if (press2 < 80);
         delay(50);
         if (press2 > 80);
         delay(50);
       if (press3 < 80);
         delay(50);
         digitalWrite(lrupPin, HIGH);
         if (press3 > 80);
           delay(50);
           digitalWrite(lrdownPin, HIGH);
       if (press4 < 80);
         delay(50);
         if (press4 > 80);
           delay(50);
    return;
   int reading1 = digitalRead(upbuttonPin);
   if (reading1 != lastButton1State)
     lastDebounceTime = millis();
   if ((millis() - lastDebounceTime) > debounceDelay)
     button1State = reading1;
   digitalWrite(upbuttonPin, button1State);
   lastButton1State = reading1;
   int reading2 = digitalRead(ridebuttonPin);
   if (reading2 != lastbutton2State)
     button2State = reading2;
   digitalWrite(ridebuttonPin, button2State);
   lastbutton2State = reading2;
void tank1()                          //Interrupt Button on digital pin 2 to show Tank 1 Pressure
  Serial.print("?x5?y0");
  Serial.print("UPPER TANK PSI:");
  tank1val = analogRead(tank1sensor);
  tank1pres =((tank1val)*35.0877-9.4737);
  Serial.print("?x08?y1");
  Serial.write(tank1pres);
  Serial.print(tank1pres);
void tank2()                         //Interrupt Button on digital pin 3 to show Tank 2 pressure
  Serial.print("?x05?y2");
  Serial.print("LOWER TANK PSI:");
  tank2val = analogRead(tank2sensor);
  tank2pres =((tank2val)*35.0877-9.4737);
  Serial.print("?x08?y3");
  Serial.write(tank2pres);
  Serial.print(tank2pres);
it is not a good idea to write to the seril port from the function loop and also from the interrupt procedure. A writing from loop can be interrupted from a serial print of the interrupt function and strange things may happen! Set a global flag inside the interrupt function and place the printing in the loop function like this:
bool tank1_print, tank2_print;
  delay (2000);
    delay(200);
    if (tank1_print) {
      tank1_print = false:
    if (tank2_print) {
      tank2_print = false;
      if (press1 < 116);
        delay(50);
        if (press1 >115);
          delay(50);
      if (press2 < 116);
        delay(50);
        if (press2 > 115);
          delay(50);
      if (press3 < 116);
        delay(50);
        if (press3 > 115);
          delay(50);
      if (press4 < 116);
        delay(50);
        if (press4 > 115);
          delay(50);
      return;
       if (press1 < 80);
         delay(50);
         if (press1 > 80);
           delay(50);
       if (press2 < 80);
         delay(50);
         if (press2 > 80);
         delay(50);
       if (press3 < 80);
         delay(50);
         if (press3 > 80);
           delay(50);
       if (press4 < 80);
         delay(50);
         if (press4 > 80);
           delay(50);
    return;
  tank_print = true;
  tank2_print = true;
Mike
Mike thank you for your help on this, I will put this into my code and see how it works for me. Thank you for helping a newbie out. I know i have TONS and TONS to learn.
