Hi, I need a little help from some of you guys who managed to get this display working. I just want to make sure I am transmitting the right bit patterns for set-up. Right now, my display remains dim...
Basically, I initialize the display and then write &B0101 to address 0x7 of IC #1 (the first addressed HT1632C controller).
I know the RC Master Mode and Com Option are not necessary, as these are the same as the default power-up state. But it makes not difference weather I transmit them or not.
Here's what I send. I have verified these states using the LEDs on the output pins of my AVR microcontroller. I have also created a delay to make sure the the bit patterns don't toggle too fast on the port for the display to be clocked in.
Here's what I transmit in sequence. I am showing the 4 lines to the display and then the binary states on each line in time, so like a timing diagram (hope that makes sense): :~
Select All ICs: I set CS low and then provide 4 positive clock pulses on Clk
CS =100000000001
Clk=010101010100
Set Command ID (transmit 100): I bit-bang on the Data line 100 while clocking WR from 0-1 at every bit
Data=110000
WR =010101
Sys Enable: I bit-bang 0000000010 while clocking WR from 0-1
Data=000000000000001100
WR =010101010101010101
LED On: I bit-bang 000000110
Data=000000000000111100
RC Master Mode: I bit-bang 000110000
Data=000000111100000000
Com Option: I bit-bang 001000000
Data=000011000000000000
Duty Cycle (set to 10/16): I bit-bang 101010010
Data=110011001100001100
Lastly, I write binary data &B0101 to address 0x7 to the first IC just to see if I get anything on the display:
Select IC #1: I set CS low and then provide 2 positive clock pulses on Clk
CS =00111
Clk=01010
Set Write Data Command ID (transmit 101): I bit-bang on the Data line 101 while clocking WR from 0-1 at every bit
Data=110011
WR =010101
Write &B0101 to address 0x7: I bit bang 0000111 as address and right after it 0101 as data while clocking WR from 0-1 at every bit
Data=0000000011111100110011
WR =0101010101010101010101
Any clue? Have I missed anything?
Thanks in advance for any hints! ![]()
