I'm attempting to create the Infinity Gauntlet for NY Comic Con and I would like to install 6 LED lights behind 6 3D printed gems. I'm trying to configure my Arduino to increase the brightness of the 6 LEDs when the flex sensor is bent and then have the LEDs turn off when the sensor is not bent. Does anyone have a code that I can use?
My apologies, let me add a little more detail to my original post.
I have the flex sensor plugged in to Analog A0, and the LEDs are in pin 7-12. I've only just started to learn how to program the Arduino and with such little time left before NYCC I'm not sure I will be able to learn the coding quick enough to create it myself.
I'm trying to tweak this code to have the lights turn on when the sensor is bent. Currently when you bend the sensor the first light turns on, if you continue to bend it the first light goes off and the second goes on, then it moves the the third light. I want all the lights to be off, but once I bend the sensor I would like them to slowly get brighter until max brightness.
//Flex Sensor Pin (flexPin)
//the analog pin the Flex Sensor is connected to
int flexPin = 0;
for (int i=7; i<14; i++){
pinMode(i, OUTPUT); //sets the led pins 7 to 12 to output
void loop(){
//Ensure to turn off ALL LEDs before continuing
for (int i=4; i<14; i++){
digitalWrite(i, LOW);
/* Read the flex Level
Adjust the value 130 to 275 to span 4 to 13
The values 130 and 275 may need to be widened to suit
the minimum and maximum flex levels being read by the
Analog pin */
int flexReading = map(analogRead(flexPin), 130, 275, 7, 14);
// Make sure the value does not go beyond 4 or 13
int LEDnum = constrain(flexReading, 7, 14);
/*Call the blink function: this will turn the LED on for 10 milliseconds, and keep it
off for only 1 millisecond. You can change the blink rate by changing these values,
however, I want a quick response time when the flex sensor bends, hence the small
values. LEDnum determines which LED gets turned on.*/
blink(LEDnum, 10,1);
// The blink function - used to turn the LEDs on and off
void blink(int LEDPin, int onTime, int offTime){
// Turn the LED on
digitalWrite(LEDPin, HIGH);
// Delay so that you can see the LED go On.
delay(onTime);
// Turn the LED Off
digitalWrite(LEDPin, LOW);
// Increase this Delay if you want to see an actual blinking effect.
delay(offTime);
one way is to lite up the LEDs one at a time as the flex sensor is bent, like this (untested)
byte ledPin[6] = {7,8,9,10,11,12};
int flexPin = A0;
for (byte i = 0; i < 6; i++)
pinMode(ledPin[i], OUTPUT); //sets the led pins 7 to 12 to output
blink(map(analogRead(flexPin), 0, 1023, 1, 6)); // you have 6 leds
void blink(byte ledsLit)
if (i <= ledsLit) digitalWrite(ledPin[i], HIGH);
else digitalWrite(ledPin[i], LOW);
the other way would be to use PWM on pins 3,5,6,9,10 & 11 and affect their brightness with the bending of the sensor like this also untested:
byte ledPin[6] = {3,5,6,9,10,11};//UNO PWM pins
int flexPin = A0;
blink(map(analogRead(flexPin), 0, 1023, 0, 255)); // you can change (0, 255) to something like (50,255) to affect the minimum briteness
void blink(byte briteness)
analogWrite(ledPin[i], briteness);
