Hi all, i have recently been building a project and prototyped with an arduino mega to get the main pcb design working but have just done my first board design including the atmega2560 chip so no arduino. I have successfully uploaded a sketch via icsp and have it working but am trying to work out the fuse bits and i can't get my head around it and what i need.
Firstly it ran slow so im assuming the divide by 8 clock was set wrong so found a working combination but when uploading my actual code i think it seems to run slow compared to when it was on the arduino board.
For example a button press from the touchscreen is lagging compared to when i push and let go versus when it enables and disables.
Im using a Ceramic Resonator 16mhz so was wondering how to go about setting the fuse bits correctly i've tried to use the calculator online but after reading im not sure what half of the variables mean or what i should be using
Is there anyone that can help me or what information or board variables will change these fuse bit requirements?
Thanks,
Darcy
