Soooo I am on the same boat as earlier people. I have this IR sensor I am trying to hookup to an Arduino One currently, but will eventually be on the adafruit Pro trinket. I am using the USB for power and have tried this code both in 5v and 3.3v and am having issues. I currently have it printing the voltage output because I was noticing the inconsistencies. Also for the power function, that was pretty much trial and error until I got a number that fit for the distance I was at.
2 questions based on the 5v setup
The sensor is giving inconsistent numbers when doing various lengths. Like one time i measure 100 cm, it will give me about 520. If it go to a different length then come back, or reupload, then next time it will be 490 or such. Is there a connection fault or is it the usb issue?
Am I even close on the conversion formulas used? I looked at different examples through the previous posts and years and found this one to, I think, supposedly be the most accurate at the end result, but it currently isn't working for me.
Any help is greatly appreciated, or if you have the code, even more so!!! ![]()
If you also have a better suggestion about how to do it and can give me some examples, that would be helpful too
#define sensorPin 0
#define VOLTS_PER_UNIT .00488F // (.0049 for 10 bit A-D) :1/v *225@5 -.887 , 148.5@3.3: -.391087
float volts;
float inches;
float proxSens = 0;
float cm;
pinMode(sensorPin, INPUT);
proxSens = analogRead(sensorPin);
volts = (float)proxSens * VOLTS_PER_UNIT; // ("proxSens" is from analog read)
cm = 225 * pow(volts,-.887); // same in cm
Serial.println(proxSens);
//Serial.print(cm);
Serial.print(' ');
delay(200);
