Help with GY-53 sensor freezing arduino
I am trying to use a time of flight sensor to measure distance, but the arduino freezes when the SDA wire is connected.
Here are the connections to the sensor:
GND > GND
5V > VCC
A4 > SDA
A5 > SCL
I have a video below showing the problem. At the beginning of the video, the connection between A4 and SDA is severed, and the program outputs invalid data, but when I plug it in, the program freezes.
Link to Video: [Link]
I am using this library, although I have also tried the Adafruit library as well.
Here is the code running, this is from the "Continuous" example:
/* This example shows how to use continuous mode to take
range measurements with the VL53L0X. It is based on
vl53l0x_ContinuousRanging_Example.c from the VL53L0X API.
The range readings are in units of mm. */
#include <Wire.h>
#include <VL53L0X.h>
VL53L0X sensor;
  Wire.begin();
  sensor.init();
  sensor.setTimeout(500);
  // Start continuous back-to-back mode (take readings as
  // fast as possible).  To use continuous timed mode
  // instead, provide a desired inter-measurement period in
  // ms (e.g. sensor.startContinuous(100)).
  sensor.startContinuous();
  Serial.print(sensor.readRangeContinuousMillimeters());
  if (sensor.timeoutOccurred()) { Serial.print(" TIMEOUT"); }
and here is the code inside of the VL53L0X.h file for convienience:
#ifndef VL53L0X_h
#define VL53L0X_h
#include <Arduino.h>
class VL53L0X
  public:
    // register addresses from API vl53l0x_device.h (ordered as listed there)
    enum regAddr
      SYSRANGE_START                              = 0x00,
      SYSTEM_THRESH_HIGH                          = 0x0C,
      SYSTEM_THRESH_LOW                           = 0x0E,
      SYSTEM_SEQUENCE_CONFIG                      = 0x01,
      SYSTEM_RANGE_CONFIG                         = 0x09,
      SYSTEM_INTERMEASUREMENT_PERIOD              = 0x04,
      SYSTEM_INTERRUPT_CONFIG_GPIO                = 0x0A,
      GPIO_HV_MUX_ACTIVE_HIGH                     = 0x84,
      SYSTEM_INTERRUPT_CLEAR                      = 0x0B,
      RESULT_INTERRUPT_STATUS                     = 0x13,
      RESULT_RANGE_STATUS                         = 0x14,
      RESULT_CORE_AMBIENT_WINDOW_EVENTS_RTN       = 0xBC,
      RESULT_CORE_RANGING_TOTAL_EVENTS_RTN        = 0xC0,
      RESULT_CORE_AMBIENT_WINDOW_EVENTS_REF       = 0xD0,
      RESULT_CORE_RANGING_TOTAL_EVENTS_REF        = 0xD4,
      RESULT_PEAK_SIGNAL_RATE_REF                 = 0xB6,
      ALGO_PART_TO_PART_RANGE_OFFSET_MM           = 0x28,
      I2C_SLAVE_DEVICE_ADDRESS                    = 0x8A,
      MSRC_CONFIG_CONTROL                         = 0x60,
      PRE_RANGE_CONFIG_MIN_SNR                    = 0x27,
      PRE_RANGE_CONFIG_VALID_PHASE_LOW            = 0x56,
      PRE_RANGE_CONFIG_VALID_PHASE_HIGH           = 0x57,
      PRE_RANGE_MIN_COUNT_RATE_RTN_LIMIT          = 0x64,
      FINAL_RANGE_CONFIG_MIN_SNR                  = 0x67,
      FINAL_RANGE_CONFIG_VALID_PHASE_LOW          = 0x47,
      FINAL_RANGE_CONFIG_VALID_PHASE_HIGH         = 0x48,
      FINAL_RANGE_CONFIG_MIN_COUNT_RATE_RTN_LIMIT = 0x44,
      PRE_RANGE_CONFIG_SIGMA_THRESH_HI            = 0x61,
      PRE_RANGE_CONFIG_SIGMA_THRESH_LO            = 0x62,
      PRE_RANGE_CONFIG_VCSEL_PERIOD               = 0x50,
      PRE_RANGE_CONFIG_TIMEOUT_MACROP_HI          = 0x51,
      PRE_RANGE_CONFIG_TIMEOUT_MACROP_LO          = 0x52,
      SYSTEM_HISTOGRAM_BIN                        = 0x81,
      HISTOGRAM_CONFIG_INITIAL_PHASE_SELECT       = 0x33,
      HISTOGRAM_CONFIG_READOUT_CTRL               = 0x55,
      FINAL_RANGE_CONFIG_VCSEL_PERIOD             = 0x70,
      FINAL_RANGE_CONFIG_TIMEOUT_MACROP_HI        = 0x71,
      FINAL_RANGE_CONFIG_TIMEOUT_MACROP_LO        = 0x72,
      CROSSTALK_COMPENSATION_PEAK_RATE_MCPS       = 0x20,
      MSRC_CONFIG_TIMEOUT_MACROP                  = 0x46,
      SOFT_RESET_GO2_SOFT_RESET_N                 = 0xBF,
      IDENTIFICATION_MODEL_ID                     = 0xC0,
      IDENTIFICATION_REVISION_ID                  = 0xC2,
      OSC_CALIBRATE_VAL                           = 0xF8,
      GLOBAL_CONFIG_VCSEL_WIDTH                   = 0x32,
      GLOBAL_CONFIG_SPAD_ENABLES_REF_0            = 0xB0,
      GLOBAL_CONFIG_SPAD_ENABLES_REF_1            = 0xB1,
      GLOBAL_CONFIG_SPAD_ENABLES_REF_2            = 0xB2,
      GLOBAL_CONFIG_SPAD_ENABLES_REF_3            = 0xB3,
      GLOBAL_CONFIG_SPAD_ENABLES_REF_4            = 0xB4,
      GLOBAL_CONFIG_SPAD_ENABLES_REF_5            = 0xB5,
      GLOBAL_CONFIG_REF_EN_START_SELECT           = 0xB6,
      DYNAMIC_SPAD_NUM_REQUESTED_REF_SPAD         = 0x4E,
      DYNAMIC_SPAD_REF_EN_START_OFFSET            = 0x4F,
      POWER_MANAGEMENT_GO1_POWER_FORCE            = 0x80,
      VHV_CONFIG_PAD_SCL_SDA__EXTSUP_HV           = 0x89,
      ALGO_PHASECAL_LIM                           = 0x30,
      ALGO_PHASECAL_CONFIG_TIMEOUT                = 0x30,
    enum vcselPeriodType { VcselPeriodPreRange, VcselPeriodFinalRange };
    uint8_t last_status; // status of last I2C transmission
    VL53L0X(void);
    void setAddress(uint8_t new_addr);
    inline uint8_t getAddress(void) { return address; }
    bool init(bool io_2v8 = true);
    void writeReg(uint8_t reg, uint8_t value);
    void writeReg16Bit(uint8_t reg, uint16_t value);
    void writeReg32Bit(uint8_t reg, uint32_t value);
    uint8_t readReg(uint8_t reg);
    uint16_t readReg16Bit(uint8_t reg);
    uint32_t readReg32Bit(uint8_t reg);
    void writeMulti(uint8_t reg, uint8_t const * src, uint8_t count);
    void readMulti(uint8_t reg, uint8_t * dst, uint8_t count);
    bool setSignalRateLimit(float limit_Mcps);
    float getSignalRateLimit(void);
    bool setMeasurementTimingBudget(uint32_t budget_us);
    uint32_t getMeasurementTimingBudget(void);
    bool setVcselPulsePeriod(vcselPeriodType type, uint8_t period_pclks);
    uint8_t getVcselPulsePeriod(vcselPeriodType type);
    void startContinuous(uint32_t period_ms = 0);
    void stopContinuous(void);
    uint16_t readRangeContinuousMillimeters(void);
    uint16_t readRangeSingleMillimeters(void);
    inline void setTimeout(uint16_t timeout) { io_timeout = timeout; }
    inline uint16_t getTimeout(void) { return io_timeout; }
    bool timeoutOccurred(void);
  private:
    // TCC: Target CentreCheck
    // MSRC: Minimum Signal Rate Check
    // DSS: Dynamic Spad Selection
    struct SequenceStepEnables
      boolean tcc, msrc, dss, pre_range, final_range;
    struct SequenceStepTimeouts
      uint16_t pre_range_vcsel_period_pclks, final_range_vcsel_period_pclks;
      uint16_t msrc_dss_tcc_mclks, pre_range_mclks, final_range_mclks;
      uint32_t msrc_dss_tcc_us,    pre_range_us,    final_range_us;
    uint8_t address;
    uint16_t io_timeout;
    bool did_timeout;
    uint16_t timeout_start_ms;
    uint8_t stop_variable; // read by init and used when starting measurement; is StopVariable field of VL53L0X_DevData_t structure in API
    uint32_t measurement_timing_budget_us;
    bool getSpadInfo(uint8_t * count, bool * type_is_aperture);
    void getSequenceStepEnables(SequenceStepEnables * enables);
    void getSequenceStepTimeouts(SequenceStepEnables const * enables, SequenceStepTimeouts * timeouts);
    bool performSingleRefCalibration(uint8_t vhv_init_byte);
    static uint16_t decodeTimeout(uint16_t value);
    static uint16_t encodeTimeout(uint16_t timeout_mclks);
    static uint32_t timeoutMclksToMicroseconds(uint16_t timeout_period_mclks, uint8_t vcsel_period_pclks);
    static uint32_t timeoutMicrosecondsToMclks(uint32_t timeout_period_us, uint8_t vcsel_period_pclks);
#endif
The sensor you're using is a 3V3 sensor. You must not connect it directly to 5V, neither for Vcc nor for the I2C signals (SDA, SCL). You might have already fried it.
Sorry, I forgot to post a link to the sensor: [Link]
In the documentation it says it accepts 3-5v, maybe I got sent the wrong product?
The link says the module accepts 3-5V power.
The module does not have level shifters for 5V I/O, so if you have accidentally exposed the inputs to 5V, it may have been destroyed as mentioned above.
Note: I2C I/O requires pullup resistors. If these are connected to 3.3V, then it can be OK to use the module with a 5V Arduino that does NOT have pullup resistors.
But it is always best to use that sensor (and any other 3.3V device) with a 3.3V Arduino.
Hello KonoDioDa, did you solve the problem?
I think that the problem is the use of the PS pin, when it is not wired, by default the module provides the measures by Serial (TX, RX and even PWM pines) but when the PS pin is attached to Ground, the module could be manipulated by I2C, I think that the library you are using is expected to work by I2C.
Can someone confirm?
Thanks
