I'm trying to set up a simple motor controller with an H-Bridge. It's all wired up and I have the Arduino programmed to run teh motor backwards and forwards with a 1 second delay between each change of direction.
The trouble is, the motor doesn't move. I have a multimeter connected to the motor outputs and it swings between +9V and -9V, without the motor. If I connect the motor, the voltage drops to +/- 0.4V.
I'm using a SN754410 H-Bridge with a 9V battery for motor power, and the Arduino for the logic power.
The motors are little DC motors that would normally hum along with a 9V battery.
Does anyone have an idea of what I might be doing wrong.
Thank you.
