I'm trying to figure out how to scan for the active slave address on any given I2C chip.
I've looked up and found some example code for this but I haven't had any success in getting a confirmed slave address in use.
In order to test the code I have an Accelerometer ADXL345 that I have powered hooked up to an Arduino Uno. SDA I hooked up to pin 2. SCL is hooked up to pin 7. My problem might be with hooking it up because I don't see anywhere in the code where you map the pins.
Here is the code I am using:
* I2CScanner.ino -- I2C bus scanner for Arduino
* 2009,2014, Tod E. Kurt, http://todbot.com/blog/
#include "Wire.h"
extern "C" {
#include "utility/twi.h" // from Wire library, so we can do bus scanning
// Scan the I2C bus between addresses from_addr and to_addr.
// On each address, call the callback function with the address and result.
// If result==0, address was found, otherwise, address wasn't found
// (can use result to potentially get other status on the I2C bus, see twi.c)
// Assumes Wire.begin() has already been called
void scanI2CBus(byte from_addr, byte to_addr,
void(*callback)(byte address, byte result) )
byte rc;
byte data = 0; // not used, just an address to feed to twi_writeTo()
for( byte addr = from_addr; addr <= to_addr; addr++ ) {
rc = twi_writeTo(addr, &data, 0, 1, 0);
callback( addr, rc );
// Called when address is found in scanI2CBus()
// Feel free to change this as needed
// (like adding I2C comm code to figure out what kind of I2C device is there)
void scanFunc( byte addr, byte result ) {
Serial.print("addr: ");
Serial.print(addr,DEC);
Serial.print( (result==0) ? " found!":" ");
Serial.print( (addr%4) ? "\t":"\n");
byte start_address = 1;
byte end_address = 100;
// standard Arduino setup()
Wire.begin();
Serial.println("\nI2CScanner ready!");
Serial.print("starting scanning of I2C bus from ");
Serial.print(start_address,DEC);
Serial.print(" to ");
Serial.print(end_address,DEC);
Serial.println("...");
// start the scan, will call "scanFunc()" on result from each address
scanI2CBus( start_address, end_address, scanFunc );
Serial.println("\ndone");
// standard Arduino loop()
// Nothing to do here, so we'll just blink the built-in LED
digitalWrite(13,HIGH);
delay(300);
digitalWrite(13,LOW);
delay(300);
After executing the code I get this on the serial monitor regardless of whether Accelerometer is powered or not:
I2CScanner ready!
starting scanning of I2C bus from 1 to 100...
addr: 1 addr: 2 addr: 3 addr: 4
addr: 5 addr: 6 addr: 7 addr: 8
addr: 9 addr: 10 addr: 11 addr: 12
addr: 13 addr: 14 addr: 15 addr: 16
addr: 17 addr: 18 addr: 19 addr: 20
addr: 21 addr: 22 addr: 23 addr: 24
addr: 25 addr: 26 addr: 27 addr: 28
addr: 29 addr: 30 addr: 31 addr: 32
addr: 33 addr: 34 addr: 35 addr: 36
addr: 37 addr: 38 addr: 39 addr: 40
addr: 41 addr: 42 addr: 43 addr: 44
addr: 45 addr: 46 addr: 47 addr: 48
addr: 49 addr: 50 addr: 51 addr: 52
addr: 53 addr: 54 addr: 55 addr: 56
addr: 57 addr: 58 addr: 59 addr: 60
addr: 61 addr: 62 addr: 63 addr: 64
addr: 65 addr: 66 addr: 67 addr: 68
addr: 69 addr: 70 addr: 71 addr: 72
addr: 73 addr: 74 addr: 75 addr: 76
addr: 77 addr: 78 addr: 79 addr: 80
addr: 81 addr: 82 addr: 83 addr: 84
addr: 85 addr: 86 addr: 87 addr: 88
addr: 89 addr: 90 addr: 91 addr: 92
addr: 93 addr: 94 addr: 95 addr: 96
addr: 97 addr: 98 addr: 99 addr: 100done
If someone could help me solve this, it would be awesome.
