I'm totally new to electronics. What I'm hoping to create is an LCD display approximately 1" x 3" that will display 6 air pressure inputs (4-20 mA or 20-100 ohm) on the display. Power source will be from a car battery 12v. Any input would be great. If I could get a parts list that would be sweet. Thanks!
I would think that if you had the resources to MAKE an LCD display that you would not need to ask for a parts list.
If you want to incorporate an LCD that you buy into an Arduino project, that's a different story. The parts list, then, is simple:
- An LCD.
by way of the Arduino. So, the actual source is not that important.
I guess I should clarify what I would like so that the next reply doesn't cling to every literal word of my post and provide no usable input.
I'd like to purchase an LCD display and using an Arduino unit of so sort, not sure what unit will work since I'm new to using them, have analog inputs into the unit to display pressures on the LCD display.
Any help would be great! Thanks.
Most LCD displays will work with most Arduinos.
If you have a specific one in mind, we can tell you whether or not it will work with a specific Arduino.
