Help with many errors on a code
I need help in this code:
int ESTADO = 0;
void setup(){
  pinMode( 13, OUTPUT);
void loop(){
  if(Serial.available()>0)(
  ESTADO= Serial.read();
  if (ESTADO == "1")(
    digitalWrite( 13, HIGH );
  if (ESTADO == "2")(
    digitalWrite( 13, LOW );
When I try to verify it in Arduino IDE it shows errors like those ones:
In function 'void loop()':
sketch_mar16a:10:24: error: expected ')' before ';' token
sketch_mar16a:11:3: error: expected primary-expression before ')' token
sketch_mar16a:14:3: error: expected primary-expression before ')' token
sketch_mar16a:18:3: error: expected primary-expression before ')' token
exit status 1
if (ESTADO == "1")ESTADO is NOT a String.
Lose the double quotes and use single quotes.
As to your other errors, use { }, not ( )
Thank you :smiley:
