Help with pixy code
Currently the code is having the wheels move in a circle and the sweep motion is not really going. The pixy isn't really controlling anything like it's supposed to. What should I change to have the pixy chase the object and then sweep it plus grab it? This is what I have so far. There is a base of four servos and two sweep servos.
#include "SPI.h"
#include <Servo.h>
#include <Pixy2.h>
#include <PIDLoop.h>
#define MAX_TRANSLATE_VELOCITY 250
PIDLoop panLoop(350, 0, 600, true);
PIDLoop tiltLoop(500, 0, 700, true);
PIDLoop rotateLoop(300, 600, 300, false);
PIDLoop translateLoop(400, 800, 300, false);
Servo ServoBaseBRPin;
Servo ServoBaseBLPin;
Servo ServoBaseFRPin;
Servo ServoBaseFLPin;
Servo ServograbarmL;
Servo ServograbarmR;
int pos = 0;
Pixy2 pixy;
int buzzerpin=12;
//BR means back right pin FR front right pin
ServoBaseBRPin.attach(2);
ServoBaseBLPin.attach(3);
ServoBaseFRPin.attach(4);
ServoBaseFLPin.attach(5);
ServograbarmL.attach(8);
ServograbarmR.attach(9);
ServoBaseBRPin.write(0);
ServoBaseFLPin.write(0);
ServoBaseFRPin.write(0);
ServograbarmL.write(0);
ServograbarmR.write(0);
pixy.init();
pixy.changeProg("color_connected_components");
int16_t acquireBlock()
if (pixy.ccc.numBlocks && pixy.ccc.blocks[0].m_age>30)
return pixy.ccc.blocks[0].m_index;
return -1;
Block trackBlock(uint8_t index)
uint8_t i;
for (i=0; i<pixy.ccc.numBlocks; i++)
if (index==pixy.ccc.blocks
.m_index)*
_ return &pixy.ccc.blocks*;_
_
}_
_
return NULL;_
_
}_
_
{_
static int16_t index = -1;
int32_t panOffset, tiltOffset, headingOffset, left, right;
Block *block=NULL;
pixy.ccc.getBlocks();
if (index>-0)
_
{_
_
block = trackBlock(index);_
if (block)
_
{_
panOffset = (int32_t)pixy.frameWidth/2 - (int32_t)block->m_x;
tiltOffset = (int32_t)block->m_y - (int32_t)pixy.frameHeight/2;
_
panLoop.update(panOffset);_
_
tiltLoop.update(tiltOffset);_
pixy.setServos(panLoop.m_command, tiltLoop.m_command);
_
ServoBaseBLPin.write(0);_
ServoBaseBRPin.write(90);
ServoBaseFRPin.write(90);
panOffset += panLoop.m_command - PIXY_RCS_CENTER_POS;
tiltOffset +=tiltLoop.m_command - PIXY_RCS_CENTER_POS - PIXY_RCS_CENTER_POS/2 + PIXY_RCS_CENTER_POS/8;
rotateLoop.update(panOffset);
translateLoop.update(-tiltOffset);
_
}_
_
{_
_
rotateLoop.reset();_
_
translateLoop.reset();_
_
_
_
_
ServoBaseBRPin.write(0);_
_
ServoBaseFLPin.write(0);_
_
ServoBaseFRPin.write(0);_
_
index = -1;_
panOffset = (int32_t)pixy.frameWidth/2-(int32_t)pixy.ccc.blocks[0].m_x;
tiltOffset - (int32_t)pixy.ccc.blocks[0].m_y-(int32_t)pixy.frameHeight/2;
_
_
pixy.setServos(panLoop.m_command,tiltLoop.m_command);
_
}_
_
}_
_
{_
_
panLoop.reset();_
_
tiltLoop.reset();_
_
}_
_
}*_
Thank you for the help
It would help us greatly if you would edit your post and add the code tags that you forgot.
After you have fixed the post, please explain in detail what the arm should do, and what it does instead.
