help with RFM69HW wireless module
Hello,
I have two Arduino Uno's and a few RFM69HW modules. I'm trying to get the node and gateway pingpong example working from LowPowerLabs/Felix website. So far, not having much luck. Maybe someone can spot what I'm doing wrong?
My wiring on both Arduinos:
RFM MISO = Arduino 12
RFM MOSI = Arduino 11
RFM SCK = Arduino 13
RFM GND = Arduino GND
RFM NSS = Arduino 10
RFM NC = Arduino GND
RFM 3.3V = 3.3V from voltage regulator
RFM DIO0 = Arduino 2 (interrupt I think)
This is the output of the node. It just sits there like this.
Transmitting at 915 Mhz...
Sending[0]:
This is the output of the gateway. It's not seeing anything.
Listening at 915 Mhz...
I made modifications to the node and gateway sketches, as well as the .h file to specify the pin used for NSS (device select).
For the node sketch, I mostly just defined the frequency and got rid of the SPIFlash.h stuff:
// Sample RFM69 sender/node sketch, with ACK and optional encryption
// Sends periodic messages of increasing length to gateway (id=1)
// It also looks for an onboard FLASH chip, if present
// Library and code by Felix Rusu - felix@lowpowerlab.com
// Get the RFM69 and SPIFlash library at: https://github.com/LowPowerLab/
NOTES:
1)  RFM69 pin:
    MOSI = 11
    MISO = 12
    SCK = 13
    SS = 10
#include <RFM69.h>
#include <SPI.h>
//#include <SPIFlash.h>
#define NODEID        2    //unique for each node on same network
#define NETWORKID     100  //the same on all nodes that talk to each other
#define GATEWAYID     1
//Match frequency to the hardware version of the radio on your Moteino (uncomment one):
//#define FREQUENCY   RF69_433MHZ
#define FREQUENCY   RF69_915MHZ
//#define FREQUENCY   RF69_868MHZ
//#define FREQUENCY     RF69_915MHZ
#define ENCRYPTKEY    "sampleEncryptKey" //exactly the same 16 characters/bytes on all nodes!
//#define IS_RFM69HW    //uncomment only for RFM69HW! Leave out if you have RFM69W!
#define ACK_TIME      30 // max # of ms to wait for an ack
#define LED           9  // Moteinos have LEDs on D9
#define SERIAL_BAUD   115200
int TRANSMITPERIOD = 300; //transmit a packet to gateway so often (in ms)
char payload[] = "123 ABCDEFGHIJKLMNOPQRSTUVWXYZ";
char buff[20];
byte sendSize=0;
boolean requestACK = false;
//SPIFlash flash(8, 0xEF30); //EF40 for 16mbit windbond chip
RFM69 radio;
  Serial.begin(SERIAL_BAUD);
  radio.initialize(FREQUENCY,NODEID,NETWORKID);
#ifdef IS_RFM69HW
  radio.setHighPower(); //uncomment only for RFM69HW!
#endif
  radio.encrypt(ENCRYPTKEY);
  char buff[50];
  sprintf(buff, "\nTransmitting at %d Mhz...", FREQUENCY==RF69_433MHZ ? 433 : FREQUENCY==RF69_868MHZ ? 868 : 915);
  Serial.println(buff);
  if (flash.initialize())
    Serial.println("SPI Flash Init OK!");
    Serial.println("SPI Flash Init FAIL! (is chip present?)");
long lastPeriod = -1;
  //process any serial input
  if (Serial.available() > 0)
    char input = Serial.read();
    if (input >= 48 && input <= 57) //[0,9]
      TRANSMITPERIOD = 100 * (input-48);
      if (TRANSMITPERIOD == 0) TRANSMITPERIOD = 1000;
      Serial.print("\nChanging delay to ");
      Serial.print(TRANSMITPERIOD);
      Serial.println("ms\n");
    if (input == 'r') //d=dump register values
      radio.readAllRegs();
    //if (input == 'E') //E=enable encryption
    //  radio.encrypt(KEY);
    //if (input == 'e') //e=disable encryption
    //  radio.encrypt(null);
    if (input == 'd') //d=dump flash area
      Serial.println("Flash content:");
      int counter = 0;
      while(counter<=256){
        Serial.print(flash.readByte(counter++), HEX);
        Serial.print('.');
      while(flash.busy());
    if (input == 'e')
      Serial.print("Erasing Flash chip ... ");
      flash.chipErase();
      Serial.println("DONE");
    if (input == 'i')
      Serial.print("DeviceID: ");
      word jedecid = flash.readDeviceId();
      Serial.println(jedecid, HEX);
  //check for any received packets
  if (radio.receiveDone())
    Serial.print('[');Serial.print(radio.SENDERID, DEC);Serial.print("] ");
    for (byte i = 0; i < radio.DATALEN; i++)
      Serial.print((char)radio.DATA[i]);
    Serial.print("   [RX_RSSI:");Serial.print(radio.RSSI);Serial.print("]");
    if (radio.ACK_REQUESTED)
      radio.sendACK();
      Serial.print(" - ACK sent");
      delay(10);
    Blink(LED,5);
  //send FLASH id
  if(sendSize==0)
    sprintf(buff, "FLASH_MEM_ID:0x%X", flash.readDeviceId());
    byte buffLen=strlen(buff);
    radio.sendWithRetry(GATEWAYID, buff, buffLen);
    delay(TRANSMITPERIOD);
  int currPeriod = millis()/TRANSMITPERIOD;
  if (currPeriod != lastPeriod)
    lastPeriod=currPeriod;
    Serial.print("Sending[");
    Serial.print(sendSize);
    Serial.print("]: ");
    for(byte i = 0; i < sendSize; i++)
      Serial.print((char)payload[i]);
    if (radio.sendWithRetry(GATEWAYID, payload, sendSize))
     Serial.print(" ok!");
    else Serial.print(" nothing...");
    sendSize = (sendSize + 1) % 31;
    Blink(LED,3);
void Blink(byte PIN, int DELAY_MS)
  pinMode(PIN, OUTPUT);
  digitalWrite(PIN,HIGH);
  delay(DELAY_MS);
  digitalWrite(PIN,LOW);
gateway:
// Sample RFM69 receiver/gateway sketch, with ACK and optional encryption
// Passes through any wireless received messages to the serial port & responds to ACKs
NOTES:
1)  RFM69 pin:
    MOSI = 11
    MISO = 12
    SCK = 13
    SS = 10
    LED = ?  add to code
#include <RFM69.h>
#include <SPI.h>
#define NODEID        1    //unique for each node on same network
//tsai:  which pin is LED
RFM69 radio;
bool promiscuousMode = false; //set to 'true' to sniff all packets on the same network
  delay(10);
#ifdef IS_RFM69HW
#endif
  radio.promiscuous(promiscuousMode);
  char buff[50];
  sprintf(buff, "\nListening at %d Mhz...", FREQUENCY==RF69_433MHZ ? 433 : FREQUENCY==RF69_868MHZ ? 868 : 915);
byte ackCount=0;
    if (input == 'r') //d=dump all register values
    if (input == 'p')
      promiscuousMode = !promiscuousMode;
      Serial.print("Promiscuous mode ");Serial.println(promiscuousMode ? "on" : "off");
      int counter = 0;
        Serial.print('.');
    if (input == 'D')
      Serial.print("Deleting Flash chip content... ");
      flash.chipErase();
    if (input == 'i')
    if (input == 't')
      byte temperature =  radio.readTemperature(-1); // -1 = user cal factor, adjust for correct ambient
      byte fTemp = 1.8 * temperature + 32; // 9/5=1.8
      Serial.print( "Radio Temp is ");
      Serial.print(temperature);
      Serial.print("C, ");
      Serial.print(fTemp); //converting to F loses some resolution, obvious when C is on edge between 2 values (ie 26C=78F, 27C=80F)
      Serial.println('F');
    if (promiscuousMode)
      Serial.print("to [");Serial.print(radio.TARGETID, DEC);Serial.print("] ");
      byte theNodeID = radio.SENDERID;
      radio.sendACK();
      Serial.print(" - ACK sent.");
      // When a node requests an ACK, respond to the ACK
      // and also send a packet requesting an ACK (every 3rd one only)
      // This way both TX/RX NODE functions are tested on 1 end at the GATEWAY
      if (ackCount++%3==0)
        Serial.print(" Pinging node ");
        Serial.print(theNodeID);
        Serial.print(" - ACK...");
        delay(3); //need this when sending right after reception .. ?
        if (radio.sendWithRetry(theNodeID, "ACK TEST", 8, 0))  // 0 = only 1 attempt, no retries
          Serial.print("ok!");
        else Serial.print("nothing");
    Blink(LED,3);
  delay(DELAY_MS);
RFM69.h file, I replaced SS with 10 for the SPI_CS. That's the only change I made.
// Driver definition for HopeRF RFM69W/RFM69HW, Semtech SX1231/1231H
// Creative Commons Attrib Share-Alike License
// You are free to use/extend this library but please abide with the CC-BY-SA license:
// http://creativecommons.org/licenses/by-sa/3.0/
// 2013-06-14 (C) felix@lowpowerlab.com
#ifndef RFM69_h
#define RFM69_h
#include <Arduino.h>            //assumes Arduino IDE v1.0 or greater
#define MAX_DATA_LEN         61 // to take advantage of the built in AES/CRC we want to limit the frame size to the internal FIFO size (66 bytes - 3 bytes overhead)
//#define SPI_CS               SS // SS is the SPI slave select pin, for instance D10 on atmega328
#define SPI_CS               10 // SS is the SPI slave select pin, for instance D10 on atmega328
#define RF69_IRQ_PIN          2 // INT0 on AVRs should be connected to DIO0 (ex on Atmega328 it's D2)
#define CSMA_LIMIT          -90 // upper RX signal sensitivity threshold in dBm for carrier sense access
#define RF69_MODE_SLEEP       0 // XTAL OFF
#define	RF69_MODE_STANDBY     1 // XTAL ON
#define RF69_MODE_SYNTH	      2 // PLL ON
#define RF69_MODE_RX          3 // RX MODE
#define RF69_MODE_TX		      4 // TX MODE
//available frequency bands
#define RF69_315MHZ     31  // non trivial values to avoid misconfiguration
#define RF69_433MHZ     43
#define RF69_868MHZ     86
#define RF69_915MHZ     91
#define null                  0
#define COURSE_TEMP_COEF    -90 // puts the temperature reading in the ballpark, user can fine tune the returned value
#define RF69_BROADCAST_ADDR 255
class RFM69 {
  public:
    static volatile byte DATA[MAX_DATA_LEN];          // recv/xmit buf, including hdr & crc bytes
    static volatile byte DATALEN;
    static volatile byte SENDERID;
    static volatile byte TARGETID; //should match _address
    static volatile byte PAYLOADLEN;
    static volatile byte ACK_REQUESTED;
    static volatile byte ACK_RECEIVED; /// Should be polled immediately after sending a packet with ACK request
    static volatile int RSSI; //most accurate RSSI during reception (closest to the reception)
    static volatile byte _mode; //should be protected?
    RFM69(byte slaveSelectPin=SPI_CS, byte interruptPin=RF69_IRQ_PIN, bool isRFM69HW=false) {
      _slaveSelectPin = slaveSelectPin;
      _interruptPin = interruptPin;
      _mode = RF69_MODE_STANDBY;
      _promiscuousMode = false;
      _powerLevel = 31;
      _isRFM69HW = isRFM69HW;
    bool initialize(byte freqBand, byte ID, byte networkID=1);
    void setAddress(byte addr);
    bool canSend();
    void send(byte toAddress, const void* buffer, byte bufferSize, bool requestACK=false);
    bool sendWithRetry(byte toAddress, const void* buffer, byte bufferSize, byte retries=2, byte retryWaitTime=30);
    bool receiveDone();
    bool ACKReceived(byte fromNodeID);
    void sendACK(const void* buffer = "", uint8_t bufferSize=0);
    void setFrequency(uint32_t FRF);
    void encrypt(const char* key);
    void setCS(byte newSPISlaveSelect);
    int readRSSI(bool forceTrigger=false);
    void promiscuous(bool onOff=true);
    void setHighPower(bool onOFF=true); //have to call it after initialize for RFM69HW
    void setPowerLevel(byte level); //reduce/increase transmit power level
    void sleep();
    byte readTemperature(byte calFactor=0); //get CMOS temperature (8bit)
    void rcCalibration(); //calibrate the internal RC oscillator for use in wide temperature variations - see datasheet section [4.3.5. RC Timer Accuracy]
    // allow hacking registers by making these public
    byte readReg(byte addr);
    void writeReg(byte addr, byte val);
    void readAllRegs();
  protected:
    static void isr0();
    void virtual interruptHandler();
    void sendFrame(byte toAddress, const void* buffer, byte size, bool requestACK=false, bool sendACK=false);
    static RFM69* selfPointer;
    byte _slaveSelectPin;
    byte _interruptPin;
    byte _address;
    bool _promiscuousMode;
    byte _powerLevel;
    bool _isRFM69HW;
    void receiveBegin();
    void setMode(byte mode);
    void setHighPowerRegs(bool onOff);
    void select();
    void unselect();
#endif
Hi arusr,
Have you solved this?
Is it probably more a hardware than a software problem?
(RFM69 is a 3.3 V module, the Uno is 5.0 V powered)
I'm currently planning to connect my Uno with a RFM69HW but don't find a lot of info on the web...
Did you guys get it working? I'm just starting the process tonight. I'm using the library here: GitHub - LowPowerLab/RFM69: RFM69 library for RFM69W, RFM69HW, RFM69CW, RFM69HCW (semtech SX1231, SX1231H)
and TNode and TGateway files from here: Anarduino MiniWireless Details
I saw this pin-out and am wondering what your final pinout is. (https://electronichamsters.files.wordpress.com/2014/09/dd_basic.png) These TNode and TGateway files have no variables for assigning pins on the Arduino. I'm using an Uno and a Nano 3.0.
If any of you have this working, do you have the schematic that's different than the one I show above?
Thank you.
Try this well supported library with several ready to go examples and wiring daigrams :
http://www.airspayce.com/mikem/arduino/RadioHead/
It also has a forum that deals with wiring issues amongst others.
Thank you. I've been digging into this further and I realize...I have a lot to learn still. I thought I could use the 3.3V output on the Uno and Nano, but the digital pins are still 5V. I don't want to fuss w/ additional circuitry, so I just bought some 3.3V Nano equivalents.
I soldered a few radios up and I'm ready to test them once I get the right microcontrollers in. I'm going to have the same problem with the ESP Wi-Fi chips I ordered. ...learning lessons stink. Hey, that's how we learn.
On that library you posted, I've been looking at it and wow, it is nice. I already downloaded it and removed the other library. :slight_smile:
arusr:
NC = Not Connected/No Connection.
I would suggest do not connect to ground.
Don't cross-post. Thread locked.
