Using IDE 2.3.10.
Project is here:
# github . com/VolosR/WaveshareRadioStream/blob/main/winRadio/winRadio.ino
#include "Arduino.h"
#include "WiFiMulti.h"
#include "Audio.h"
#include "SD_MMC.h"
#include "FS.h"
#include <Arduino_GFX_Library.h>
#include <LovyanGFX.hpp>
#include "es8311.h"
#include "esp_check.h"
#include "Wire.h"
#include "NotoSansBold15.h"
#define PA_CTRL 7
#define I2S_MCLK 8
#define I2S_BCLK 9
#define I2S_DOUT 12
#define I2S_LRC 10
#define I2C_SDA 42
#define I2C_SCL 41
#define EXAMPLE_SAMPLE_RATE (16000)
#define EXAMPLE_MCLK_MULTIPLE (256) // If not using 24-bit data width, 256 should be enough
#define EXAMPLE_MCLK_FREQ_HZ (EXAMPLE_SAMPLE_RATE * EXAMPLE_MCLK_MULTIPLE)
#define EXAMPLE_VOICE_VOLUME (75)
LGFX_Sprite sprite;
LGFX_Sprite sprite2;
String curStation="";
String songPlaying="";
long bitrate=0;
bool connected=false;
int songposition=-220;
float voltage=4.20;
int batLevel=0;
Audio audio;
WiFiMulti wifiMulti;
String ssid = "xxxxxxxxx"; // ################### DONT FORGET EDIT THIS
String password = "xxxxxxxxxx";
bool canDraw=0;
bool deb=0;
bool deb2=0;
int rssi=0;
int clk = 16;
int cmd = 15;
int d0 = 17;
int d1 = 18;
int d2 = 13;
int d3 = 14;
int chosen=0; //current station
int volume=2;
String letters[3]={"P","S","V"};
unsigned short grays[18];
unsigned short gray;
unsigned short light;
int g[14]={0}; //graph
#define ns 6 //number of stations max 9
String stations[ns]={
"https://discodiamond.radioca.st/autodj",
"https://listen.radioking.com/radio/175279/stream/216784",
"http://sc6.radiocaroline.net:8040/stream",
"https://club-high.rautemusik.fm/;",
"http://greece-media.monroe.edu/wgmc.mp3",
"https://audio.radio-banovina.hr:9998/;"
#define GFX_BL 46
Arduino_DataBus* bus = new Arduino_ESP32SPI(45 /* DC */, 21 /* CS */, 38 /* SCK */, 39 /* MOSI */, -1 /* MISO */);
Arduino_GFX* gfx = new Arduino_ST7789(
bus, 40 /* RST */, 0 /* rotation */, true, 240, 240);
static esp_err_t es8311_codec_init(void) {
es8311_handle_t es_handle = es8311_create(I2C_NUM_0, ES8311_ADDRRES_0);
ESP_RETURN_ON_FALSE(es_handle, ESP_FAIL, TAG, "es8311 create failed");
const es8311_clock_config_t es_clk = {
.mclk_inverted = false,
.sclk_inverted = false,
.mclk_from_mclk_pin = true,
.mclk_frequency = EXAMPLE_MCLK_FREQ_HZ,
.sample_frequency = EXAMPLE_SAMPLE_RATE
ESP_ERROR_CHECK(es8311_init(es_handle, &es_clk, ES8311_RESOLUTION_16, ES8311_RESOLUTION_16));
ESP_RETURN_ON_ERROR(es8311_sample_frequency_config(es_handle, EXAMPLE_SAMPLE_RATE * EXAMPLE_MCLK_MULTIPLE, EXAMPLE_SAMPLE_RATE), TAG, "set es8311 sample frequency failed");
ESP_RETURN_ON_ERROR(es8311_voice_volume_set(es_handle, EXAMPLE_VOICE_VOLUME, NULL), TAG, "set es8311 volume failed");
ESP_RETURN_ON_ERROR(es8311_microphone_config(es_handle, false), TAG, "set es8311 microphone failed");
return ESP_OK;
Wire.begin(I2C_SDA, I2C_SCL);
gpio_hold_dis((gpio_num_t)2);
pinMode(0, INPUT_PULLUP); // left na GPIO0
pinMode(5, INPUT_PULLUP); // mid button
pinMode(4, INPUT_PULLUP); // right button
// batt enable
pinMode(2,OUTPUT);
digitalWrite(2,HIGH);
pinMode(PA_CTRL, OUTPUT);
digitalWrite(PA_CTRL, HIGH);
es8311_codec_init();
gpio_hold_en((gpio_num_t)2);
gfx->begin();
gfx->fillScreen(RGB565_BLACK);
analogWrite(GFX_BL,110); //SCREEN BRIGHTNESS 0-255
gfx->setCursor(2, 20);
gfx->setTextSize(2);
gfx->setTextColor(RGB565_GREEN);
gfx->println("connecting to WI-FI");
sprite.setColorDepth(16); // RGB565
sprite.createSprite(240, 240);
sprite2.createSprite(230, 16);
sprite.loadFont(NotoSansBold15);
int co = 214;
for (int i = 0; i < 18; i++) {
grays[i] = sprite.color565(co, co, co+40);
co = co - 13;
sprite2.setTextColor(grays[0],TFT_BLACK);
WiFi.mode(WIFI_STA);
wifiMulti.addAP(ssid.c_str(), password.c_str());
wifiMulti.run();
if (WiFi.status() != WL_CONNECTED) {
WiFi.disconnect(true);
wifiMulti.run();
audio.setPinout(I2S_BCLK, I2S_LRC, I2S_DOUT, I2S_MCLK);
audio.setVolume(volume*4); // 0...21
audio.connecttohost(stations[0].c_str());
void draw2()
sprite.drawString("Hello",20,20,2);
gray=grays[16];
light=grays[12];
sprite.fillRect(0,0,240,240,gray);
//stations frame
sprite.fillRect(4,20,150,172,BLACK);
sprite.drawRect(4,20,150,172,light);
// time and grapg frame
sprite.fillRect(160,20,74,60,BLACK);
sprite.drawRect(160,20,74,60,light);
sprite.fillRect(174,24,5,10,TFT_RED);
sprite.fillRect(174,37,5,10,TFT_GREEN);
//battery
sprite.drawRect(210,36,17,10,TFT_GREEN);
sprite.fillRect(212,38,batLevel,6,TFT_GREEN); //bat lvl
sprite.fillRect(227,39,2,4,TFT_GREEN);
//bitrate
sprite.fillRect(160,176,74,16,BLACK);
sprite.drawRect(160,176,74,16,light);
//volume bar
sprite.fillRoundRect(160,140,74,3,2,YELLOW);
sprite.fillRoundRect(146+(volume*15),137,14,8,2,grays[2]);
sprite.fillRoundRect(149+(volume*15),139,8,4,2,grays[10]);
//songplaying frame
sprite.fillRect(4,212,232,18,BLACK);
sprite.drawRect(4,212,232,18,light);
sprite.fillRect(149,20,5,172,grays[11]);
int sliderPos=12;
sprite.fillRect(149,sliderPos+8,5,20,grays[2]);
sprite.fillRect(151,sliderPos+12,1,12,grays[16]);
sprite.fillRect(4,7,150,3,ORANGE);
sprite.fillRect(190,5,45,3,ORANGE);
sprite.fillRect(160,194,74,1,ORANGE);
sprite.fillRect(190,11,45,3,grays[6]);
//frame top and bot
sprite.drawRect(0,0,239,239,light);
sprite.fillRect(5,234,230,2,grays[13]);
sprite.setTextColor(grays[1],gray);
sprite.drawString(" STATIONS ",42,2,2);
sprite.drawString("WEB",160,2,2);
//station list
for(int i=0;i<ns;i++)
if(i==chosen) sprite.setTextColor(TFT_GREEN,TFT_BLACK); else sprite.setTextColor(TFT_DARKGREEN,TFT_BLACK);
sprite.drawString(stations[i].substring(0,20),10,26+(i*19),2);
sprite.setTextColor(grays[0],gray);
sprite.drawString("INTERNET",160,86);
sprite.setTextColor(TFT_RED,gray);
sprite.drawString("RADIO",160,102);
sprite.setTextColor(grays[6],gray);
sprite.drawString("SONG PLAYING",6,200,1);
sprite.drawString("VOLUME",160,124,1);
sprite.setTextColor(grays[10],TFT_BLACK);
sprite.drawString("W",165,24,1);
sprite.drawString("I",165,34,1);
sprite.drawString("F",165,44,1);
sprite.drawString("I",165,54,1);
sprite.drawString("BITRATE "+String(bitrate),164,180,1);
sprite.drawString("RSSI:"+String(rssi),183,24,1);
sprite.drawString(String(voltage),183,37,1);
sprite.setTextColor(grays[11],gray);
sprite.drawString("VOLOS PROJECTS 2026",122,200,1);
//graph
for(int i=0;i<12;i++){
if(connected)
g[i]=random(1,5);
for(int j=0;j<g[i];j++)
sprite.fillRect(172+(i*5),71-j*4,4,3,grays[4]);
sprite.setTextColor(grays[16],grays[5]);
//butons
for(int i=0;i<3;i++)
sprite.fillRoundRect(160+(i*26),152,22,18,4,grays[5]);
sprite.drawString(letters[i],166+(i*26),154);
uint16_t *buf = (uint16_t*)sprite.getBuffer();
int total = 240 * 240;
for (int i = 0; i < total; i++) {
buf[i] = __builtin_bswap16(buf[i]);
gfx->draw16bitRGBBitmap(0, 0, buf, 240, 240);
canDraw=0;
draw3();
void draw3()
songposition--;
if(songposition<-220) songposition=220;
sprite2.fillSprite(TFT_BLACK);
sprite2.drawString(songPlaying,songposition,5);
uint16_t *buf2 = (uint16_t*)sprite2.getBuffer();
int total2 = 230 * 16;
for (int i = 0; i < total2; i++) {
buf2[i] = __builtin_bswap16(buf2[i]);
gfx->draw16bitRGBBitmap(5, 213, buf2, 230, 16);
void measureBatt()
uint16_t mv = analogReadMilliVolts(1); // mV na ADC pinu
float vbat = (mv / 1000.0) * 3.0; // stvarni napon baterije
voltage = vbat;
char vol_buffer[8];
sprintf(vol_buffer, "%.2f", voltage);
// izračun postotka baterije (Li-ion)
float minV = 3.0;
float maxV = 4.2;
float pct = (vbat - minV) / (maxV - minV);
pct = constrain(pct, 0.0, 1.0);
batLevel = pct * 13.0;
//measure signal strength
static unsigned long lastRSSI = 0;
static unsigned long lastSlide = 0;
if (millis() - lastRSSI > 240) { // every 240 ms
lastRSSI = millis();
rssi = WiFi.RSSI(); // očitaj jačinu signala
measureBatt();
canDraw=1;
if (WiFi.status() == WL_CONNECTED)
{connected=true;}
{connected=false;
songPlaying="WIFI NOT CONNECTED";}
if (millis() - lastSlide > 30) { // svakih 1 sekundu
lastSlide = millis();
draw3();
if (digitalRead(5) == LOW) {
if(deb==0)
deb=1;
chosen++;
if(chosen==ns) chosen=0;
audio.connecttohost(stations[chosen].c_str());
canDraw=1;
}else deb=0;
if (digitalRead(4) == LOW) {
if(deb2==0)
deb2=1;
volume++;
if(volume==6) volume=1;
canDraw=1;
}else deb2=0;
if (digitalRead(0) == LOW) {
esp_sleep_enable_ext0_wakeup(GPIO_NUM_0, 0); // probudi se kad gumb opet bude LOW
digitalWrite(PA_CTRL, LOW);
delay(200);
esp_deep_sleep_start();
vTaskDelay(1);
audio.loop();
if(canDraw)
draw2();
// optional
void audio_info(const char *info) {
Serial.print("info ");
Serial.println(info);
void audio_id3data(const char *info) { //id3 metadata
Serial.print("id3data ");
void audio_showstation(const char *info) {
Serial.print("station ");
curStation=info;
canDraw=true;
void audio_showstreamtitle(const char *info) {
Serial.print("streamtitle ");
songPlaying=info;
canDraw=1;
void audio_bitrate(const char *info) {
Serial.print("bitrate ");
bitrate=(String(info).toInt()/1000);
Compile errors:
winRadio.ino:38:1: error: 'Audio' does not name a type
38 | Audio audio;
winRadio.ino: In function 'void setup()':
winRadio.ino:154:3: error: 'audio' was not declared in this scope
154 | audio.setPinout(I2S_BCLK, I2S_LRC, I2S_DOUT, I2S_MCLK);
winRadio.ino: In function 'void draw2()':
winRadio.ino:169:38: error: 'BLACK' was not declared in this scope
169 | sprite.fillRect(4,20,150,172,BLACK);
winRadio.ino:189:45: error: 'YELLOW' was not declared in this scope
189 | sprite.fillRoundRect(160,140,74,3,2,YELLOW);
winRadio.ino:203:35: error: 'ORANGE' was not declared in this scope; did you mean 'ERANGE'?
203 | sprite.fillRect(4,7,150,3,ORANGE);
| ERANGE
winRadio.ino: In function 'void loop()':
winRadio.ino:353:9: error: 'audio' was not declared in this scope
353 | audio.connecttohost(stations[chosen].c_str());
winRadio.ino:365:9: error: 'audio' was not declared in this scope
365 | audio.setVolume(volume*4);
winRadio.ino:378:3: error: 'audio' was not declared in this scope
378 | audio.loop();
exit status 1
The first 1/2 dozen compile attempts it was missing .h files so I found them (or at least the same name on my system) and copied them over. Then it wanted a library so I found it (some GFX library that I had to go and find the .zip file). Then I tried to compile - I thought it hung. I was going to post a question about hanging during compile but then I saw it came back - with these errors. Any advice?
