ptillisch,
Thank you for the constructive response. Here is a link to the source sketch file:
// CYD-GOLD - Main sketch
// ESP32-S3 Internet Radio / MP3 Player / Alarm Clock
// Entry points:
// setup() - hardware init, WiFi, LVGL, home screen
// loop() - audio, LEDs, LVGL, WiFi watchdog, sleep
// All UI screens are in ui_*.cpp files.
// Config persisted in LittleFS /config.bin.
// Stations loaded from SD /radios.json.
#include <Arduino.h>
#include "LittleFS.h"
#include "FS.h"
#include "Audio.h"
#include <WiFi.h>
#include <lvgl.h>
#include <WebServer.h>
This file has been truncated. show original
Dependencies
Library Version
ESP32-audioI2S 3.4.6
LVGL 8.3.11
FastLED 3.10.3
RTClib 2.1.4
ArduinoJson 7.4.3
TFT_eSPI 2.5.43
Arduino IDE Board Settings
Board ESP32S3 Dev Module
Flash Size 16MB (128Mb)
Part. Scheme 16M Flash (3MB APP/9.9MB FATFS)
PSRAM OPI PSRAM
CPU Frequency 240MHz (WiFi)
Upload Speed 115200
Below is the verbose output from the verify/compile in Arduino IDE 2.3.10.
Thanks again,
Tim
FQBN: esp32:esp32:esp32s3
Using board 'esp32s3' from platform in folder: C:\Users\tjb02\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8
Using core 'esp32' from platform in folder: C:\Users\tjb02\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8
cmd /c if exist "D:\\Reveil-CYDGOLD-main\\esp32s3audio\\partitions.csv" COPY /y "D:\\Reveil-CYDGOLD-main\\esp32s3audio\\partitions.csv" "C:\\Users\\xxx\\AppData\\Local\\arduino\\sketches\\EDE84037B9CB12681397CC7F7EAD2EA1\\partitions.csv"
cmd /c if not exist "C:\\Users\\xxx\\AppData\\Local\\arduino\\sketches\\EDE84037B9CB12681397CC7F7EAD2EA1\\partitions.csv" if exist "C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.8\\variants\\esp32s3\\partitions.csv" COPY "C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.8\\variants\\esp32s3\\partitions.csv" "C:\\Users\\xxx\\AppData\\Local\\arduino\\sketches\\EDE84037B9CB12681397CC7F7EAD2EA1\\partitions.csv"
cmd /c if not exist "C:\\Users\\xxx\\AppData\\Local\\arduino\\sketches\\EDE84037B9CB12681397CC7F7EAD2EA1\\partitions.csv" COPY "C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.8\\tools\\partitions\\default.csv" "C:\\Users\\xxx\\AppData\\Local\\arduino\\sketches\\EDE84037B9CB12681397CC7F7EAD2EA1\\partitions.csv"
cmd /c IF EXIST "D:\\Reveil-CYDGOLD-main\\esp32s3audio\\bootloader.bin" ( COPY /y "D:\\Reveil-CYDGOLD-main\\esp32s3audio\\bootloader.bin" "C:\\Users\\xxx\\AppData\\Local\\arduino\\sketches\\EDE84037B9CB12681397CC7F7EAD2EA1\\esp32s3audio.ino.bootloader.bin" ) ELSE ( IF EXIST "C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.8\\variants\\esp32s3\\bootloader.bin" ( COPY "C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.8\\variants\\esp32s3\\bootloader.bin" "C:\\Users\\xxx\\AppData\\Local\\arduino\\sketches\\EDE84037B9CB12681397CC7F7EAD2EA1\\esp32s3audio.ino.bootloader.bin" ) ELSE ( "C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esptool_py\\5.2.0\\esptool.exe" --chip esp32s3 elf2image --flash-mode dio --flash-freq 80m --flash-size 4MB -o "C:\\Users\\xxx\\AppData\\Local\\arduino\\sketches\\EDE84037B9CB12681397CC7F7EAD2EA1\\esp32s3audio.ino.bootloader.bin" "C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32s3-libs\\3.3.8\\bin\\bootloader_qio_80m.elf" ) )
esptool v5.2.0
Creating ESP32-S3 image...
Merged 2 ELF sections.
Successfully created ESP32-S3 image.
cmd /c if exist "D:\\Reveil-CYDGOLD-main\\esp32s3audio\\build_opt.h" COPY /y "D:\\Reveil-CYDGOLD-main\\esp32s3audio\\build_opt.h" "C:\\Users\\xxx\\AppData\\Local\\arduino\\sketches\\EDE84037B9CB12681397CC7F7EAD2EA1\\build_opt.h"
cmd /c if not exist "C:\\Users\\xxx\\AppData\\Local\\arduino\\sketches\\EDE84037B9CB12681397CC7F7EAD2EA1\\build_opt.h" type nul > "C:\\Users\\xxx\\AppData\\Local\\arduino\\sketches\\EDE84037B9CB12681397CC7F7EAD2EA1\\build_opt.h"
cmd /c type nul > "C:\\Users\\xxx\\AppData\\Local\\arduino\\sketches\\EDE84037B9CB12681397CC7F7EAD2EA1/file_opts"
cmd /c COPY /y "C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32s3-libs\\3.3.8\\sdkconfig" "C:\\Users\\xxx\\AppData\\Local\\arduino\\sketches\\EDE84037B9CB12681397CC7F7EAD2EA1\\sdkconfig"
1 file(s) copied.
Detecting libraries used...
C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2601/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S3_DEV" -DARDUINO_VARIANT="esp32s3" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/defines -ID:\Reveil-CYDGOLD-main\esp32s3audio -iprefix C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/include/ @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/includes -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/qio_qspi/include -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\cores\esp32 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\variants\esp32s3 @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/build_opt.h @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/file_opts C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged -o nul -MMD -MF C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged.libsdetect.d
Alternatives for LittleFS.h: [LittleFS@3.3.8]
ResolveLibrary(LittleFS.h)
-> candidates: [LittleFS@3.3.8]
C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2601/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S3_DEV" -DARDUINO_VARIANT="esp32s3" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/defines -ID:\Reveil-CYDGOLD-main\esp32s3audio -iprefix C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/include/ @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/includes -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/qio_qspi/include -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\cores\esp32 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\variants\esp32s3 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\LittleFS\src @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/build_opt.h @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/file_opts C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged -o nul -MMD -MF C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged.libsdetect.d
Alternatives for FS.h: [FS@3.3.8]
ResolveLibrary(FS.h)
-> candidates: [FS@3.3.8]
C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2601/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S3_DEV" -DARDUINO_VARIANT="esp32s3" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/defines -ID:\Reveil-CYDGOLD-main\esp32s3audio -iprefix C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/include/ @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/includes -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/qio_qspi/include -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\cores\esp32 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\variants\esp32s3 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\LittleFS\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FS\src @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/build_opt.h @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/file_opts C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged -o nul -MMD -MF C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged.libsdetect.d
Alternatives for Audio.h: [ESP32-audioI2S-master@3.4.6]
ResolveLibrary(Audio.h)
-> candidates: [ESP32-audioI2S-master@3.4.6]
C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2601/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S3_DEV" -DARDUINO_VARIANT="esp32s3" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/defines -ID:\Reveil-CYDGOLD-main\esp32s3audio -iprefix C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/include/ @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/includes -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/qio_qspi/include -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\cores\esp32 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\variants\esp32s3 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\LittleFS\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FS\src -Id:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/build_opt.h @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/file_opts C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged -o nul -MMD -MF C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged.libsdetect.d
Alternatives for FFat.h: [FFat@3.3.8]
ResolveLibrary(FFat.h)
-> candidates: [FFat@3.3.8]
C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2601/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S3_DEV" -DARDUINO_VARIANT="esp32s3" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/defines -ID:\Reveil-CYDGOLD-main\esp32s3audio -iprefix C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/include/ @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/includes -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/qio_qspi/include -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\cores\esp32 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\variants\esp32s3 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\LittleFS\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FS\src -Id:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FFat\src @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/build_opt.h @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/file_opts C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged -o nul -MMD -MF C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged.libsdetect.d
Alternatives for NetworkClient.h: [Networking@3.3.8]
ResolveLibrary(NetworkClient.h)
-> candidates: [Networking@3.3.8]
C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2601/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S3_DEV" -DARDUINO_VARIANT="esp32s3" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/defines -ID:\Reveil-CYDGOLD-main\esp32s3audio -iprefix C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/include/ @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/includes -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/qio_qspi/include -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\cores\esp32 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\variants\esp32s3 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\LittleFS\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FS\src -Id:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FFat\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Network\src @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/build_opt.h @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/file_opts C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged -o nul -MMD -MF C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged.libsdetect.d
Alternatives for NetworkClientSecure.h: [NetworkClientSecure@3.3.8]
ResolveLibrary(NetworkClientSecure.h)
-> candidates: [NetworkClientSecure@3.3.8]
C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2601/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S3_DEV" -DARDUINO_VARIANT="esp32s3" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/defines -ID:\Reveil-CYDGOLD-main\esp32s3audio -iprefix C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/include/ @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/includes -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/qio_qspi/include -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\cores\esp32 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\variants\esp32s3 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\LittleFS\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FS\src -Id:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FFat\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Network\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\NetworkClientSecure\src @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/build_opt.h @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/file_opts C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged -o nul -MMD -MF C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged.libsdetect.d
Alternatives for SD.h: [SD@3.3.8]
ResolveLibrary(SD.h)
-> candidates: [SD@3.3.8]
C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2601/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S3_DEV" -DARDUINO_VARIANT="esp32s3" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/defines -ID:\Reveil-CYDGOLD-main\esp32s3audio -iprefix C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/include/ @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/includes -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/qio_qspi/include -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\cores\esp32 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\variants\esp32s3 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\LittleFS\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FS\src -Id:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FFat\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Network\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\NetworkClientSecure\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD\src @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/build_opt.h @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/file_opts C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged -o nul -MMD -MF C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged.libsdetect.d
Alternatives for SPI.h: [SPI@3.3.8]
ResolveLibrary(SPI.h)
-> candidates: [SPI@3.3.8]
C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2601/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S3_DEV" -DARDUINO_VARIANT="esp32s3" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/defines -ID:\Reveil-CYDGOLD-main\esp32s3audio -iprefix C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/include/ @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/includes -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/qio_qspi/include -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\cores\esp32 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\variants\esp32s3 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\LittleFS\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FS\src -Id:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FFat\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Network\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\NetworkClientSecure\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SPI\src @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/build_opt.h @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/file_opts C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged -o nul -MMD -MF C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged.libsdetect.d
Alternatives for SD_MMC.h: [SD_MMC@3.3.8]
ResolveLibrary(SD_MMC.h)
-> candidates: [SD_MMC@3.3.8]
C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2601/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S3_DEV" -DARDUINO_VARIANT="esp32s3" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/defines -ID:\Reveil-CYDGOLD-main\esp32s3audio -iprefix C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/include/ @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/includes -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/qio_qspi/include -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\cores\esp32 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\variants\esp32s3 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\LittleFS\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FS\src -Id:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FFat\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Network\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\NetworkClientSecure\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SPI\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD_MMC\src @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/build_opt.h @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/file_opts C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged -o nul -MMD -MF C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged.libsdetect.d
Alternatives for WiFi.h: [WiFi@3.3.8]
ResolveLibrary(WiFi.h)
-> candidates: [WiFi@3.3.8]
C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2601/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S3_DEV" -DARDUINO_VARIANT="esp32s3" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/defines -ID:\Reveil-CYDGOLD-main\esp32s3audio -iprefix C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/include/ @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/includes -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/qio_qspi/include -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\cores\esp32 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\variants\esp32s3 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\LittleFS\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FS\src -Id:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FFat\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Network\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\NetworkClientSecure\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SPI\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD_MMC\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WiFi\src @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/build_opt.h @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/file_opts C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged -o nul -MMD -MF C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged.libsdetect.d
Alternatives for lvgl.h: [lvgl@8.3.10]
ResolveLibrary(lvgl.h)
-> candidates: [lvgl@8.3.10]
C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2601/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S3_DEV" -DARDUINO_VARIANT="esp32s3" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/defines -ID:\Reveil-CYDGOLD-main\esp32s3audio -iprefix C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/include/ @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/includes -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/qio_qspi/include -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\cores\esp32 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\variants\esp32s3 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\LittleFS\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FS\src -Id:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FFat\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Network\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\NetworkClientSecure\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SPI\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD_MMC\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WiFi\src -Id:\Program Files\Arduino IDE\libraries\lvgl\src @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/build_opt.h @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/file_opts C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged -o nul -MMD -MF C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged.libsdetect.d
Alternatives for WebServer.h: [WebServer@3.3.8]
ResolveLibrary(WebServer.h)
-> candidates: [WebServer@3.3.8]
C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2601/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S3_DEV" -DARDUINO_VARIANT="esp32s3" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/defines -ID:\Reveil-CYDGOLD-main\esp32s3audio -iprefix C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/include/ @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/includes -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/qio_qspi/include -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\cores\esp32 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\variants\esp32s3 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\LittleFS\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FS\src -Id:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FFat\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Network\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\NetworkClientSecure\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SPI\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD_MMC\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WiFi\src -Id:\Program Files\Arduino IDE\libraries\lvgl\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WebServer\src @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/build_opt.h @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/file_opts C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged -o nul -MMD -MF C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged.libsdetect.d
Alternatives for Update.h: [Update@3.3.8]
ResolveLibrary(Update.h)
-> candidates: [Update@3.3.8]
C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2601/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S3_DEV" -DARDUINO_VARIANT="esp32s3" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/defines -ID:\Reveil-CYDGOLD-main\esp32s3audio -iprefix C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/include/ @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/includes -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/qio_qspi/include -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\cores\esp32 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\variants\esp32s3 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\LittleFS\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FS\src -Id:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FFat\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Network\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\NetworkClientSecure\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SPI\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD_MMC\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WiFi\src -Id:\Program Files\Arduino IDE\libraries\lvgl\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WebServer\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Update\src @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/build_opt.h @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/file_opts C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged -o nul -MMD -MF C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged.libsdetect.d
Alternatives for FastLED.h: [FastLED@3.10.5]
ResolveLibrary(FastLED.h)
-> candidates: [FastLED@3.10.5]
C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2601/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S3_DEV" -DARDUINO_VARIANT="esp32s3" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/defines -ID:\Reveil-CYDGOLD-main\esp32s3audio -iprefix C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/include/ @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/includes -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/qio_qspi/include -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\cores\esp32 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\variants\esp32s3 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\LittleFS\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FS\src -Id:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FFat\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Network\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\NetworkClientSecure\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SPI\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD_MMC\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WiFi\src -Id:\Program Files\Arduino IDE\libraries\lvgl\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WebServer\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Update\src -Id:\Program Files\Arduino IDE\libraries\FastLED\src @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/build_opt.h @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/file_opts C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged -o nul -MMD -MF C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged.libsdetect.d
Alternatives for RTClib.h: [RTClib@2.1.4]
ResolveLibrary(RTClib.h)
-> candidates: [RTClib@2.1.4]
C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2601/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S3_DEV" -DARDUINO_VARIANT="esp32s3" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/defines -ID:\Reveil-CYDGOLD-main\esp32s3audio -iprefix C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/include/ @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/includes -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/qio_qspi/include -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\cores\esp32 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\variants\esp32s3 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\LittleFS\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FS\src -Id:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FFat\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Network\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\NetworkClientSecure\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SPI\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD_MMC\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WiFi\src -Id:\Program Files\Arduino IDE\libraries\lvgl\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WebServer\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Update\src -Id:\Program Files\Arduino IDE\libraries\FastLED\src -Id:\Program Files\Arduino IDE\libraries\RTClib\src @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/build_opt.h @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/file_opts C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged -o nul -MMD -MF C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged.libsdetect.d
Alternatives for Adafruit_I2CDevice.h: [Adafruit BusIO@1.17.4]
ResolveLibrary(Adafruit_I2CDevice.h)
-> candidates: [Adafruit BusIO@1.17.4]
C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2601/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S3_DEV" -DARDUINO_VARIANT="esp32s3" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/defines -ID:\Reveil-CYDGOLD-main\esp32s3audio -iprefix C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/include/ @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/includes -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/qio_qspi/include -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\cores\esp32 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\variants\esp32s3 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\LittleFS\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FS\src -Id:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FFat\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Network\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\NetworkClientSecure\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SPI\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD_MMC\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WiFi\src -Id:\Program Files\Arduino IDE\libraries\lvgl\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WebServer\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Update\src -Id:\Program Files\Arduino IDE\libraries\FastLED\src -Id:\Program Files\Arduino IDE\libraries\RTClib\src -Id:\Program Files\Arduino IDE\libraries\Adafruit_BusIO @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/build_opt.h @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/file_opts C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged -o nul -MMD -MF C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged.libsdetect.d
Alternatives for Wire.h: [Wire@3.3.8]
ResolveLibrary(Wire.h)
-> candidates: [Wire@3.3.8]
C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2601/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S3_DEV" -DARDUINO_VARIANT="esp32s3" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/defines -ID:\Reveil-CYDGOLD-main\esp32s3audio -iprefix C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/include/ @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/includes -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/qio_qspi/include -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\cores\esp32 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\variants\esp32s3 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\LittleFS\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FS\src -Id:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FFat\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Network\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\NetworkClientSecure\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SPI\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD_MMC\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WiFi\src -Id:\Program Files\Arduino IDE\libraries\lvgl\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WebServer\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Update\src -Id:\Program Files\Arduino IDE\libraries\FastLED\src -Id:\Program Files\Arduino IDE\libraries\RTClib\src -Id:\Program Files\Arduino IDE\libraries\Adafruit_BusIO -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Wire\src @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/build_opt.h @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/file_opts C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged -o nul -MMD -MF C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged.libsdetect.d
Alternatives for TFT_eSPI.h: [TFT_eSPI@2.5.43]
ResolveLibrary(TFT_eSPI.h)
-> candidates: [TFT_eSPI@2.5.43]
C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2601/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S3_DEV" -DARDUINO_VARIANT="esp32s3" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/defines -ID:\Reveil-CYDGOLD-main\esp32s3audio -iprefix C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/include/ @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/includes -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/qio_qspi/include -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\cores\esp32 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\variants\esp32s3 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\LittleFS\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FS\src -Id:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FFat\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Network\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\NetworkClientSecure\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SPI\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD_MMC\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WiFi\src -Id:\Program Files\Arduino IDE\libraries\lvgl\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WebServer\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Update\src -Id:\Program Files\Arduino IDE\libraries\FastLED\src -Id:\Program Files\Arduino IDE\libraries\RTClib\src -Id:\Program Files\Arduino IDE\libraries\Adafruit_BusIO -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Wire\src -Id:\Program Files\Arduino IDE\libraries\TFT_eSPI @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/build_opt.h @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/file_opts C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged -o nul -MMD -MF C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged.libsdetect.d
Alternatives for SPIFFS.h: [SPIFFS@3.3.8]
ResolveLibrary(SPIFFS.h)
-> candidates: [SPIFFS@3.3.8]
C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2601/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S3_DEV" -DARDUINO_VARIANT="esp32s3" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/defines -ID:\Reveil-CYDGOLD-main\esp32s3audio -iprefix C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/include/ @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/includes -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/qio_qspi/include -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\cores\esp32 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\variants\esp32s3 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\LittleFS\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FS\src -Id:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FFat\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Network\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\NetworkClientSecure\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SPI\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD_MMC\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WiFi\src -Id:\Program Files\Arduino IDE\libraries\lvgl\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WebServer\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Update\src -Id:\Program Files\Arduino IDE\libraries\FastLED\src -Id:\Program Files\Arduino IDE\libraries\RTClib\src -Id:\Program Files\Arduino IDE\libraries\Adafruit_BusIO -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Wire\src -Id:\Program Files\Arduino IDE\libraries\TFT_eSPI -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SPIFFS\src @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/build_opt.h @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/file_opts C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged -o nul -MMD -MF C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged.libsdetect.d
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\FT6336.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\fonctions.cpp
Alternatives for ArduinoJson.h: [ArduinoJson@7.4.3]
ResolveLibrary(ArduinoJson.h)
-> candidates: [ArduinoJson@7.4.3]
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\font_7seg_90.c
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\led_control.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\themes.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\ui_alarme.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\ui_config.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\ui_equalizer.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\ui_home.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\ui_info.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\ui_lang.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\ui_leds.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\ui_mp3.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\ui_pays.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\ui_radio.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\ui_themes.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\ui_traduction.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\ui_wifi.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\web_server.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\LittleFS\src\LittleFS.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FS\src\FS.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FS\src\vfs_api.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src\Audio.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src\aac_decoder\aac_decoder.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src\aac_decoder\libfaad\neaacdec.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src\flac_decoder\flac_decoder.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src\mp3_decoder\mp3_decoder.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src\opus_decoder\celt.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src\opus_decoder\opus_decoder.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src\opus_decoder\range_decoder.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src\opus_decoder\silk.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src\vorbis_decoder\vorbis_decoder.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src\wav_decoder\wav_decoder.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FFat\src\FFat.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Network\src\NetworkClient.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Network\src\NetworkEvents.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Network\src\NetworkInterface.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Network\src\NetworkManager.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Network\src\NetworkServer.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Network\src\NetworkUdp.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\NetworkClientSecure\src\NetworkClientSecure.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\NetworkClientSecure\src\ssl_client.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD\src\SD.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD\src\sd_diskio.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD\src\sd_diskio_crc.c
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SPI\src\SPI.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD_MMC\src\SD_MMC.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WiFi\src\AP.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WiFi\src\STA.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WiFi\src\WiFi.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WiFi\src\WiFiAP.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WiFi\src\WiFiGeneric.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WiFi\src\WiFiMulti.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WiFi\src\WiFiSTA.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WiFi\src\WiFiScan.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\core\lv_disp.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\core\lv_event.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\core\lv_group.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\core\lv_indev.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\core\lv_indev_scroll.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\core\lv_obj.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\core\lv_obj_class.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\core\lv_obj_draw.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\core\lv_obj_pos.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\core\lv_obj_scroll.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\core\lv_obj_style.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\core\lv_obj_style_gen.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\core\lv_obj_tree.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\core\lv_refr.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\core\lv_theme.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\arm2d\lv_gpu_arm2d.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\lv_draw.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\lv_draw_arc.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\lv_draw_img.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\lv_draw_label.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\lv_draw_layer.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\lv_draw_line.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\lv_draw_mask.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\lv_draw_rect.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\lv_draw_transform.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\lv_draw_triangle.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\lv_img_buf.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\lv_img_cache.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\lv_img_decoder.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\nxp\pxp\lv_draw_pxp.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\nxp\pxp\lv_draw_pxp_blend.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\nxp\pxp\lv_gpu_nxp_pxp.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\nxp\pxp\lv_gpu_nxp_pxp_osa.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\nxp\vglite\lv_draw_vglite.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\nxp\vglite\lv_draw_vglite_arc.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\nxp\vglite\lv_draw_vglite_blend.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\nxp\vglite\lv_draw_vglite_line.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\nxp\vglite\lv_draw_vglite_rect.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\nxp\vglite\lv_vglite_buf.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\nxp\vglite\lv_vglite_utils.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\renesas\lv_gpu_d2_draw_label.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\renesas\lv_gpu_d2_ra6m3.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\sdl\lv_draw_sdl.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\sdl\lv_draw_sdl_arc.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\sdl\lv_draw_sdl_bg.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\sdl\lv_draw_sdl_composite.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\sdl\lv_draw_sdl_img.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\sdl\lv_draw_sdl_label.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\sdl\lv_draw_sdl_layer.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\sdl\lv_draw_sdl_line.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\sdl\lv_draw_sdl_mask.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\sdl\lv_draw_sdl_polygon.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\sdl\lv_draw_sdl_rect.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\sdl\lv_draw_sdl_stack_blur.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\sdl\lv_draw_sdl_texture_cache.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\sdl\lv_draw_sdl_utils.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\stm32_dma2d\lv_gpu_stm32_dma2d.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\sw\lv_draw_sw.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\sw\lv_draw_sw_arc.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\sw\lv_draw_sw_blend.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\sw\lv_draw_sw_dither.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\sw\lv_draw_sw_gradient.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\sw\lv_draw_sw_img.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\sw\lv_draw_sw_layer.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\sw\lv_draw_sw_letter.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\sw\lv_draw_sw_line.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\sw\lv_draw_sw_polygon.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\sw\lv_draw_sw_rect.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\sw\lv_draw_sw_transform.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\draw\swm341_dma2d\lv_gpu_swm341_dma2d.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\layouts\flex\lv_flex.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\layouts\grid\lv_grid.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\libs\bmp\lv_bmp.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\libs\ffmpeg\lv_ffmpeg.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\libs\freetype\lv_freetype.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\libs\fsdrv\lv_fs_fatfs.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\libs\fsdrv\lv_fs_posix.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\libs\fsdrv\lv_fs_stdio.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\libs\fsdrv\lv_fs_win32.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\libs\gif\gifdec.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\libs\gif\lv_gif.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\libs\png\lodepng.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\libs\png\lv_png.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\libs\qrcode\lv_qrcode.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\libs\qrcode\qrcodegen.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\libs\rlottie\lv_rlottie.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\libs\sjpg\lv_sjpg.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\libs\sjpg\tjpgd.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\lv_extra.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\others\fragment\lv_fragment.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\others\fragment\lv_fragment_manager.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\others\gridnav\lv_gridnav.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\others\ime\lv_ime_pinyin.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\others\imgfont\lv_imgfont.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\others\monkey\lv_monkey.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\others\msg\lv_msg.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\others\snapshot\lv_snapshot.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\themes\basic\lv_theme_basic.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\themes\default\lv_theme_default.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\themes\mono\lv_theme_mono.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\widgets\animimg\lv_animimg.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\widgets\calendar\lv_calendar.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\widgets\calendar\lv_calendar_header_arrow.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\widgets\calendar\lv_calendar_header_dropdown.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\widgets\chart\lv_chart.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\widgets\colorwheel\lv_colorwheel.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\widgets\imgbtn\lv_imgbtn.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\widgets\keyboard\lv_keyboard.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\widgets\led\lv_led.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\widgets\list\lv_list.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\widgets\menu\lv_menu.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\widgets\meter\lv_meter.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\widgets\msgbox\lv_msgbox.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\widgets\span\lv_span.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\widgets\spinbox\lv_spinbox.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\widgets\spinner\lv_spinner.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\widgets\tabview\lv_tabview.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\widgets\tileview\lv_tileview.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\extra\widgets\win\lv_win.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_dejavu_16_persian_hebrew.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_fmt_txt.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_loader.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_montserrat_10.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_montserrat_12.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_montserrat_12_subpx.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_montserrat_14.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_montserrat_16.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_montserrat_18.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_montserrat_20.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_montserrat_22.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_montserrat_24.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_montserrat_26.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_montserrat_28.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_montserrat_28_compressed.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_montserrat_30.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_montserrat_32.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_montserrat_34.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_montserrat_36.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_montserrat_38.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_montserrat_40.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_montserrat_42.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_montserrat_44.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_montserrat_46.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_montserrat_48.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_montserrat_8.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_simsun_16_cjk.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_unscii_16.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\font\lv_font_unscii_8.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\hal\lv_hal_disp.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\hal\lv_hal_indev.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\hal\lv_hal_tick.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\misc\lv_anim.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\misc\lv_anim_timeline.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\misc\lv_area.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\misc\lv_async.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\misc\lv_bidi.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\misc\lv_color.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\misc\lv_fs.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\misc\lv_gc.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\misc\lv_ll.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\misc\lv_log.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\misc\lv_lru.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\misc\lv_math.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\misc\lv_mem.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\misc\lv_printf.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\misc\lv_style.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\misc\lv_style_gen.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\misc\lv_templ.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\misc\lv_timer.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\misc\lv_tlsf.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\misc\lv_txt.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\misc\lv_txt_ap.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\misc\lv_utils.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\widgets\lv_arc.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\widgets\lv_bar.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\widgets\lv_btn.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\widgets\lv_btnmatrix.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\widgets\lv_canvas.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\widgets\lv_checkbox.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\widgets\lv_dropdown.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\widgets\lv_img.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\widgets\lv_label.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\widgets\lv_line.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\widgets\lv_objx_templ.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\widgets\lv_roller.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\widgets\lv_slider.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\widgets\lv_switch.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\widgets\lv_table.c
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\lvgl\src\widgets\lv_textarea.c
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WebServer\src\Parsing.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WebServer\src\WebServer.cpp
Alternatives for SHA1Builder.h: [Hash@3.3.8]
ResolveLibrary(SHA1Builder.h)
-> candidates: [Hash@3.3.8]
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WebServer\src\detail\mimetable.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WebServer\src\middleware\AuthenticationMiddleware.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WebServer\src\middleware\CorsMiddleware.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WebServer\src\middleware\LoggingMiddleware.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WebServer\src\middleware\MiddlewareChain.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Update\src\HttpsOTAUpdate.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Update\src\Updater.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Update\src\Updater_Signing.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\fl\build\extras+.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\fl\build\fl.asset+.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\fl\build\fl.audio+.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\fl\build\fl.channels+.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\fl\build\fl.chipsets+.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\fl\build\fl.codec+.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\fl\build\fl.control+.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\fl\build\fl.font+.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\fl\build\fl.fx+.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\fl\build\fl.gfx+.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\fl\build\fl.log+.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\fl\build\fl.math+.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\fl\build\fl.net+.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\fl\build\fl.remote+.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\fl\build\fl.sensors+.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\fl\build\fl.stl+.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\fl\build\fl.system+.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\fl\build\fl.system.sd+.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\fl\build\fl.task+.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\fl\build\fl.test+.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\fl\build\fl.ui+.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\fl\build\fl.video+.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\fl\build\fl.wdt+.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\fl\build\platforms+.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\fl\build\src.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\fl\build\third_party+.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\platforms\esp\32\drivers\gpio_isr_rx\fast_isr.S
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\FastLED\src\third_party\libhelix_mp3\real\arm\asmpoly_gcc.S
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\RTClib\src\RTC_DS1307.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\RTClib\src\RTC_DS3231.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\RTClib\src\RTC_Micros.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\RTClib\src\RTC_Millis.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\RTClib\src\RTC_PCF8523.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\RTClib\src\RTC_PCF8563.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\RTClib\src\RTClib.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\Adafruit_BusIO\Adafruit_BusIO_Register.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\Adafruit_BusIO\Adafruit_GenericDevice.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\Adafruit_BusIO\Adafruit_I2CDevice.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\Adafruit_BusIO\Adafruit_SPIDevice.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Wire\src\Wire.cpp
Using cached library dependencies for file: d:\Program Files\Arduino IDE\libraries\TFT_eSPI\TFT_eSPI.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SPIFFS\src\SPIFFS.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Hash\src\PBKDF2_HMACBuilder.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Hash\src\SHA1Builder.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Hash\src\SHA2Builder.cpp
Using cached library dependencies for file: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Hash\src\SHA3Builder.cpp
Generating function prototypes...
C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp-x32\2601/bin/xtensa-esp32s3-elf-g++ -c @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/cpp_flags -w -Os -Werror=return-type -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 -DARDUINO_BOARD="ESP32S3_DEV" -DARDUINO_VARIANT="esp32s3" -DARDUINO_PARTITION_default -DARDUINO_HOST_OS="windows" -DARDUINO_FQBN="esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/defines -ID:\Reveil-CYDGOLD-main\esp32s3audio -iprefix C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/include/ @C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/flags/includes -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/qio_qspi/include -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\cores\esp32 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\variants\esp32s3 -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\LittleFS\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FS\src -Id:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FFat\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Network\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\NetworkClientSecure\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SPI\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD_MMC\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WiFi\src -Id:\Program Files\Arduino IDE\libraries\lvgl\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WebServer\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Update\src -Id:\Program Files\Arduino IDE\libraries\FastLED\src -Id:\Program Files\Arduino IDE\libraries\RTClib\src -Id:\Program Files\Arduino IDE\libraries\Adafruit_BusIO -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Wire\src -Id:\Program Files\Arduino IDE\libraries\TFT_eSPI -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SPIFFS\src -Id:\Program Files\Arduino IDE\libraries\ArduinoJson\src -IC:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Hash\src @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/build_opt.h @C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1/file_opts C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\esp32s3audio.ino.cpp.merged -o C:\Users\xxx\AppData\Local\Temp\4008286638\sketch_merged.cpp
C:\Users\xxx\AppData\Local\Arduino15\packages\builtin\tools\ctags\5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives C:\Users\xxx\AppData\Local\Temp\4008286638\sketch_merged.cpp
Compiling sketch...
Using previously compiled file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\ui_config.cpp.o
"C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp-x32\\2601/bin/xtensa-esp32s3-elf-g++" -MMD -c "@C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32s3-libs\\3.3.8/flags/cpp_flags" -Os -Werror=return-type -DF_CPU=240000000L -DARDUINO=10607 -DARDUINO_ESP32S3_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD=\"ESP32S3_DEV\"" "-DARDUINO_VARIANT=\"esp32s3\"" -DARDUINO_PARTITION_default "-DARDUINO_HOST_OS=\"windows\"" "-DARDUINO_FQBN=\"esp32:esp32:esp32s3:UploadSpeed=921600,USBMode=hwcdc,CDCOnBoot=default,MSCOnBoot=default,DFUOnBoot=default,UploadMode=default,CPUFreq=240,FlashMode=qio,FlashSize=4M,PartitionScheme=default,DebugLevel=none,PSRAM=disabled,LoopCore=1,EventsCore=1,EraseFlash=none,JTAGAdapter=default,ZigbeeMode=default\"" -DESP32=ESP32 -DCORE_DEBUG_LEVEL=0 -DARDUINO_RUNNING_CORE=1 -DARDUINO_EVENT_RUNNING_CORE=1 -DARDUINO_USB_MODE=1 -DARDUINO_USB_CDC_ON_BOOT=0 -DARDUINO_USB_MSC_ON_BOOT=0 -DARDUINO_USB_DFU_ON_BOOT=0 "@C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32s3-libs\\3.3.8/flags/defines" "-ID:\\Reveil-CYDGOLD-main\\esp32s3audio" -iprefix "C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32s3-libs\\3.3.8/include/" "@C:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32s3-libs\\3.3.8/flags/includes" "-IC:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\esp32s3-libs\\3.3.8/qio_qspi/include" "-IC:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.8\\cores\\esp32" "-IC:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.8\\variants\\esp32s3" "-IC:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.8\\libraries\\LittleFS\\src" "-IC:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.8\\libraries\\FS\\src" "-Id:\\Program Files\\Arduino IDE\\libraries\\ESP32-audioI2S-master\\src" "-IC:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.8\\libraries\\FFat\\src" "-IC:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.8\\libraries\\Network\\src" "-IC:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.8\\libraries\\NetworkClientSecure\\src" "-IC:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.8\\libraries\\SD\\src" "-IC:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.8\\libraries\\SPI\\src" "-IC:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.8\\libraries\\SD_MMC\\src" "-IC:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.8\\libraries\\WiFi\\src" "-Id:\\Program Files\\Arduino IDE\\libraries\\lvgl\\src" "-IC:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.8\\libraries\\WebServer\\src" "-IC:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.8\\libraries\\Update\\src" "-Id:\\Program Files\\Arduino IDE\\libraries\\FastLED\\src" "-Id:\\Program Files\\Arduino IDE\\libraries\\RTClib\\src" "-Id:\\Program Files\\Arduino IDE\\libraries\\Adafruit_BusIO" "-IC:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.8\\libraries\\Wire\\src" "-Id:\\Program Files\\Arduino IDE\\libraries\\TFT_eSPI" "-IC:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.8\\libraries\\SPIFFS\\src" "-Id:\\Program Files\\Arduino IDE\\libraries\\ArduinoJson\\src" "-IC:\\Users\\xxx\\AppData\\Local\\Arduino15\\packages\\esp32\\hardware\\esp32\\3.3.8\\libraries\\Hash\\src" "@C:\\Users\\xxx\\AppData\\Local\\arduino\\sketches\\EDE84037B9CB12681397CC7F7EAD2EA1/build_opt.h" "@C:\\Users\\xxx\\AppData\\Local\\arduino\\sketches\\EDE84037B9CB12681397CC7F7EAD2EA1/file_opts" "C:\\Users\\xxx\\AppData\\Local\\arduino\\sketches\\EDE84037B9CB12681397CC7F7EAD2EA1\\sketch\\esp32s3audio.ino.cpp" -o "C:\\Users\\xxx\\AppData\\Local\\arduino\\sketches\\EDE84037B9CB12681397CC7F7EAD2EA1\\sketch\\esp32s3audio.ino.cpp.o"
Using previously compiled file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\font_7seg_90.c.o
Using previously compiled file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\themes.cpp.o
Using previously compiled file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\FT6336.cpp.o
Using previously compiled file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\fonctions.cpp.o
Using previously compiled file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\ui_lang.cpp.o
Using previously compiled file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\led_control.cpp.o
Using previously compiled file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\ui_alarme.cpp.o
Using previously compiled file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\ui_leds.cpp.o
Using previously compiled file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\ui_info.cpp.o
Using previously compiled file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\ui_pays.cpp.o
Using previously compiled file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\ui_equalizer.cpp.o
Using previously compiled file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\ui_home.cpp.o
Using previously compiled file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\ui_traduction.cpp.o
Using previously compiled file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\ui_themes.cpp.o
Using previously compiled file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\web_server.cpp.o
Using previously compiled file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\ui_wifi.cpp.o
Using previously compiled file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\ui_radio.cpp.o
Using previously compiled file: C:\Users\xxx\AppData\Local\arduino\sketches\EDE84037B9CB12681397CC7F7EAD2EA1\sketch\ui_mp3.cpp.o
In file included from d:\Program Files\Arduino IDE\libraries\TFT_eSPI/User_Setup_Select.h:27,
from d:\Program Files\Arduino IDE\libraries\TFT_eSPI/TFT_eSPI.h:69,
from D:\Reveil-CYDGOLD-main\esp32s3audio\display_gui.h:4,
from D:\Reveil-CYDGOLD-main\esp32s3audio\esp32s3audio.ino:28:
d:\Program Files\Arduino IDE\libraries\TFT_eSPI/User_Setup.h:69:9: warning: "TFT_BL" redefined
69 | #define TFT_BL 21 // LED back-light control pin
In file included from D:\Reveil-CYDGOLD-main\esp32s3audio\esp32s3audio.ino:26:
D:\Reveil-CYDGOLD-main\esp32s3audio\config.h:21:9: note: this is the location of the previous definition
21 | #define TFT_BL 45 // Backlight PWM
d:\Program Files\Arduino IDE\libraries\TFT_eSPI/User_Setup.h:272:9: warning: "TFT_MISO" redefined
272 | #define TFT_MISO 12
D:\Reveil-CYDGOLD-main\esp32s3audio\config.h:20:9: note: this is the location of the previous definition
20 | #define TFT_MISO 13
d:\Program Files\Arduino IDE\libraries\TFT_eSPI/User_Setup.h:273:9: warning: "TFT_MOSI" redefined
273 | #define TFT_MOSI 13
D:\Reveil-CYDGOLD-main\esp32s3audio\config.h:15:9: note: this is the location of the previous definition
15 | #define TFT_MOSI 11
d:\Program Files\Arduino IDE\libraries\TFT_eSPI/User_Setup.h:274:9: warning: "TFT_SCLK" redefined
274 | #define TFT_SCLK 14
D:\Reveil-CYDGOLD-main\esp32s3audio\config.h:16:9: note: this is the location of the previous definition
16 | #define TFT_SCLK 12
d:\Program Files\Arduino IDE\libraries\TFT_eSPI/User_Setup.h:275:9: warning: "TFT_CS" redefined
275 | #define TFT_CS 15 // Chip select control pin
D:\Reveil-CYDGOLD-main\esp32s3audio\config.h:17:9: note: this is the location of the previous definition
17 | #define TFT_CS 10
d:\Program Files\Arduino IDE\libraries\TFT_eSPI/User_Setup.h:276:9: warning: "TFT_DC" redefined
276 | #define TFT_DC 2 // Data Command control pin
D:\Reveil-CYDGOLD-main\esp32s3audio\config.h:18:9: note: this is the location of the previous definition
18 | #define TFT_DC 46
In file included from d:/Program Files/Arduino IDE/libraries/lvgl/src/core/lv_obj.h:140,
from d:/Program Files/Arduino IDE/libraries/lvgl/lvgl.h:35,
from d:\Program Files\Arduino IDE\libraries\lvgl\src/lvgl.h:17,
from D:\Reveil-CYDGOLD-main\esp32s3audio\esp32s3audio.ino:19:
d:/Program Files/Arduino IDE/libraries/lvgl/src/core/lv_obj_style.h: In function 'void lv_obj_remove_style_all(_lv_obj_t*)':
d:/Program Files/Arduino IDE/libraries/lvgl/src/core/lv_obj_style.h:94:48: warning: bitwise operation between different enumeration types '<unnamed enum>' and '<unnamed enum>' is deprecated [-Wdeprecated-enum-enum-conversion]
94 | lv_obj_remove_style(obj, NULL, LV_PART_ANY | LV_STATE_ANY);
In file included from d:\Program Files\Arduino IDE\libraries\FastLED\src/fl/system/delay.h:18,
from d:\Program Files\Arduino IDE\libraries\FastLED\src/fastled_delay.h:8,
from d:\Program Files\Arduino IDE\libraries\FastLED\src/fl/system/fastled.h:89,
from d:\Program Files\Arduino IDE\libraries\FastLED\src/FastLED.h:159,
from D:\Reveil-CYDGOLD-main\esp32s3audio\esp32s3audio.ino:23:
d:\Program Files\Arduino IDE\libraries\FastLED\src/platforms/delay.h: At global scope:
d:\Program Files\Arduino IDE\libraries\FastLED\src/platforms/delay.h:62:63: warning: optimization attribute on 'void fl::delayNanoseconds_impl(u32, u32)' follows definition but the attribute doesn't match [-Wattributes]
62 | FASTLED_FORCE_INLINE void delayNanoseconds_impl(u32 ns, u32 hz) FL_NOEXCEPT;
In file included from d:\Program Files\Arduino IDE\libraries\FastLED\src/platforms/delay.h:31:
d:\Program Files\Arduino IDE\libraries\FastLED\src/platforms/esp/32/core/delay.h:33:27: note: previous definition of 'void fl::delayNanoseconds_impl(u32, u32)' here
33 | FASTLED_FORCE_INLINE void delayNanoseconds_impl(u32 ns, u32 hz) FL_NOEXCEPT {
d:\Program Files\Arduino IDE\libraries\FastLED\src/platforms/delay.h:66:55: warning: optimization attribute on 'void fl::delayNanoseconds_impl(u32)' follows definition but the attribute doesn't match [-Wattributes]
66 | FASTLED_FORCE_INLINE void delayNanoseconds_impl(u32 ns) FL_NOEXCEPT;
d:\Program Files\Arduino IDE\libraries\FastLED\src/platforms/esp/32/core/delay.h:41:27: note: previous definition of 'void fl::delayNanoseconds_impl(u32)' here
41 | FASTLED_FORCE_INLINE void delayNanoseconds_impl(u32 ns) FL_NOEXCEPT {
D:\Reveil-CYDGOLD-main\esp32s3audio\esp32s3audio.ino: In function 'void enter_deep_sleep()':
D:\Reveil-CYDGOLD-main\esp32s3audio\esp32s3audio.ino:85:44: warning: 'ESP_EXT1_WAKEUP_ALL_LOW' is deprecated: wakeup mode "ALL_LOW" is no longer supported after ESP32, please use ESP_EXT1_WAKEUP_ANY_LOW instead [-Wdeprecated-declarations]
85 | esp_sleep_enable_ext1_wakeup(pin_mask, ESP_EXT1_WAKEUP_ALL_LOW);
In file included from C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\cores\esp32/esp32-hal.h:33,
from C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\cores\esp32/Arduino.h:44,
from D:\Reveil-CYDGOLD-main\esp32s3audio\esp32s3audio.ino:14:
C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\tools\esp32s3-libs\3.3.8/include/esp_hw_support/include/esp_sleep.h:39:5: note: declared here
39 | ESP_EXT1_WAKEUP_ALL_LOW __attribute__((deprecated("wakeup mode \"ALL_LOW\" is no longer supported after ESP32, \
D:\Reveil-CYDGOLD-main\esp32s3audio\esp32s3audio.ino: In function 'void lvgl_tick_cb(void*)':
D:\Reveil-CYDGOLD-main\esp32s3audio\esp32s3audio.ino:92:45: error: 'lv_tick_inc' was not declared in this scope; did you mean 'lv_tick_get'?
92 | static void IRAM_ATTR lvgl_tick_cb(void*) { lv_tick_inc(1); }
| lv_tick_get
Using library LittleFS at version 3.3.8 in folder: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\LittleFS
Using library FS at version 3.3.8 in folder: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FS
Using library ESP32-audioI2S-master at version 3.4.6 in folder: D:\Program Files\Arduino IDE\libraries\ESP32-audioI2S-master
Using library FFat at version 3.3.8 in folder: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\FFat
Using library Networking at version 3.3.8 in folder: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Network
Using library NetworkClientSecure at version 3.3.8 in folder: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\NetworkClientSecure
Using library SD at version 3.3.8 in folder: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD
Using library SPI at version 3.3.8 in folder: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SPI
Using library SD_MMC at version 3.3.8 in folder: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SD_MMC
Using library WiFi at version 3.3.8 in folder: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WiFi
Using library lvgl at version 8.3.10 in folder: D:\Program Files\Arduino IDE\libraries\lvgl
Using library WebServer at version 3.3.8 in folder: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\WebServer
Using library Update at version 3.3.8 in folder: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Update
Using library FastLED at version 3.10.5 in folder: D:\Program Files\Arduino IDE\libraries\FastLED
Using library RTClib at version 2.1.4 in folder: D:\Program Files\Arduino IDE\libraries\RTClib
Using library Adafruit BusIO at version 1.17.4 in folder: D:\Program Files\Arduino IDE\libraries\Adafruit_BusIO
Using library Wire at version 3.3.8 in folder: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Wire
Using library TFT_eSPI at version 2.5.43 in folder: D:\Program Files\Arduino IDE\libraries\TFT_eSPI
Using library SPIFFS at version 3.3.8 in folder: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\SPIFFS
Using library ArduinoJson at version 7.4.3 in folder: D:\Program Files\Arduino IDE\libraries\ArduinoJson
Using library Hash at version 3.3.8 in folder: C:\Users\xxx\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.8\libraries\Hash
exit status 1
Compilation error: 'lv_tick_inc' was not declared in this scope; did you mean 'lv_tick_get'?
