#include <NewPing.h>
#include <Wire.h>
#define TRIGGER_PIN 7
#define ECHO_PIN 8
#define MAX_DISTANCE 200
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
int testled = 5;
byte ledState = LOW;
unsigned long currentMillis = 0;
pinMode(testled, OUTPUT);
if(ledState == LOW){
unsigned int uS = sonar.ping();
delay(30);
int distance = uS / US_ROUNDTRIP_CM;
if(distance <10){
ledState = HIGH;
currentMillis= millis();
digitalWrite(testled, ledState);
if (ledState == HIGH) {
if (millis()>(currentMillis+10000)) {
ledState = LOW;
I want the led to turn on when there is something in front of the ultrasonic sensor and then turn off when the ultrasonic sensor does not detect anything
Although I want this to happen in the background as I will also be running a another code which is going to be added to this 1
Currently the led just stays on it does not turn off
Ok. Your Calculation of the distance into cm looks wierd....
I made a code like this some time ago... Take a look at this:
(Dont wonder about the Language... Just some German :D)
#define trigPin 7 // Connect Trig on the module to pin 7 on the Arduino
#define echoPin 6 // Connect Echo on the module to pin 6 on the Arduino
int led = 3;
int led2 = 5;
int led3 = 4;
int repeat = 0;
pinMode(led, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(trigPin, OUTPUT); // Set the trigPin to output
digitalWrite(trigPin, LOW); // Set trigPin low to start
pinMode(echoPin, INPUT); // Set echoPin as an input
Serial.begin(9600); // Start a serial connection to view the Arduino output
delay(3000); // 3 second pause before we start
repeat = repeat + 1;
long duration; // Define the variable used for the pulse duration
digitalWrite(trigPin, HIGH); // Set the trigPin high, to start the measurement
delayMicroseconds(10); // Wait 10 uS
digitalWrite(trigPin, LOW); // Set the trigPin low, module will send a pulse
duration = pulseIn(echoPin, HIGH); // Read the pulse length from the module
duration = duration / 50; // Convert number to cm (range is 3cm - 4.5M)
if(repeat==10){
repeat = 0;
Serial.println("");
Serial.println("");
Serial.println("");
Serial.println("Entfernung in CM:");
Serial.println(duration); // Send the distance to the serial port
Serial.println("");
Serial.println("");
Serial.println("");
if(duration < 20){
Serial.println("Abstand: NAH");
} else
if(duration < 50){
Serial.println("Abstand: NORMAL");
} else
if(duration < 100){
Serial.println("Abstand: FERN");
delay(100); // Wait a second before the next reading
if(duration < 20){
digitalWrite(led, HIGH);
// Serial.println("Abstand: NAH");
} else
if(duration < 50){
// Serial.println("Abstand: NORMAL");
digitalWrite(led2, HIGH);
} else
if(duration < 100){
// Serial.println("Abstand: FERN");
digitalWrite(led3, HIGH);
digitalWrite(led,LOW);
digitalWrite(led2,LOW);
digitalWrite(led3,LOW);
CrossRoads:
Where is this given a value?
US_ROUNDTRIP_CM
Put a serial print after this line
and see what you are getting for distance
Add UL after this #
10000UL
#include <Wire.h>
#define ECHO_PIN 8
int testled = 5;
delay(30);
Serial.print("Ping: ");
Serial.print(uS / US_ROUNDTRIP_CM); // Convert ping time to distance in cm and print result (0 = outside set distance range)
Serial.println("cm");
if(distance <10){
ledState = HIGH;
ledState = LOW;
When doing this I can see that the distance is shown as 0 in the serial monitor, this can be the reason why the led is always on
This is the code I used to produce my code, now looking at this im very sure that there is something wrong with it but I cant really figure out what can anyone help me (im new to arduino):
#define TRIGGER_PIN 12 // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN 11 // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 450 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
Serial.begin(115200); // Open serial monitor at 115200 baud to see ping results.
pinMode(13,OUTPUT); // pin pe 13, fara rezistenta
delay(50); // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
unsigned int uS = sonar.ping(); // Send ping, get ping time in microseconds (uS).
if(uS / US_ROUNDTRIP_CM >100)
analogWrite(13, 255);
analogWrite(13, 0);
Try this code.
Change pins + connections to suit.
Change timing to suit.
On detection within range "on-state" in maintained for 3 sec.
One sec delay between pings.
#define trigPin 7
#define echoPin 8
#define datPin 13 // alternatively use as ledPin
float maxrange; // maximum detection range
long duration;
float distance;
pinMode(datPin, OUTPUT);
digitalWrite(trigPin, LOW); // ensure low state at start
delay(3000);
maxrange = 10;
digitalWrite(trigPin, HIGH); // initiate pulse
delayMicroseconds(10); // maintain pulse for 10�s
digitalWrite(trigPin, LOW); // terminate pulse
duration = pulseIn(echoPin, HIGH); // measures delay till echo heard
distance = duration / 29.1 / 2; // calculates distance in cm
if (distance < maxrange) {
digitalWrite(datPin, HIGH);
Serial.print("Activity Detected at ");
Serial.print(distance);
Serial.println(" cm");
delay(3000);
digitalWrite(datPin, LOW);}
else{
Serial.print("No Activity : ");
Serial.println(" cm");}
delay(1000); // maintain terminates state for 100ms
I think your problem is that NewPing will return 0 if the measurement fails (distance too short or too long). The minimum measurable distance is about 3 cm and you set the maximum to 200 cm. If the measurement is outside that range it will return 0 which is <10 so it will be counted as a HIT and turn the LED on for 10 seconds. Try this version:
// #include <Wire.h>
#define ECHO_PIN 8
int testled = 5;
unsigned long startMillis = 0;
if (ledState == LOW) {
// LED is off
int distance = sonar.ping_cm();
// If distance measured and is less than 10 cm, turn on the LED
if (distance > 0 && distance < 10) {
ledState = HIGH;
startMillis = millis();
} else { // ledState == HIGH
// If LED has been on for 10 seconds, turn it off
if (millis() - startMillis > 10000) {
ledState = LOW;
