hi guys i have code in which i have created functions and called it in main void loop via if else statement but the problem is whenever the statement gets true it executes the code only for 1 loop but i want that it executes nonstop unlimited loop like void loop does.What is problem with my code please help me out
here is my code
ardu#include <Servo.h> //Servo motor library. This is standard library
#include <NewPing.h> //Ultrasonic sensor function library. You must install this library
//our L298N control pins
const int LeftMotorForward = 7;
const int LeftMotorBackward = 6;
const int RightMotorForward = 4;
const int RightMotorBackward = 5;
//sensor pins
#define trig_pin A1 //analog input 1
#define echo_pin A2 //analog input 2
#define maximum_distance 200
boolean goesForward = false;
int distance = 100;
NewPing sonar(trig_pin, echo_pin, maximum_distance); //sensor function
Servo servo_motor; //our servo name
void setup(){
pinMode(RightMotorForward, OUTPUT);
pinMode(LeftMotorForward, OUTPUT);
pinMode(LeftMotorBackward, OUTPUT);
pinMode(RightMotorBackward, OUTPUT);
pinMode(13,OUTPUT);
Serial.println("serial communication stablished");
servo_motor.attach(9); //our servo pin
servo_motor.write(90);
delay(2000);
distance = readPing();
delay(100);
delay(100);
delay(100);
delay(100);
void loop(){
if (Serial.available())
char inChar = Serial.read();
Serial.println(inChar);
if (inChar == '1')
led();
Serial.println("Command completed LED turned ON");
if (inChar == '2')
digitalWrite(13, LOW);
Serial.println("Command completed LED turned OFF");
if (inChar == '3')
automode();
Serial.println("automode turned ON");
if (inChar == '4')
moveStop();
Serial.println("automode turned OFF");
int led (){
digitalWrite(13, HIGH);
int automode(){
int distanceRight = 0;
int distanceLeft = 0;
delay(50);
if (distance <= 20){
moveStop();
delay(300);
moveBackward();
delay(400);
moveStop();
delay(300);
distanceRight = lookRight();
delay(300);
distanceLeft = lookLeft();
delay(300);
if (distance >= distanceLeft){
turnRight();
moveStop();
else{
turnLeft();
moveStop();
else{
moveForward();
int lookRight(){
servo_motor.write(1);
int distance = readPing();
delay(100);
return distance;
int lookLeft(){
servo_motor.write(180);
delay(100);
return distance;
delay(100);
int readPing(){
delay(70);
int cm = sonar.ping_cm();
if (cm==0){
cm=250;
return cm;
void moveStop(){
digitalWrite(RightMotorForward, LOW);
digitalWrite(LeftMotorForward, LOW);
digitalWrite(RightMotorBackward, LOW);
digitalWrite(LeftMotorBackward, LOW);
void moveForward(){
if(!goesForward){
goesForward=true;
digitalWrite(LeftMotorForward, HIGH);
digitalWrite(RightMotorForward, HIGH);
void moveBackward(){
goesForward=false;
digitalWrite(LeftMotorBackward, HIGH);
digitalWrite(RightMotorBackward, HIGH);
void turnRight(){
void turnLeft(){
Thanks in advance
