Help writing a simple sketch, at power up send 2 RC5 IR sequences
Please post the sketch.
I thought it was working, but you didn't seem to need what fixed it just now.
a7
Quite. But your posted code syntax wasn't from 4.x.x version.
Hmmm will investigate after dinner. Maybe something is amiss with my IDE setup.
Here you go, could do with a tidy up at the end to put it to sleep:
#include <IRremote.h>  // Standard IR library for Arduino
// Define RC5 codes (address and command)
#define RC5_ADDRESS 0x10
#define RC5_POWER_ON 0x7B
#define RC5_SELECT_AV 0x5E
#define RC5_STANDBY 0x7C
// Define pin mapping
const int IR_SEND_PIN = 3;       // Digital pin 3 for IR LED
// For older versions of IRremote library
IRsend irsend(IR_SEND_PIN); // Explicitly specify the pin in older versions
  Serial.println("IR Remote Control - Testing Output");
  pinMode(IR_SEND_PIN, OUTPUT);  // Explicitly set the pin mode
  Serial.println("IR sender initialized on pin " + String(IR_SEND_PIN));
void sendRC5(uint8_t address, uint8_t command) {
  Serial.println("Sending RC5 - Address: " + String(address, HEX) + ", Command: " + String(command, HEX));
  for (int i = 0; i < 3; i++) {  // Send multiple times to increase chance of reception
    irsend.sendRC5(address, command, 0);
    delay(100);
  Serial.println("Command sent");
  // Start first RC5 transmission (Power On)
  Serial.println("Sending Power On command");
  sendRC5(RC5_ADDRESS, RC5_POWER_ON);
  delay(6000); // Wait 6 seconds
  // Start second RC5 transmission (Select AV input)
  Serial.println("Sending Select AV command");
  sendRC5(RC5_ADDRESS, RC5_SELECT_AV);
 while (1);   // processor spins here until power off or reset
  // Wait before repeating the sequence
  delay(10000);
Maybe its because I have 2 libraries installed? I deffo have the 4.4.1 installed.
Quite likely, Your code is from ancient version of the library.
Yes you were right, my folder path was set wrong.... sorted out the libraries to 4.4.2 from github and manually put it into the right place.
Below sketch now works with 4.4.2.
#include <IRremote.hpp>  // Updated include for latest IRremote library
#define IR_SEND_PIN 3       // Digital pin 3 for IR LED
  Serial.println("IR Remote Control");
  // Start the IR sender with the latest library syntax
  IrSender.begin(IR_SEND_PIN);  // Initialize the IR sender
  // Updated syntax for the latest library
  IrSender.sendRC5(address, command, 2); // Address, command, number of repeats (2 means send 3 times)
  delay(100); // Small delay after sending
  delay(7000); // Wait 7 seconds
  delay(10000);
NOTE:
For anyone wanting to attempt this, this was my final sketch for use on the Nano and it works fine. Just substitute your RC5 codes.
Now it's matching.. :+1:
Yaaaaay!
Onto the next problem. Nice that I got this work on the Nano, however my original plan was to get this work on the Digispark ATTiny board.
I've managed to follow the guide to get the drivers and IDE configured correctly and I can see it device manager. However, when I try to compile it for the digispark I'm getting a lot of errors (using the same sketch that compiles fine for the Nano)
Never tried with that.
Read the docs about attiny85:
Not having much luck, got past the compiling errors and managed to upload some sketches. I can get the IR LED output to work but the receiver ignores whatever is being sent by the ATtiny.
Not sure where to go from here.
Post the code, or say what code you have posted you are using unmodified.
a7
The first step is to get the ATTiny85 "Blink" example to flash and run. Then you know you have the boards file and the USB driver installed.
When you select the Sparkfun as the board, do you have an option to set the clock speed? If so, you might try 8MHz instead of 1MHz.
Also, when you say it's working with the Nano, does that mean you can control the other device from the Nano's IR? So in other words, it's outputting the RC5 commands correctly?
Hi, I can upload sketches to the ATTIny like the blink one fine. Everything is setup correctly.
Yes the project works fine on the Nano with the IR sequence accepted correctly by the second device, powers on and changes input as required.
I just can't get the sketch to work once I've ported it to the ATTiny.
// RC5 IR transmitter for Digispark using hardware PWM
// Focused on exact protocol compliance with precise timing
#include <avr/io.h>
#define IR_LED_PIN 4       // Using PB4 for IR transmission (PWM pin)
#define FEEDBACK_LED_PIN 1 // Using PB1 for visual feedback (built-in LED)
// RC5 protocol constants
#define RC5_ADDRESS 0x10   // Your confirmed address (0x10)
#define RC5_POWER 0x7B     // Your confirmed power code (0x7B)
#define RC5_AV 0x5E        // Your confirmed AV code (0x5E)
// RC5 timing (microseconds)
#define RC5_TIME_BASE 889  // Each RC5 bit is 1.778ms (2 × 889μs)
// Global toggle bit (changes each time a button is pressed)
boolean toggleBit = true;
  // Configure pins
  pinMode(IR_LED_PIN, OUTPUT);
  pinMode(FEEDBACK_LED_PIN, OUTPUT);
  // Configure Timer1 for 38kHz PWM on PB4
  TCCR1 = 0;                                // Clear timer configuration
  GTCCR = 0;                                // Clear GTCCR configuration
  TCCR1 = (1 << CTC1) | (1 << PWM1A) | (1 << COM1A0) | (1 << CS10); // Fast PWM, no prescaler
  OCR1C = 210;                              // Set TOP value (F_CPU / 38000 / 2)
  OCR1A = 70;                               // ~33% duty cycle
  // Brief delay for system stabilization
  // Send power command with 3 repetitions
    sendRC5(RC5_ADDRESS, RC5_POWER);
    delay(65);  // Standard RC5 gap between repetitions
  // Visual feedback
  flashFeedbackLED();
  // Send AV select command with 3 repetitions
    sendRC5(RC5_ADDRESS, RC5_AV);
  // Visual feedback
  flashFeedbackLED();
  delay(10000); // Wait before repeating the sequence
  // Toggle the toggle bit for next transmission
  toggleBit = !toggleBit;
void flashFeedbackLED() {
  digitalWrite(FEEDBACK_LED_PIN, HIGH);
  delay(200);
  digitalWrite(FEEDBACK_LED_PIN, LOW);
  uint16_t frame = 0;
  // Build the 14-bit RC5 frame
  frame = (1 << 13);              // First start bit (always 1)
  frame |= (1 << 12);             // Second start bit (always 1)
  frame |= (toggleBit ? 0 : 1) << 11; // Toggle bit (inverted for extended RC5)
  // Apply the 5-bit address
  frame |= (address & 0x1F) << 6;
  // Apply the 6-bit command
  frame |= (command & 0x3F);
  // Transmit the frame bit by bit, MSB first
  for (uint8_t i = 14; i > 0; i--) {
    // Extract bit value (0 or 1)
    uint8_t bit = (frame & (1 << (i-1))) ? 1 : 0;
    // Manchester encode and send this bit
    if (bit) {
      // Bit 1: space then mark
      ir_off(RC5_TIME_BASE);
      ir_on(RC5_TIME_BASE);
      // Bit 0: mark then space
  // Final space to end transmission
// Turn IR LED on (generate carrier)
void ir_on(unsigned int time) {
  // Enable PWM output
  GTCCR |= (1 << PWM1B) | (1 << COM1B1);
  delayMicroseconds(time);
// Turn IR LED off (stop carrier)
void ir_off(unsigned int time) {
  // Disable PWM output
  GTCCR &= ~((1 << PWM1B) | (1 << COM1B1));
  digitalWrite(IR_LED_PIN, LOW);
What is the clock speed of the digispark?
The ATtiny85 defaults to its 1-MHz internal clock
But if the comment is right,
210 * 38000 *2 is 16 MHz.
Where did the code for setting the carrier frequency constants come from?
a7
Everything is from the Arduino AI. Not sure what the clock speed is, will check.
I'm suspecting the issue is something like the carrier is not correct or the way the Attiny does the PWM. I can see output to the IR led but the receiver ignores it.
I'll book up a scope and compare it with the IR out on the Nano.
From library docs...
Tried that, didn't make a difference.... must be something else and ATTiny not working too good with these ATTiny chips. Will try a project a bit later based on Raw IR codes, I will set up the Uno I bought as a receiver to capture the codes and try a different approach. For now I will use the Nano as that works.
Good choice.
I kind of lost the problem at the moment. You still get errors while compiling? You use digispark or bare attiny85? At what frequency?
