HELP
Help with ISO C++ forbids comparison between pointer and integer.
I have a problem any one can help please, I'm very smart but i'm young and cant find an answer. hear is my code
if( FLOW == 2)<---------the part im getting the problem at.
void FLOW (int Flow)
if (digitalRead(buttonPin))
Flow = 1;
if (digitalRead(buttonPin2))
Flow = 2;
as much as I want to show, will show if need be.
Hello and welcome,
That condition (once fixed by adding () :slight_smile: ) will never be true because your function doesn't return anything.
You have to do something like this:
if( FLOW() == 2 )
  //do something when FLOW() returns 2
int FLOW()
    return 1;
  else if (digitalRead(buttonPin2))
    return 2;
  return 0;
Also don't double post, click the Remove button near your posts in the other topic, write a clear topic title not just "HELP"... and use code tags (the '#' button) around your code :slight_smile:
how should i change the code to fix it.
Deion:
Start by explaining what you are trying to do.
Read this before posting a programming question
Very useless thread title. Everyone wants help. Try being more specific.
    Flow = 1;
   Flow = 2;
Try guix code
  if( FLOW() == 2 )
  else if( FLOW() == 1 )
    //do something when FLOW() returns 1
    //do something when FLOW() returns 0
int FLOW()
    return 1;
    return 2;
  return 0;
Having a variable and a function with the same name is a recipe for disaster. Function names should imply what they do. FLOW() does not. Give the function a meaningful name, and do not declare it inside the if statement, and life will be better.
