Hi there,
I'm using a TFT shield on a Mega. But I want to add other features that need the timer pins it normally mates to. So I need to divert some of the shield pins to other Mega pins.
Here's the library section that already maps those shield pins for Mega:
//################################### MEGA2560 ##############################
#elif defined(__AVR_ATmega2560__) || defined(__AVR_ATmega1280__) //regular UNO shield on MEGA2560
#define RD_PORT PORTF
#define RD_PIN 0
#define WR_PORT PORTF
#define WR_PIN 1
#define CD_PORT PORTF
#define CD_PIN 2
#define CS_PORT PORTF
#define CS_PIN 3
#define RESET_PORT PORTF
#define RESET_PIN 4
#define EMASK 0x38
#define GMASK 0x20
#define HMASK 0x78
#define write_8(x) { PORTH &= ~HMASK; PORTG &= ~GMASK; PORTE &= ~EMASK; \
PORTH |= (((x) & (3<<0)) << 5); \
PORTE |= (((x) & (3<<2)) << 2); \
PORTG |= (((x) & (1<<4)) << 1); \
PORTE |= (((x) & (1<<5)) >> 2); \
PORTH |= (((x) & (3<<6)) >> 3); \
#define read_8() ( ((PINH & (3<<5)) >> 5)\
| ((PINE & (3<<4)) >> 2)\
| ((PING & (1<<5)) >> 1)\
| ((PINE & (1<<3)) << 2)\
| ((PINH & (3<<3)) << 3)\
#define setWriteDir() { DDRH |= HMASK; DDRG |= GMASK; DDRE |= EMASK; }
#define setReadDir() { DDRH &= ~HMASK; DDRG &= ~GMASK; DDRE &= ~EMASK; }
#define write8(x) { write_8(x); WR_STROBE; }
#define write16(x) { uint8_t h = (x)>>8, l = x; write8(h); write8(l); }
#define READ_8(dst) { RD_STROBE; dst = read_8(); RD_IDLE; }
#define READ_16(dst) { uint8_t hi; READ_8(hi); READ_8(dst); dst |= (hi << 8); }
#define PIN_LOW(p, b) (p) &= ~(1<<(b))
#define PIN_HIGH(p, b) (p) |= (1<<(b))
#define PIN_OUTPUT(p, b) *(&p-1) |= (1<<(b))
I'd like to change PH3,4,5,6 across to PA3,4,5,6
It seems to begin with the hex addresses where EMASK, GMASK & HMASK are defined.
Firstly - how or where do I find the hex value of all Mega port pins?
I'm hoping if I can find those, it will just be a case of re-mathing the mask offsetting in the read & write functions up there.
Any further advice or unseen catastrophes to point me to?
Thank you!
J
