I somehow got this working. But for me it looks like there should be a simpler way. Can I simplify this code and avoid the sprintf / buffer somehow?
// uint64_t pt = 0x1105202216300000;
char buf1[5];
sprintf_P(buf1, PSTR("%02x"), ((byte)(pt >> 32)));
ds3231.setYear((byte)(String(buf1).toInt()));
sprintf_P(buf1, PSTR("%02x"), ((byte)(pt >> 48)));
ds3231.setMonth(String(buf1).toInt());
sprintf_P(buf1, PSTR("%02x"), ((byte)(pt >> 56)));
ds3231.setDate(String(buf1).toInt());
sprintf_P(buf1, PSTR("%02x"), ((byte)(pt >> 24)));
ds3231.setHour(String(buf1).toInt());
sprintf_P(buf1, PSTR("%02x"), ((byte)(pt >> 16)));
ds3231.setMinute(String(buf1).toInt());
sprintf_P(buf1, PSTR("%02x"), ((byte)(pt >> 8)));
ds3231.setSecond(String(buf1).toInt());
greetings and thanks,
André
If you start with an int, why convert it to a string, then to a String, then back to an int?
ds3231.setYear((byte)( pt >> 32));
Seems to me that this can be written as:
ds3231.setMonth(pt >> 48);
(edit)
You probably also need to use AND to select a certain number of bits, e.g.,
ds3231.setMonth((pt >> 48) & 0xff);
gcjr
4
isn't there a problem with these values being in hex?
hex 22 is 34 decimal. the individual nibbles (4-bits) need to be teased out and combined to create a decimal value
#include <stdio.h>
#include <stdint.h>
uint8_t *p = (uint8_t*) & pt;
void
set (
uint8_t val,
const char *lbl )
int dec;
dec = val & 0xF;
dec += (val >> 4) * 10;
printf ("set: %02x %02d %s\n", val, dec, lbl);
int
main ()
printf (" %llx\n", pt);
for (int i = 0; i < sizeof(uint64_t); i++)
printf (" %02x", p [i]);
printf ("\n");
set (p [7], "month");
set (p [6], "day");
set (p [4], "year");
set (p [3], "hour");
set (p [2], "minute");
return 0;
the format is awkward unless it really is intended to be interpreted as nibbles
sadly, the bit mask does not work.
ds3231.setYear((pt >> 32) & 0xff);
result: 34
ds3231.setYear(String(buf1).toInt());
result: 22
Here is a useful function:
byte bcdToNumber(byte b) {
// convert BCD (binary-coded decimal) to an ordinary number
byte tens = (b >> 4) & 0xF;
byte ones = b & 0xF;
return (byte)((tens * 10) + ones);
That function allows you to do this:
ds3231.setYear(bcdToNumber((byte)((pt >> 32) & 0xff)));
You might want tot post your entire sketch, so we can see the actual format of pt.
system
Closed
8
