Hi all, I am having an issue with the ModbusMaster.h library trying to read some Register values from a modbus slave. I am using the example included as follows:
#include<ModbusMaster.h>
#define MAX485_DE 3
#define MAX485_RE_NEG 2
ModbusMaster node;
void preTransmission()
digitalWrite(MAX485_RE_NEG, 0);
digitalWrite(MAX485_DE, 1);
void postTransmission()
digitalWrite(MAX485_RE_NEG, 1);
digitalWrite(MAX485_DE, 0);
pinMode(MAX485_RE_NEG, OUTPUT);
pinMode(MAX485_DE, OUTPUT);
// Init in receive mode
//slave ID 1 from datasheet
node.begin(1, Serial);
Serial.println("Starting Modbus Transaction:");
node.preTransmission(preTransmission);
node.postTransmission(postTransmission);
static uint32_t i;
uint8_t j, result;
uint16_t data[10];
i++;
result = node.readHoldingRegisters(10,2); // i want to read 7 registers from start address 10 based on datasheet
Serial.println("");
if (result == node.ku8MBSuccess) {
Serial.print("Success, Received data: ");
for (j = 0; j < 2; j++) {
data[j] = node.getResponseBuffer(j);
Serial.print(data[0], HEX);
Serial.print(" ");
Serial.println("");
Serial.print("Failed, Response Code: ");
Serial.print(result, HEX);
Serial.println("");
delay(5000);
When i run the code get error like as follows:
12:37:05.358 -> Starting Modbus Transaction:
12:37:05.358 -> Failed, Response Code: E2
12:37:07.439 -> Failed, Response Code: E2
Please kindly help me, thank you very much
