Need help with coding
I'm trying to make a health monitoring project in which I've used a MAX30102 and a ds18b20 temperature sensor I'm viewing the data on an oled display I want to send the data to my blynk account as well but I'm facing some problem in my code I'm sharing my code can someone please help me out with it, I kind of have almost no coding knowledge.
My code:
#include <Wire.h>
#include "MAX30105.h"
#include "spo2_algorithm.h"
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
MAX30105 particleSensor;
TwoWire max30102Wire(1);
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 32
#define OLED_RESET    -1
#define SCREEN_ADDRESS 0x3C
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
uint32_t irBuffer[100];
uint32_t redBuffer[100];
int32_t bufferLength;
int32_t spo2;
int8_t validSPO2;
int32_t heartRate;
int8_t validHeartRate;
OneWire oneWire(5);
DallasTemperature sensors(&oneWire);
char auth[] = "YourAuthToken";
char ssid[] = "YourNetworkSSID";
char pass[] = "YourNetworkPassword";
BlynkTimer timer;
void sendSensorDataToBlynk() {
  sensors.requestTemperatures();
  float tempFahrenheit = sensors.getTempFByIndex(0);
  Serial.print("Heart Rate: ");
  Serial.println(heartRate);
  Serial.print("SpO2: ");
  Serial.println(spo2);
  Serial.print("Temperature: ");
  Serial.print(tempFahrenheit);
  Serial.println(" °F");
  Blynk.virtualWrite(V0, heartRate);
  Blynk.virtualWrite(V1, spo2);
  Blynk.virtualWrite(V2, tempFahrenheit);
  Wire.begin();
  max30102Wire.begin(18, 19);
  if (!particleSensor.begin(max30102Wire, I2C_SPEED_FAST)) {
    Serial.println(F("MAX30105 was not found. Please check wiring/power."));
    while (1);
  if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
    Serial.println(F("SSD1306 allocation failed"));
    for (;;);
  display.clearDisplay();
  display.display();
  delay(2000);
  sensors.begin();
  Blynk.begin(auth, ssid, pass);
  timer.setInterval(5000L, sendSensorDataToBlynk);
  bufferLength = 100;
  for (byte i = 0; i < bufferLength; i++) {
    while (particleSensor.available() == false)
      particleSensor.check();
    redBuffer[i] = particleSensor.getRed();
    irBuffer[i] = particleSensor.getIR();
    particleSensor.nextSample();
  maxim_heart_rate_and_oxygen_saturation(irBuffer, bufferLength, redBuffer, &spo2, &validSPO2, &heartRate, &validHeartRate);
  display.setTextSize(1);
  display.setTextColor(SSD1306_WHITE);
  display.setCursor(0, 0);
  display.print(F("Heart Rate: "));
  display.println(heartRate);
  display.print(F("SpO2: "));
  display.print(spo2);
  display.println(F("%"));
  display.print(F("Temp: "));
  display.print(tempFahrenheit);
  display.println(F("°F"));
  display.display();
  Serial.println("--- New Iteration ---");
  Blynk.run();
  timer.run();
And this is the error message I'm getting:
In file included from C:\Users\DELL\AppData\Local\Temp.arduinoIDE-unsaved20231111-9528-1p0chj0.2qq7\sketch_dec11a\sketch_dec11a.ino:10:
c:\Users\DELL\Documents\Arduino\libraries\Blynk\src/BlynkSimpleEsp32.h: In member function 'void BlynkWifi::connectWiFi(const char*, const char*)':
c:\Users\DELL\Documents\Arduino\libraries\Blynk\src/BlynkSimpleEsp32.h:39:14: error: 'class WiFiClass' has no member named 'mode'
WiFi.mode(WIFI_STA);
c:\Users\DELL\Documents\Arduino\libraries\Blynk\src/BlynkSimpleEsp32.h:39:19: error: 'WIFI_STA' was not declared in this scope
exit status 1
Compilation error: exit status 1
#include <Wire.h>
#include <WiFi.h>
int32_t spo2;
int8_t validSPO2;
int32_t heartRate;
OneWire oneWire(5);
BlynkTimer timer;
  Wire.begin();
    while (1);
    for (;;);
  display.display();
  delay(2000);
  sensors.begin();
  bufferLength = 100;
  display.display();
  Blynk.run();
  timer.run();
This is my code to view the data on serial monitor and oled display
and this is the example code to send data to Blynk account
#include <WiFi.h>
// WiFi credentials
char ssid[] = "YourSSID";
char pass[] = "YourPassword";
// Timer interval for Blynk data transmission
#define SEND_INTERVAL 5000  // 5 seconds
unsigned long lastMillis = 0;
  // Connect to Wi-Fi
  WiFi.begin(ssid, pass);
    Serial.println("Connecting to WiFi...");
  Serial.println("Connected to WiFi");
  Blynk.run();
  if (currentMillis - lastMillis >= SEND_INTERVAL) {
    lastMillis = currentMillis;
    // Your sensor readings and Blynk.virtualWrite() calls here
    float sensorValue = analogRead(A0); // Example sensor reading
    Blynk.virtualWrite(V1, sensorValue); // Send sensor value to V1 in Blynk app
You should save your sketch with a meaningful name
How would you ever determine in two weeks what the file "sketch_dec11a" does??
For the error-message
The Arduino-IDE can be configured to log only a few = too few things about the compiling-process and errors or very much details
So as the next step you should adjust the arduino-IDE to printout each and every detail about the compiling process like described in this tutorial
best regards Stefan
What problem are you facing?
Also put some effort on making your post more readable. Punctuate! It's frustrating to read, if one has to guess the punctuation. I usually stop reading, if the writer doesn't care for such details.
What model Arduino are you using?
Tom... :grinning: :+1: :coffee: :australia:
