I have been rearranging my security alarm project a bit, trying to simplify it a little, without sacrifying any features. I got to the power supply, and wondered why I need so many 7805 regulators, so I found THIS PAGE, and regarding the circuit at the bottom for the high current adjustable regulator, if I swap the LM317 for a LM7805, will it cause the 2n3055's to output 5V regulated?
Yikes, thats a lot of current for an alarm system, have to ask what you are using that demands such a hefty current; is it some kind of electrified fence etc ?
These days DCtoDC converter is the way to go.
The LM78XX series spec/data sheets do have a circuit to increase the output current of LM78XX type regulators, but not using the LM317 type addon you had.
The circuit that you showed, removed most of the regulation properties from the regulator.
But you have the problem of heat dissipation/efficiency.
