Once you have your 3.5+ amp power supply sorted, you could use a MOSFET to switch the LEDs on/off.
Connect all LED anodes to the +ve power rail, and all cathodes to the MOSFET source pin. Connect the MOSFET drain pin to GND, and the Arduino output pin (with a pull-down resistor to GND) to the MOSFET gate pin.
You will need to choose a suitable MOSFET, one which switches on logic levels. Look for "L" at the end of the part number.
AdeV:
Not needed, that module can be controlled directly with the ttl logic output, just like "terryking228" said.
