Hoi,
Ik heb deze code :
// Alle pinnen van de leds
const uint8_t ledPins[] = { 9, 11, 10, 6, 3, 5 };
// de pin van de potmeter
byte potPin = A3;
byte switchPin = 12;
// de waarde die de potmeter aangeeft
int potValue;
int switchValue;
bool LED0 = 0;
// geeft de richting aan waar de led moeten draaien.
int richting;
// houdt de index bij van de huidige brandende led
int currentLed = 0;
// houdt de index bij van de leds van de staart
byte trails[5] = {0, 0, 0, 0, 0};
String action;
int oldSwitchValue;
unsigned long previousMillis = 0;
long interval;
// Zet de seriele monitor aan
for (uint8_t cnt = 0; cnt < sizeof(ledPins); cnt++) {
// Zet alle leds uit
analogWrite(ledPins[cnt], 0);
// Zet de pin mode op output
pinMode(ledPins[cnt], OUTPUT);
pinMode(switchPin, INPUT_PULLUP);
void debug(String text, int variable) {
Serial.print("Mode :");
Serial.print(action);
Serial.print('\t');
Serial.print('\t');
Serial.print("Led :");
Serial.print(currentLed);
Serial.print('\t');
Serial.print('\t');
Serial.print(text);
Serial.print(" : ");
Serial.print(variable);
Serial.print('\t');
Serial.print("Richting");
Serial.println(richting);
void Collect() {
Reads the value of the pot meter
@param values none
@return void because only a local variable is being changed
potValue = analogRead(potPin);
switchValue = digitalRead(switchPin);
void reset() {
reset all values to the starting values
if (switchValue == 0) {
currentLed = -1;
currentLed = -2;
for (int i = 0; i < 5; i++) {
trails[i] = 0;
void Process() {
Change value of currentled
Changes the value of some local variables.
@param values none
if (switchValue != oldSwitchValue) {
reset();
oldSwitchValue = switchValue;
action = "staart";
currentLed += richting;
for (int i = 4; i > 0; i--) {
trails[i] = trails[i - 1];
trails[0] = currentLed;
if (switchValue == 1) {
action = "twee_keer";
currentLed = 0;
LED0 = !LED0;
// Set to predefined values
richting = 0;
interval = 5000;
// 512 - 30 (middle value - offset)
if (potValue < 482)
// richting wordt linksom
richting = -1;
// berekenen van de nieuwe interval voor linksom
interval = map(potValue, 482, 0, 500, 75);
// 512 + 30 (middle value + offset)
if (potValue > 542) {
richting = 1;
// berekenen van de nieuwe interval voor rechtsom
interval = map(potValue, 1023, 542, 75, 500);
debug("switchValue", switchValue);
void display_leidend() {
digitalWrite(ledPins[currentLed], LED0);
void display_volgend() {
if (action == "staart") {
analogWrite(ledPins[trails[4]], 0);
analogWrite(ledPins[trails[3]], 25);
analogWrite(ledPins[trails[2]], 54);
analogWrite(ledPins[trails[1]], 117);
if (action == "twee_keer") {
digitalWrite(ledPins[1], LED0);
digitalWrite(ledPins[2], !LED0);
digitalWrite(ledPins[3], !LED0);
digitalWrite(ledPins[4], LED0);
digitalWrite(ledPins[5], LED0);
void Display() {
takes care of de display of leds
@param values none
@return void because nothing changes
display_volgend();
display_leidend();
void preventOverflow() {
take care that there is no overflow
@param values none
if (richting == 1) {
if (currentLed >= sizeof(ledPins) - 1) {
currentLed = -1;
if (richting == -1) {
if (currentLed <= 0) {
currentLed = sizeof(ledPins);
bool timer() {
if (currentMillis - previousMillis >= interval) {
return true;
return false;
if (timer()) {
Collect();
Process();
Display();
preventOverflow();
Hoe kan ik dit het beste splitsen in classes en misschien wel aparte bestanden zodat het makkelijker is om nieuwe effecten toe te voegen.
JIj gaf me al deze demo.
#define NUMELEMENTS(x) (sizeof(x) / sizeof(x[0]))
// function prototypes
void effect1();
void effect2();
void effect3();
// array with function pointers for effects
void (*effects[])() = {
effect1,
effect2,
effect3,
nullptr,
Serial.println("function pointer demonstration");
static uint8_t selected;
if (Serial.available())
// read serial data
char ch = Serial.read();
// limit 1..9
if (ch >= '1' && ch <= '9')
selected = ch - '0';
// make sure that selected effect does not exceed boundary of effect array
if (selected > NUMELEMENTS(effects))
Serial.println(F("Ongeldige keuze"));
selected = 0;
// only if a correct selection was made and an effect function was specified in the effect array
if (selected != 0 && effects[selected - 1] != nullptr)
// execute selected function
effects[selected - 1]();
void effect1()
Serial.println(__FUNCTION__);
void effect2()
void effect3()
Misschien kunnen we die als vertrek punt gebruiken.
En jij hoeft niet alles te veranderen.
