Hold Button Problem
Well, i am very new at this arduino thing and its awesome.
Shortly i made this RGB light thing for my room and i putted button.
I wanted, when you hold button like 3000 milliseconds it turn rgb off, but i have used 16 hours at internet trying find solution for that. I have tried every thing. Help me.
//this should work
#define BUTTON_LEAD 12
#define LED_LEAD 6
#define NUMBER_OF_PIXELS 60
#define NUMBER_OF_MODES 6
#define NUM_LEDS 60
Adafruit_NeoPixel strip = Adafruit_NeoPixel(60, 6, NEO_GRB + NEO_KHZ800);
bool buttonState = LOW;
bool lastButtonState = LOW;
//delay between pixel flash
const int PIXEL_FLASH_INTERVAL =1 ;//original 25
unsigned long previousMillis = millis();
int mode = 1; // Default mode is one.
byte colors[3][3] = { {0xff, 0,0xff}, //magenta
                        {0xff, 0, 0}, //red
                        {0   , 0xff   , 0xff} }; //turqoise
  pinMode(BUTTON_LEAD, INPUT_PULLUP);
  strip.begin();
  strip.show();
int pos = 0, dir = 1; // Position, direction of "eye"
  switch (mode) {
    case 1:
      rainbow();
    case 2:
    BouncingColoredBalls(3, colors);
      //colorWipe(strip.Color(0, 255, 0));
      case 3:
      scanner();
      case 4:
      colorWipe(50);
      case 5:
      theaterChaseRainbow(20);
      case 6:
      theaterChase(strip.Color(3, 253, 170), 50); // sinivihree
      theaterChase(strip.Color(253, 171, 67), 50); // valkonen
      theaterChase(strip.Color(248, 12, 198), 50); // pinkki
    default:
      mode = 1;
 /*colorWipe function*/
void colorWipe(uint8_t wait) {
  uint32_t c = strip.Color(255, 0, 0); //starts as red
  int b = 0;
  for(int i=0; i<strip.numPixels(); i++) {
    strip.setPixelColor(i,c);
    strip.show();
    delay(wait);
    if (buttonListener()) {
      clearPixel();
    if(i == 59){
      b++;
    if(b == 1){
      if(i == 59){
        c = strip.Color(12, 240, 214); //sets color to aqua
        i = -1;
    if(b == 2){
      if(i == 59){
        c = strip.Color(5, 233, 3); //sets color to green
        i = -1;
    if(b == 3){
      if(i == 59){
      b = 0;
      i = -1;
      c = strip.Color(255, 0, 0); //sets color back to red
/* rainbow function */
void rainbow() {
  uint16_t j = 0;
  while(j<256*3) {
    if(millis() - previousMillis >= PIXEL_FLASH_INTERVAL) {
      uint16_t i = 0;
      while(i < strip.numPixels()) {
        strip.setPixelColor(i, Wheel(((i * 256 / strip.numPixels()) + j) & 255));
        i++;
        if(buttonListener()) { return; }
      strip.show();
      j++;
/* Wheel function */
uint32_t Wheel(byte WheelPos) {
  WheelPos = 255 - WheelPos;
  if(WheelPos < 85) {
    return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  if(WheelPos < 170) {
    WheelPos -= 85;
    return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
  WheelPos -= 170;
  return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
/* monitor button press */
bool buttonListener() {
  bool modeChanged = false;
  buttonState = digitalRead(BUTTON_LEAD);
  if (buttonState != lastButtonState) {
    if (buttonState == LOW) {
      mode++;
      modeChanged = true;
      delay(250);             // Debounce delay
  lastButtonState = buttonState;
  return modeChanged;
void scanner() {
  if (millis() - previousMillis >= PIXEL_FLASH_INTERVAL) {
      clearPixel();
  int j;
  // Draw 5 pixels centered on pos.  setPixelColor() will clip any
  // pixels off the ends of the strip
  strip.setPixelColor(pos - 2, 0x0000FF); // blue
  strip.setPixelColor(pos - 1, 0x00FF00); // green
  strip.setPixelColor(pos    , 0xFF0000); // red
  strip.setPixelColor(pos + 1, 0x00FF00); // green
  strip.setPixelColor(pos + 2, 0x0000FF); // blue
  strip.show();
  //delay(60);
  // Rather than being sneaky and erasing just the tail pixel,
  // it's easier to erase it all and draw a new one next time.
  for(j=-2; j<= 2; j++) strip.setPixelColor(pos+j, 0);
  // Bounce off ends of strip
  pos += dir;
  if(pos < 0) {
    pos = 1;
    dir = -dir;
  } else if(pos >= strip.numPixels()) {
    pos = strip.numPixels() - 2;
    dir = -dir;
void BouncingColoredBalls(int BallCount, byte colors[][3]) {
  float Gravity = -9.81;
  int StartHeight = 1;
  float Height[BallCount];
  float ImpactVelocityStart = sqrt( -2 * Gravity * StartHeight );
  float ImpactVelocity[BallCount];
  float TimeSinceLastBounce[BallCount];
  int   Position[BallCount];
  long  ClockTimeSinceLastBounce[BallCount];
  float Dampening[BallCount];
  for (int i = 0 ; i < BallCount ; i++) {
    ClockTimeSinceLastBounce[i] = millis();
    Height[i] = StartHeight;
    Position[i] = 0;
    ImpactVelocity[i] = ImpactVelocityStart;
    TimeSinceLastBounce[i] = 0;
    Dampening[i] = 0.90 - float(i)/pow(BallCount,2);
  while (true) {
      TimeSinceLastBounce[i] =  millis() - ClockTimeSinceLastBounce[i];
      Height[i] = 0.5 * Gravity * pow( TimeSinceLastBounce[i]/1000 , 2.0 ) + ImpactVelocity[i] * TimeSinceLastBounce[i]/1000;
      if ( Height[i] < 0 ) {
        Height[i] = 0;
        ImpactVelocity[i] = Dampening[i] * ImpactVelocity[i];
        if ( ImpactVelocity[i] < 0.01 ) {
      Position[i] = round( Height[i] * (NUM_LEDS - 1) / StartHeight);
      setPixel(Position[i],colors[i][0],colors[i][1],colors[i][2]);
    showStrip();
    clearPixel();
void theaterChaseRainbow(uint8_t wait) {
  for (int j=0; j < 256; j++) {     // cycle all 256 colors in the wheel
    for (int q=0; q < 3; q++) {
      for (uint16_t i=0; i < strip.numPixels(); i=i+3) {
        strip.setPixelColor(i+q, Wheel( (i+j) % 255));    //turn every third pixel on
      strip.show();
      delay(wait);
        strip.setPixelColor(i+q, 0);        //turn every third pixel off
void theaterChase(uint32_t c, uint8_t wait) {
  for (int j=0; j<10; j++) {  //do 10 cycles of chasing
        strip.setPixelColor(i+q, c);    //turn every third pixel on
      strip.show();
      delay(wait);
void showStrip() {
 #ifdef ADAFRUIT_NEOPIXEL_H
   // NeoPixel
   strip.show();
 #endif
 #ifndef ADAFRUIT_NEOPIXEL_H
   // FastLED
   FastLED.show();
 #endif
void setPixel(int Pixel, byte red, byte green, byte blue) {
   // NeoPixel
   strip.setPixelColor(Pixel, strip.Color(red, green, blue));
 #endif
   // FastLED
   leds[Pixel].r = red;
   leds[Pixel].g = green;
   leds[Pixel].b = blue;
 #endif
void setAll(byte red, byte green, byte blue) {
  for(int i = 0; i < NUM_LEDS; i++ ) {
    setPixel(i, red, green, blue);
  showStrip();
void clearPixel(){
  for(int i=0;i<NUMBER_OF_PIXELS;i++){
    strip.setPixelColor(i, 0,0,0);
  strip.show();
If you used a name that meant something, perhaps the solution to your problem would become apparent.
Just what cheap-assed switches are you using that bounce anywhere near that long?
Somewhere, you need to detect that the switch has become pressed. Where do you do that?
Somewhere, you need to determine if the switch is pressed, and has been pressed for some period of time. Where do you do that?
You'd be a lot further ahead if you re-wrote your code using a state machine and NO blocking functions. The loop() function already loops. Let is handle ALL of the looping that is going on.
That way, you could read the state of the switch every few (hundred) nanoseconds, instead of once a week. It is far easier to change the behavior of the system if you notice the need to make a change more often.
Ossi15:
The way to do that is to record the value of millis() every time the button goes from NOT-PRESSED to PRESSED and later in your code you can check if the button is pressed and how long it is pressed. Something like this
buttonState = digitalRead(buttonPin);
if (buttonState == LOW and previousButtonState == HIGH) { // assumes low when pressed
  buttonPressedMillis = millis();
previousButtonState = buttonState;
if (buttonState == LOW and millis() - buttonPressedMillis >= 3000) {
   // button has been held down for 3 secs
...R
