i want to build smart home automation system in which if my circuit dies or pcb board dies even then i'm able to operate lights with manually using switches so, what can i add in the system for this?
Not build the system...Or add bypass circuitry.
Also moved to Project Guidance.... Was nothing to do with emergency response.
WARNING: High voltage is DANGEROUS
Connect a separate switch between LIVE and each of the orange wires.
The whole relay setup wouldn't be needed if you replace the wall switches with smart switches.
Much safer too.
Leo..
