Hi I would like to ask for a help if there is any mistake in the Ardumote's sketch which stopping me to control fully my andruino ??. , I try to complete my project of home automation with Ardumote for android phone .I have downloaded the sketch from Ardumote website and fill all required fields with my data .On Ardumote site my arduino has been detected but I can controll only output A1 and only I can switch lights on but I can not switch them off.The rest of the outputs besides being detected they dont work .I am 100 % sure that I set them right in Ardumote .Please have look attached sketch from Ardumote is there any mistake which stops me to control it fully .I dont know if problem is with my ruter setup or sketch I have spent a week but nothing .Any help appreciate
http://www.ardumote.com
Copyright (c) 2012 Suat Özgür
http://opensource.org/licenses/MITArdumote example sketch for Duemilanove/Uno boards
The difference to Mega boards is due to memory limitation. The
authentication is done in plaintext and thus less secure
(vulnerable to man in the middle attacks). Also you can not use
the RCSwitch library. So this example is limited to a couple
of LEDs and a analog sensor.Pin Device
3 Status LED (Recieve)
4 Status LED (Transmit)
5 Status LED (IRC Connection)
6 LED (PWM)
A0 Analog sensor (LM35 for example)
A1 LED
A2 LED
A3 LED
// ==== Basic configuration =====================================#define ARDUMOTE_CONTROLLER_ID 123
#define ARDUMOTE_SHARED_SECRET "01234567890abcdef01234567890abcd"#define STATUS_LED_RX 3
#define STATUS_LED_TX 4
#define STATUS_LED_IRC 5byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// ==== General Includes ========================================
#include <Ardumote.h>
#include <SPI.h>
#include <Ethernet.h>
#include <RCSwitch.h>
#include <Servo.h>
#include <Time.h>
#include <ArdumotePlain.h>
#include <ArdumoteMD5.h>
// ===== Maintenance Modules ====================================
#include <SensorMaintenance.h>
#include <ActorMaintenance.h>
// ===== Com Modules ============================================
#include <ComSerial.h>
#include <ComEthernetIRC.h>
#include <ComEthernetHTTP.h>
// ===== Sensor Modules =========================================
#include <SensorAnalog.h>
#include <SensorDigital.h>
#include <SensorRCSwitch.h>
// ===== Actor Modules ==========================================
#include <ActorAnalog.h>
#include <ActorDigital.h>
#include <ActorRCSwitch.h>
#include <ActorServo.h>
// ==============================================================void setup() {
// Init ethernet
Ethernet.begin(mac);
delay(1000);// Init ardumote itself
ArdumotePlain myArdumote;
myArdumote.setup(ARDUMOTE_CONTROLLER_ID, ARDUMOTE_SHARED_SECRET, STATUS_LED_TX, STATUS_LED_RX);// Init maintenance modules (Do not remove)
SensorMaintenance s0;
s0.setup();
myArdumote.addSensorModule( &s0 );ActorMaintenance a0;
a0.setup();
myArdumote.addActorModule( &a0 );// Init ComModules
ComEthernetIRC c2;
c2.setup(STATUS_LED_IRC);
myArdumote.addComModule(&c2);// Init sensors
SensorAnalog s1;
s1.setup("Analog Sensor / Pin A0", A0, 360);// Init actors
ActorDigital a1;
a1.setup("LED / Pin A1", A1);
myArdumote.addActorModule(&a1);ActorDigital a2;
a2.setup("LED / Pin A2", A2);
myArdumote.addActorModule(&a2);ActorDigital a3;
a3.setup("LED / Pin A3", A3);
myArdumote.addActorModule(&a3);ActorAnalog a4;
a4.setup("PWM LED / Pin 6", 6);
myArdumote.addActorModule(&a4);// run
while (true) {
myArdumote.loop();
Pin Device
6 LED (PWM)
A1 LED
A2 LED
A3 LED
#include <SPI.h>
#include <Servo.h>
#include <Time.h>
// Init ethernet
s0.setup();
a0.setup();
// Init ComModules
ComEthernetIRC c2;
// Init sensors
SensorAnalog s1;
// Init actors
ActorDigital a1;
ActorDigital a2;
ActorDigital a3;
ActorAnalog a4;
// run
while (true) {
myArdumote.loop();
