Hi everyone!
I have a project that I came up with to make maintenance of my hens easier - an automatic coop door opener. Now there are several openers on the market already, but they are all vertical, so they open the doors on a string up and down. In my chicken coop, however, I need this to work horizontally, so sliding the door left and right, instead of pulling it up like a guillotine. I also came up with a system that would not only open the coop door but also open the door of the enclosure, so the hens would get out of the coop and out of the enclosure out into the garden. This would be done, in my mind, by one action of a single motor.
Now I am an absolute amateur when it comes to Arduino and engineering - I have no knowledge of circuits, programming etc. I have an inventive and creative mind and I know how it should work, but no idea how to make it work, that is how and what to connect, which motor to choose so it would be strong enough to open the door, how to make the Arduino to turn the motor on specific programmable time etc. So essentially, I only have the concept that I created in 3D and that's it.
I wanted to ask if there would be someone willing to help with this project, either collaborate or point me in the right direction of which parts I need to make it work.
Here is the 3D model that I've made: https://www.tinkercad.com/things/egfpwfHMwhD-otevirani-kurniku/edit?sharecode=qCPwM1VVyXnuBeHlOsU8F7fNxZqB5eHmBXpB4e2dkcA So you have an idea of how it should work. The doors slide to the left in the morning, open the coop, and at a certain point make the upper cogs move the trigger pole up, releasing the door that is pushed against a spring that pops the big door open as soon as the trigger releases the loop. In the evening, the door slide to the right, close the coop and the big doors are manually set into position.
Thank you in advance for any tips!
Can't you mount an already existing opener turned by 90 degrees, so it opens horizontally?
If it needs weight (gravity) to close then add a string+pulley+weight to simulate "horizontal gravity closing"
blimpyway:
I thought about that, but that system works on a turning spool with a string, so when you would need to close it, it just wouldn't do the job. Also, it wouldn't open the second door.
There are many, many designs on hackaday and instructables for chicken coop door openers. Don't reinvent the wheel, just pick one.
If you really want to create your own, the simplest way is to buy a linear actuator. They typically have limit switches at the end of travel so you can drive them indefinitely and they will shut off automatically. But when the power is reversed, they'll travel all the way to the other limit. Couldn't be easier.
cedarlakeinstruments:
Thank you for the tip!
It's really not about me reinventing the wheel, it's just that I don't need only to open the coop door, but also the door of the enclosure - that's very specific and I don't think I can just pick an existing solution, since the chicken coops are not the same...
Please confirm that you already have the functioning doors on the coop and enclosure and are only looking for a system to automate their operation.
Paul
