I need to store around 120 kilobytes of information in an EEPROM. I don't want to use an SD card.
I found this chip online, and purchased it:
It says 128K, but I think i'm reading it wrong. Can someone please help me in understanding how to work out sizes of EEPROMs and any suggestions on storing data other than on an SD card.
May I suggest the 23LCV1024 SRAM chip. 128K bytes. SPI interface, so its fast. With the addition of a 3V button cell it can be non-volatile (OK, semi non-volatile). Unlimited writes. Available in through hole 8 pin DIP. You can have as many as you need on the SPI bus (each would need a chip select).
Depends on how long you have to write the data and how long you want to retain it.
I'd recommend an SD card because they're cheap and easy to interface, but you seem to have an aversion.
