how can arduino connect with Android App via bluetooth?
Hi everyone,
I'm new to arduino. I'm designing a project which contains hardware and software part, the hardware part should be able to send some information to the Android App to trigger further actions.
Can you please recommend a easy implemented bluetooth module? Do I need to adopt any communication protocols? If yes, then which one is the easiest since I'm an absolute greenhand.
I've heard that HC-05 and I2C are the most common options? Are they suitable for my project?
Thank you very much! Any advice would be appreciated!
Yuan_Junkai:
Hi everyone,
You can send serial data from an Arduino via a HC05 or HC06 Bluetooth adapter and you can recieve it with an Android application such as Blueterm, which is a Bluetoorh serial terminal app.
To do anymore with the serial data, on the Android device, that you can send through the HC05\HC06 from the Arduino is a question for the developers of Android apps.
srnet:
Thank you very much for your advice!
So i need to use an application like Blueterm to receive the serial data first, then transfer it to my own App?
can i use my own App to receive the commands from Arduino directly?
Could you pls give me some advice?
Thanks a lot!
Yuan_Junkai:
Blueterm was given as an example.
It you want an Android app to do stuff with data it receives over serial Bluetooth, then thats really a question for an Android support forum.
srnet:
ok, thank you very much!
