How can I close the library manager?
Yes, sometimes the library manager sticks open and will not toggle off.
I think I’ve opened another window and tried toggling it on and off there. Other times I closed and reopened.
You don't mention how you try to close it. Have you tried <ctrl><shift>I
? That would toggle the library manager open/close.
I normally use the mouse and select Tools/ManageLibraries to try to toggle it on or off, but sometimes that has no effect. Especially if I left the window open for a while and worked on other things. In that case, the library panel remains stuck.
It is intermittent, and I have not discovered a repeatable way to trigger it.
Thanks.
"You don't mention how you try to close it."
That's because there was no visual clue. The menu option to open the window, which shows the ctrl-shift-i short-cut, doesn't state that it's a toggle.
I later found that the third button on the left, which looks like a book-shelf, is a toggle.
