How can I deliberately make a stepper motor vibrate?
I'm using a Nema 17 stepper with a 4988 driver in 16x step mode in a dispensing application. Sometimes the output media gets hung up in the output chute. A little vibration would help.
Is there an easy way to pulse the stepper motor to make it vibrate when needed? It's ok if it turns at the same time.
Thanks!
I would guess that you could try reducing the microstepping to 1 and try driving the motor backwards and forwards a few steps at a suitable rate. You may need to wire output pins to the microstep controls of the driver. Would it matter if you lost steps?
You could up the stepper power supply to the max, 35 volts, and then try stepping a6 steps back and 16 forward as fast as you can.
Move rapidly one step forwards one step back.
Thanks I will try back and forth a few steps.
It's ok to lose steps. But I can't change stepping mode.
Fwd & rev a few steps works great. Thanks
Please read
Thanking the people who helped you.
And consider if you have done this correctly.
