I am new to this forum (and board programming). I am a mechanical engineer by trade but unfortunately have little experience in the programming/electronic side of engineering, although I am competent with Matlab (not much help!)
I have decided that I need to learn programming with the way the world is going (and for fun!)
Anyway to the question:
I have bought the pictured components with the aim of creating a gyro camera for my motorbike like the ones in motogp. Obviously these are far more advanced than anything I am likely to achieve but its worth a shot right?
I started out by buying an UNO and a 6050 to try and get some data from. this worked fine, but then I found the board in the title which seemed to have everything I need on one chip... at £6 I thought why not give it a go!
Essentially, I have had no problem with flashing to the Uno and getting raw data off the 6050 but I would like to know how to flash to the MWC board and do the same!
Does anyone has any information about this board? If anyone can help me I would be most grateful!
That is the board I have, and I did see that link before posting, but it didn't supply me with a data sheet, or any method of uploading a sketch to it.
Also, most of the links on that page don't work unfortunately.
guitarcarrot:
And what about the other 3,910 pages that Google found ?
Unless you find the underlying information it will be hard to help.
And your title does not tell Forum readers the name of the product you have a problem with, so, even if someone knows the answer they probably won't relate it to your question. If you modify your original post you can change the title.
guitarcarrot:
What underlying information do I need?
This information ? (your original Post ?)
Or, more specifically, the programming specs for that board.
At the moment your question is a bit like "How do I change the plugs in a Spitfire". And I am saying - get the Spitfire maintenance manual so we can all read it and see how to help you.
It looks to have a CP2102 USB to serial chip on it. It seems to possibly have a ISP connector(but I might be wrong ) if you look at the attached picture. You might want to find out if the CP2102 is connected to the hardware UART on the ATMEGA.
