I am having trouble programming a "button-state" (regardless of time pressed) to last for 500ms.
What I would like is to have any input for the button too last for 500ms, regardless of actual "button-state". So, if you press the button, it will stay for 500ms- no longer, no less.
int button = 3;
int unsigned long currentMillis = millis();
unsigned long buttonPress;
unsigned long shotRelease = 500; //adjusts timing of jumpshot animation in milliseconds
unsigned long shotStart = 200;
bool buttonState = false;
pinMode(button, OUTPUT);
int sensorValue = analogRead(button);
Serial.println(sensorValue);
delay(1);
int buttonState = false;
if (analogRead(button) == 0 && (buttonState == false)) {
buttonPress = currentMillis;
buttonState = true;
if ((buttonState == true) && shotStart + buttonPress); {
analogWrite(button, 0);
Serial.println("HOLD");
if (analogRead(button) == 0 && (buttonState == true && shotRelease + buttonPress)) {
analogWrite(button, !0);
Serial.println("Green");
okay I did this and it worked in the serial monitor, I am going to test on my equipment now. Only issue is, that If I physically keep the button it will loop() the input in 200ms intervals. Thats lame.
I wish it would stop and wait for a false button before starting the loop() again.
int button = 3;
//unsigned long shotRelease = 500; //adjusts timing in milliseconds
//unsigned long shotStart = 200;
pinMode(button, INPUT);
int sensorValue = buttonState;
delay(10);
while (analogRead(button) > 0) {
Serial.println("n");
while (analogRead(button) <= 2) {
buttonState = true;
Serial.println("y");
if (buttonState == true) {
Serial.println("green");
delay(200);
Looks like you know about millis() therefore you are not really a brand new noob
Using ‘while’ can result in blocking code, suggest you avoid it unless there is a good reason to use it.
An example covering timing and switch monitor for you to review:
#define OFF LOW
#define ON HIGH
unsigned long ledOnMillis;
const unsigned long onTime = 5000;
boolean ledOnFlag = false;
const byte redLED = 13;
const byte onSwitch = 2;
const byte auxOnSwitch = 3;
const byte auxOffSwitch = 4;
byte lastOnSwitchState;
pinMode(redLED, OUTPUT);
digitalWrite(redLED, OFF);
//switch wired so a press give a LOW
pinMode(onSwitch, INPUT_PULLUP);
//initialize the last State variable
lastOnSwitchState = digitalRead(onSwitch);
pinMode(auxOnSwitch, INPUT_PULLUP);
pinMode(auxOffSwitch, INPUT_PULLUP);
} //END of setup()
byte currentState = digitalRead(onSwitch);
//when timing is disabled, has the ON switch changed state?
if (ledOnFlag == false && lastOnSwitchState != currentState)
//update to the new state
lastOnSwitchState = currentState;
//did the switch just get pressed i.e. LOW?
if (currentState == LOW)
//turn the red LED ON
digitalWrite(redLED, ON);
Serial.println("Turn LED ON");
//the time when the red LED went ON
ledOnMillis = millis();
//enable timing
ledOnFlag = true;
//switch must have gone HIGH
//nothing to do here
} //END of if (ledOnFlag == false && lastOnSwitchState != currentState)
//if timing is enabled, has the timing interval expired?
if (ledOnFlag == true && millis() - ledOnMillis >= onTime)
//turn the red LED OFF 5 seconds after it went ON
Serial.println("Turn LED OFF");
//disable timing
ledOnFlag = false; // <------<<<<<
//maybe do some other stuff
//when the auxiliary on switch is pressed, turn ON the red LED
if (digitalRead(auxOnSwitch) == LOW)
//when the auxiliary off switch is pressed, turn OFF the red LED
if (digitalRead(auxOffSwitch) == LOW)
//turn the red LED Off
//disable timing
ledOnFlag = false;
} //END of loop()
I have a remote that is controlled by one button. When that by is pressed I would like the action to take place for 500ms, regardless of how long the button is pressed. Then the action would stop, reset and wait for the next button press.
In this case water a plant for 500ms or 0.5s. Holding button longer would flood the plant, tapping the button wouldn't give the plant enough water...
Suppose the button is pressed for 1 minute, then the plant is watered for only 500ms. That I understand.
But what if the button is pressed multiple times very quickly while the plant is being watered ? Do you want the 500ms to have ended and the button to be released before a new press is accepted ?
@larryd, your example is how it should be done of course, but can you do "if ( !ledOnFlag && lastOnSwitchState..." and "if ( ledOnFlag && millis..." ?
Koepel:
Great question. Yes I would want the 500ms to have ended, and the button to be released before a new press is accepted.
@EugeneBatiste
If you want help, you should answer the questions put to you.
When you don't answer us, we have no way of knowing where you are having problems.
Do you follow what is happening here?
//Version 1.01
#define PUSHED LOW
#define NotPUSHED HIGH
#define PUMPon HIGH
#define PUMPoff LOW
#define ENABLED true
#define DISABLED false
const byte button = 2;
const byte waterPump = 3;
byte lastButtonState;
bool timingFlag = DISABLED;
unsigned long lastMillis;
unsigned long timingMillis;
const unsigned long timingInterval = 5000; // 5 second
pinMode(waterPump, OUTPUT);
digitalWrite(waterPump, PUMPoff);
pinMode(button, INPUT_PULLUP);
lastButtonState = digitalRead(button);
} //END of setup()
//time to check the switches?
if (millis() - lastMillis > 50)
//restart timer
lastMillis = millis();
checkSwitches();
//when the timer is enabled, has the interval expired?
if (timingFlag == ENABLED && millis() - timingMillis >= timingInterval)
//disable timing
//stop watering
Serial.println("Water is OFF");
//other none blocking code
} //END of loop()
void checkSwitches()
byte currentState = 0;
currentState = digitalRead(button);
//has the switch changed state?
if (lastButtonState != currentState)
lastButtonState = currentState;
//when timing is disabled, was the button pushed/closed?
if (timingFlag == DISABLED && currentState == PUSHED)
//enable timing
timingFlag = ENABLED;
//reset the timer
timingMillis = millis();
//start watering
digitalWrite(waterPump, PUMPon);
Serial.println("Water is ON");
} //END of if (lastButtonState != currentState))
//future switches go here
} //END of checkSwitches()
