Hello all,
First off, I apologize if this is not in the correct section, but this is the most appropriate section I could find for what I am trying to do.
I dont know if this is possible or not, so I am asking.
What I am trying to do is utilizing my 2 IR remotes for the fan/light and ac/heating system respectively, is to create a system that will turn the fan and the ac on at scheduled times and days. For example, from monday through thursday, I want my ac to turn on at 8pm and off at 8am, and on friday and saturday I want it on all day.
If possible, I also want to connect it to my home wifi so that if I want to turn it on and I am not at home, I can do that as well (similar to the remote systems like NEST). I would also like to add a temperature sensor that will both display the current temperature on a small LCD and (if possible) display it on my phone as well. (Displaying it on my phone is not a need, just a nice to have.)
I am quite a noob at arduino programming, so please be patient with me and try to explain how to do this in as simple a way as possible.
Edit: Ill try and make this a little clearer.
My ac/heating unit is one of the ones that is mounted on the wall and plugs into an outlet, so maybe I can somehow use the remote control that came with it or something?
My fan also has a remote and maybe I could use that for the controller?
I am not looking to start opening up the walls or removing the switches and outlets to get to the wiring. I simply want to (if possible, of course) use the IR remotes to turn the fan and ac on and off.
Thanks,
PhauxFenix
